Line Stoppers/Clutches (F32 Hoyt)
Posted by rbrown739 (bob.brown@…>)
For my F32 (Hoyt) I’m interested in installing a 2 level turning block
(6 sheeves) up by the mast in place of the original single level
turning block(3 sheeves) so that I can run my main sheet forward and
then back and also run my vang back. I’d be interested in any lessons
learned during this process and what people did for installing extra
line stoppers/clutches. It seems the real estate back by the current
stoppers is pretty crowded. Any pictures would be appreciated.
On a recent trip to Cuttyhunk I was surprised to find another F32
(Hoyt) anchored right in front of my boat. It was the S/V Grace from
Newport.
I’m having trouble getting to the photo section of our Yahoo site.
Anybody else having a problem?
Bob
“Carina” F32
As I have an F30, I can’t comment about real estate for additional line stoppers on a 32. But I did install a two level organizer and I’m quite pleased with it. I stacked two Spinlock T50/3s in place of the original Schaefer triple. I had to drill new holes, but the mounting block was reusable. The Spinlock organizers are surprisingly strong and quite reasonably priced.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of rbrown739Sent: Wednesday, August 31, 2005 2:58 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Line Stoppers/Clutches (F32 Hoyt)For my F32 (Hoyt) I’m interested in installing a 2 level turning block(6 sheeves) up by the mast in place of the original single levelturning block(3 sheeves) so that I can run my main sheet forward andthen back and also run my vang back. I’d be interested in any lessonslearned during this process and what people did for installing extraline stoppers/clutches. It seems the real estate back by the currentstoppers is pretty crowded. Any pictures would be appreciated.On a recent trip to Cuttyhunk I was surprised to find another F32(Hoyt) anchored right in front of my boat. It was the S/V Grace fromNewport.I’m having trouble getting to the photo section of our Yahoo site. Anybody else having a problem?Thanks,Bob"Carina" F32IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe Maw LLP) of that transaction or matter, and (ii) such taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisorThis email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
A bit over a year ago I replaced the original turning blocks/line organizers on my Hoyt32 with double stacked units totaling 8 sheaves on each side. At the same time I replaced the original line stoppers on the cabin top with two custom made 6 gang rope/line clutches. these were all fabricated by Garhauer, quite reasonable, and have performed flawlessly. I prefer separate reefing lines for clew and tack, hence the need for the extra equipment.
Start your day with Yahoo! - make it your home page
I have an F-33 so also can’t comment on space. I also installed the spinlocks and am very happy. they resolved some chafe issues due to the height and narrow frame and work very well. Can now raise my mizzen without the winch.
The hardest part of installation was related to access via the headliner etc., drilling throught he backing plate and routing out balsa and epoxying and then redrilling. If I had just drilled new holes and not bothered with the balsa it would have been very easy.
I used Lewmar D-2 clutches to ensure the halyards could be released at full load without use of the winch. They work very well but are a bit large and heavy.
Alan
Sent: Wednesday, August 31, 2005 3:17 PM
Subject: RE: [freedomyachts2003] Line Stoppers/Clutches (F32 Hoyt)
Al Lorman
F30 Ab Initio
I did the same thing as Alan did in terms of cleaning out the balsa and replacing with epoxy, etc. As I had my headliner down for repairs anyhow, that wasn’t a problem. What I found interesting is that the original organizer was caulked with silicone. These days, the only suggested uses for silicone on a boat are around certain kinds of plastics. Yet the 17 year old silicone on my organizer held and didn’t leak at all; the headliner showed no sign of leakage ever and the core was dry (even though I replaced it anyhow).
Al Lorman
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Alan KusinitzSent: Wednesday, August 31, 2005 5:44 PMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] Line Stoppers/Clutches (F32 Hoyt)
Alan
Al Lorman
F30 Ab Initio
This email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe Maw LLP) of that transaction or matter, and (ii) such taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisorThis email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
I’ve found the same that silicone was used for everything I’ve found so far including the throughbolted lifeline stanchions. In general the silicone was quite thick and held well and only in a few places have I found seepage or wet balsa. Howver it makes me uncomfortable not having the epoxy.
Alan
Sent: Wednesday, August 31, 2005 5:50 PM
Al Lorman
Alan
Al Lorman
F30 Ab Initio
Ditto to everything you said. I did find water intrusion when I installed a new diesel deck fill and around the bolt holes in the hinges on the cockpit lazarette lid.
Al
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Alan KusinitzSent: Wednesday, August 31, 2005 7:01 PMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] Line Stoppers/Clutches (F32 Hoyt)
Alan
Al Lorman
Alan
Al Lorman
F30 Ab Initio
The deck fills are on my list to take out and epoxy although I don’t see anything or find anything with the moisture meter at this point.
Alan
Sent: Wednesday, August 31, 2005 7:05 PM
Al
Alan
Al Lorman
Alan
Al Lorman
F30 Ab Initio
