Allen,
I’m not familiar with the traveller arrangement on the F-21, but you
should only have to release the upwind cam to dump main. This is
often all that’s required to regain control, or to allow enough
pressure to come off the main to ease the sheet.
A common occurrence is to allow the boat to round up sharply in
these conditions - it seems logical to bring the boat head to wind
to ease the pressure on the sails, but the combined speed of the
boat, wind pressure on the sail, and momentum can cause the boat’s
angle of heel to INCREASE under the very conditions you’re trying to
alleviate! Try to ease the boat into the turn, making it as gradual
as you can. Don’t Panic - the boat is more stable than you think,
and wants to be upright. This gradual turn keeps the moment of the
boat from causing even MORE heel before the pressure is eased. Then
slowly bring the boat back onto course as the gust passes.
Some sailors, upon anticipating a gust, will actually start to steer
somewhat away from the current wind angle. I wouldn’t have
recommended this in your situation where you didn’t have control of
the sheet, but this off-wind steering technique uses the boat’s
momentum to heel the boat slightly to windward (offset, of course,
by the pressure in the sail).
I’m not sure in the F-21, but in my F-40 cat ketch, I’ve already got
a reef in the mizzen and am contemplating one in the main in 15-20
kts apparent.
The previous owner said, “reef early - reef often” and it’s very
good advice!
fair winds,
lance ryley, “Bright Star,” F40 CK #49
— In freedomyachts2003@yahoogroups.com, “allenmcclung”
<amcclung@f…> wrote:
While sailing yesterday in 15/20 knot winds, a gust came up and
heeled the boat over even more. I had the tiller extender in one
hand, a 230 lb. passenger sitting on the wrong side of the boat
adding to the angle of the heel, and the line to spill air out of
main wouldn’t release. Too much pressure on the main sail, I
guess.
Not good, and I don’t want it to happen again. In the end, nobody
got
too wet, and I got the boat headed in the opposite direction. One
of
those spin-arounds, I think. As I sit here at the computer
thinking
about the situation, I suppose I should/could have released the
traveler to de-power the main sail. Of course, that would mean
releasing both stb. and port lines from their cams while holding
tiller with my knees. At the time, the thought didn’t occur to me.
Any suggestions? In other boats I’ve sailed, the release to the
main
is located where you can stomp on the line to release it. In the F-
21, that’s not an option.
Allen
