I had Doyle Stack Pack on my Tartan 30. Loved it. Unfurl took 1 minute. Furling took about 2-3 minutes.
It makes a one hour sail something I didn’t think twice about because it was so easy.
The Stack Pack required only 2 attachments on each side of the mast. One just above the boom and one 1/2 way up the mast.
Bill
_________________________________________________William A. Cormack, CPAPrincipal and Chief Financial OfficerWhelan Associates, LLC, a Corporate Real Estate Service Firm100 Faunce Corner Executive Center, Suite 150500 Faunce Corner RoadNorth Dartmouth, MA 02747Voice: 508-984-4100, Fax: 508-984-4101, Cell 508-254-5828MailTo:wacormack@…
Sent: 01/10/2006 8:55 AM
Subject: RE: [freedomyachts2003] Re: Mack Pack
Interesting. I find the time it takes to stow the sail with the mack packs to be dramatically less then with sail ties and sail covers. (And on the 33 there are two) I imagine it partially depends on the how tight the original sail covers were. Used to take me about 20 minutes or so to stow both sails and get the sail covers on and involved a lot of long reaches (and I’m short). With the Mack Packs takes me about 5 minutes total.
Alan F-33 Hull #51 1982
The information contained in this e-mail and any attachments is intended only for the personal and confidential use of the recipient(s) named above and may be subject to attorney client privilege if so marked. If the reader of this message is not the intended recipient or an agent responsible for delivering it to the intended recipient, you are hereby notified that you have received this document in error and that any review, dissemination, distribution, or copying of this message is strictly prohibited. If you have received this communication in error, please notify us immediately by e-mail, and delete the original message.
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of macks011Sent: Tuesday, January 10, 2006 8:17 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Mack Pack
I installed the Mack Pack on a F36 with a solid vang. Works well. A few points: On the 36 at least, there never was a topping lift. The lazy jacks served that purpose and could still as well wih the Mack Pack if you are so inclined. The Mack Pack requires 6 holes in the mast, 3 on each side of the sail track. Drill and tap an 8/32 machine screw and epoxy in place. Re-think the lazy jack leg spacing along the boom. Mack equally spaces the down legs along your boom length. If you have a full roach, full batten main, you will not have enough support at the boom end. Since the sail is already supported at the mast track, Favor the spacing to the aft end of the boom. Consider extra length primary lazy jack lines led aft along the boom to cleats for adjusting purposes. finally, there is the hanging laundry effect. The boat just doesnt look clean with the cover hanging while sailing. But, you get used to it. In reality, in the time and effort it takes to stow the sail and zip up the Mack, you can retrieve and put on a normal sail cover. All things being equal and had I not needed a new sail cover, I would have upgraded the existing lazy jack system and altered the sail cover. — In freedomyachts2003@yahoogroups.com, “tgcmd” <Finesse@s…> wrote:>> Does the Mack Pack work well without a topping lift on the Freedom rigs? Do those with > Mack Packs use their boom end support for the aft end of the pack? Does their system > require new holes in the carbon fiber mast? What else would I have to consider in thinking > about installing the Mack Pack on a F-33?> Thomas> F-33 #66 L’Audace>
