Max,
I noticed on the map that I am located 60 miles SE of my actual
location.
Maybe I gave you the wrong coordinates.Longitude 39 degrees 47 min.
21.10seconds. Lat. 76 degrees 53 min. 52.67 seconds.
BIFF
Biff,
My figures and your figures match. That means that the coordinates
that you provided are slightly off. I suggest using the Google Maps
method outline at http://www.freedom21.info/maprequest.htm to refine
your numbers.
Here are the numbers that I have:
(-76.535267,39.472110)
Sincerely,
Max
— In freedom21@yahoogroups.com, “julius christensen”
<biff_sail@…> wrote:
Max,
location.
BIFF
