Two noises, different solutions
Mast Clunk;
Clunk is caused by the mast inside diameter being larger then the outside of the
disk that
the mast fits over. The sound is a thud that occurs when you tack. The fix is
to fill in the
gap. ÇAUTION: If you bond the mast to the disk, deliberately or otherwise,
your next
mast removal will be with a Saws-All, an extremely undesirable un-intended
consequence.
Mast Squeak;
I think this comes from the “wedge” flexing. For me, it is a Live With it,
Freedom Quark.
Mast Base Bolts.
The Stainless bolts thru the mast base are intended to keep the mast from
“twisting,” not
to keep the mast from slipping, and thus thunking at the base.
Remember, Carbon masts bend and flex, desirable. Wood wedges, are hard spots,
since
the do not flex (enough) in their use as a deck wedge, Thus they are Point
Loaded spots
on the mast. Undesirable. Remember, wood wedges are common on STAYED rigs,
where
flexing is undesirable, as yo need to keep the compression element, (mast) the
compression-tension loop, IN COLUMN, (not bowing.) Mast bend, in the for-aft
plain, is
a different issue.
A note;
Boat hulls flex, and when they do, things either flex as well or have room to
slip. If the
bulked was originally hard bonded to the hull, then fix it. IF not, maybe a
non-squeaky
gap filler would be more desirable. If you bond something that is not designed
to be, you
will be modifying the stress distribution or as they call it a Hardspot.
Sometimes it isn’t
problem, but _______.
S/V Cayenne, freedom 44 with two Permanent Masts
