Posted by hxschiller (schiller@…>)
My '87 Freedom 28 was disassembled by a yard at point of purchase. As
a consequence I am now facing a mystery. I’m looking at a circle of
threaded studs on the inside of the mast hole in the cabin top, but
cannot find anything that looks as though it should be held by these
studs. I have a set of acorn nuts that match these studs but nothing
else.
Is there a ring that is missing, or are the nuts simply put on these
studs (are they bolts?)?
Also, how is the carpeted trim ring fastened to the cabin overhead
once the mast is in place?
Posted by Payne, Doug (doug.payne@…>)
Doing this from memory and the 28’s manual will tell you all this stuff, but there is an aluminum ring topsides that gets siliconed when you reposition it, plastic wedges to center the mast, that go between the mast and the cabin top, and a trim ring that goes around the mast on the inside up against the cabin top. I believe that is secured with screws.
Douglas M. Payne
Tatum Partners
480-614-4915 Office
480-236-4561 Mobile
480-614-4916 Fax
doug.payne@…
TATUM PARTNERS
This electronic message is intended for the person or entity to which it is addressed and may contain confidential and/or privileged information. Any review, dissemination, copying, printing, or other use of this electronic message by persons or entities other than the addressee is prohibited. If you received this electronic message in error, please contact the sender immediately and delete the electronic message from any and all computers.
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of hxschillerSent: Tuesday, October 25, 2005 6:02 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Mast “partners”
My '87 Freedom 28 was disassembled by a yard at point of purchase. As a consequence I am now facing a mystery. I’m looking at a circle of threaded studs on the inside of the mast hole in the cabin top, but cannot find anything that looks as though it should be held by these studs. I have a set of acorn nuts that match these studs but nothing else. Is there a ring that is missing, or are the nuts simply put on these studs (are they bolts?)?Also, how is the carpeted trim ring fastened to the cabin overhead once the mast is in place?
