Posted by anngilmartin3 (anngilmartin3@…>)
Owner of Freedom 32 - The mast makes an annoying creaking sound when at
anchor in choppy seas. Does it have to have wooden blocks installed to
keep it from moving?
No- They are polyurethane. check to see the poly mast wedges are tight.
Sent: Friday, June 17, 2005 2:47 PM
Subject: [freedomyachts2003] Mast stability
keep it from moving?Yahoo! Groups Links
tight.
----- Original Message -----Owner of Freedom 32 - The mast makes an annoying creaking sound
when at
He might be talking about the noise made by the mast creaking on the
mast step.
This problem has come up year after year on this BB.
I cured the problem on my boat when I last pulled the mast by
squirting a bead of silicon on the step just before dropping the mast
the last foot or so before restepping it. On a 32 (I understand) you
might have to be careful not to plug a drainage hole when doing this.
However, on a 36 there is no drainage hole at that location – at
least not on my boat.
I accept it as part of sailing a freedom. Its almost
reassuring these days when sailing the SF Bay. Yep,
the mast is creaking, all is well with the world.
Same thing with the sole. You drop stuff and get
dings, each one has its own character and story.
That one happened when my son dropped the winch
handle…God was I pissed… and that other one
happened when I dropped the screwdriver while I was
replacing the headliner. Ahem, a reasonable mistake by
a master shipwright. All the while silently chuckling
at the many silly things that have happened over the
years.
Good and bad memories are imbedded in my boat’s
defects I refuse to erase them unless they compromise
safety (or render me irretrievably un-bristol like)
Mike
mast wedges are
tight.
creaking sound
when at
anchor in choppy seas.He might be talking about the noise made by the mast
creaking on the
mast step.
the mast by
dropping the mast
(I understand) you
when doing this.
location – at
Do You Yahoo!?
http://mail.yahoo.com
I had a problem with my main rotating slightly that caused some rubbing/wear both to the base of the mast and next to the collar. If that’s what cause the creaking its a bad thing. I now have spartited at the collar at the cabin top and have wooden wedges at the base along with fiberglass reinforcing around the holes for the set screws/pins at the base that go through the aluminum collar.
So far so good.
Alan F33 Hull #51 SEAPR
Sent: Friday, June 17, 2005 9:17 PM
Subject: Re: [freedomyachts2003] Re: Mast stability
I accept it as part of sailing a freedom. Its almostreassuring these days when sailing the SF Bay. Yep,the mast is creaking, all is well with the world.Same thing with the sole. You drop stuff and getdings, each one has its own character and story. That one happened when my son dropped the winchhandle…God was I pissed… and that other onehappened when I dropped the screwdriver while I wasreplacing the headliner. Ahem, a reasonable mistake bya master shipwright. All the while silently chucklingat the many silly things that have happened over theyears.Good and bad memories are imbedded in my boat’sdefects I refuse to erase them unless they compromisesafety (or render me irretrievably un-bristol like)Mike— jerry_magic1 <jerry_magic1@…> wrote:> — Jerome Weinraub <zayde@o…> wrote:> > No- They are polyurethane. check to see the poly> mast wedges are > tight.> > ----- Original Message ----- > > > Owner of Freedom 32 - The mast makes an annoying> creaking sound > when at > > > anchor in choppy seas. > > He might be talking about the noise made by the mast> creaking on the > mast step.> This problem has come up year after year on this BB.> I cured the problem on my boat when I last pulled> the mast by > squirting a bead of silicon on the step just before> dropping the mast > the last foot or so before restepping it. On a 32> (I understand) you > might have to be careful not to plug a drainage hole> when doing this. > However, on a 36 there is no drainage hole at that> location – at > least not on my boat.> > > __________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Check the buttom.
