My boat is in the water and I am trying to set up a trailer to get her back to
my house (so I can make the trailer ‘fit’ well. Does anybody have the following
measurements:
I have the deep keel, 3’9" draft - how deep is the keel itself?
What is the measurement from the rear of the keel to the outside of the
transom?
How long (not tall) is the keel, measured at the hull?
I looked for drawings on the internet, but found none. I scored a trailer for a
Chrysler 22, title and trailer for $50! I weld and can easily make the riding
boards to fit the hull.
Posted by esx123 (scott_shuler@…>)
I believe there is an F-21 that is on the hard at my marina. I’ll check and if this is so, I’ll send the measurments tomorrow.David Walker <wahooadv@…> wrote: My boat is in the water and I am trying to set up a trailer to get her back to my house (so I can make the trailer ‘fit’ well. Does anybody have the following measurements:1. I have the deep keel, 3’9" draft - how deep is the keel itself?2. What is the measurement from the rear of the keel to the outside of the transom?3. How long (not tall) is the keel, measured at
the hull?I looked for drawings on the internet, but found none. I scored a trailer for a Chrysler 22, title and trailer for $50! I weld and can easily make the riding boards to fit the hull.Thank you to anyone who can help.Laissez les bons temps rouler
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
Please see my measurements below. The trailer was a Triad. I believe it might be same as used for J22. You might be ableto get better measurements if you can find one. I’m only a few minutes from the marina where I took the measurements so, if you need anything further, just ask.David Walker <wahooadv@…> wrote: My boat is in the water and I am trying to set up a trailer to get her back to my house (so I can make the trailer ‘fit’ well. Does anybody have the following measurements: 1. I have the deep keel, 3’9" draft - how deep is the keel
itself? 3’ 2. What is the measurement from the rear of the keel to the outside of the transom? 9’9" 3. How long (not tall) is the keel, measured at the hull? 46" I looked for drawings on the internet, but found none. I scored a trailer for a Chrysler 22, title and trailer for $50! I weld and can easily make the riding boards to fit the hull. Thank you to anyone who can help. Laissez les bons temps rouler
Never miss a thing. Make Yahoo your homepage.
Thank you! Those look great! They should help me mock up the welding to get it home.
Cheers,
David
end of message
To: freedom21@yahoogroups.com
Sent: Saturday, December 15, 2007 10:23 AM
Subject: Re: [freedom21] measurements
Please see my measurements below. The trailer was a Triad. I believe it might be same as used for J22. You might be ableto get better measurements if you can find one. I’m only a few minutes from the marina where I took the measurements so, if you need anything further, just ask.David Walker <wahooadv@earthlink.net> wrote:
My boat is in the water and I am trying to set up a trailer to get her back to my house (so I can make the trailer ‘fit’ well. Does anybody have the following measurements:1. I have the deep keel, 3’9" draft - how deep is the keel itself? 3’2. What is the measurement from the rear of the keel to the outside of the transom? 9’9"3. How long (not tall) is the keel, measured at the hull? 46"I looked for drawings on the internet, but found none. I scored a trailer for a Chrysler 22, title and trailer for $50! I weld and can easily make the riding boards to fit the hull.Thank you to anyone who can help.Laissez les bons temps rouler
David, If you go to www triadtrailers.com you can get pictures of the trailers that were made for freedom 21’s. If they don’t have a freedom,look for a j22 trailer. Triad will sell you the screwjacks that come with their trailers. I have a triad and it is a super strong trailer. Good luck. BiffDavid Walker <wahooadv@…> wrote: Thank you! Those look great! They should
help me mock up the welding to get it home. Cheers, David end of message ----- Original Message ----- From: esx123 To: freedom21@yahoogroups.com Sent: Saturday, December 15, 2007 10:23 AM Subject: Re: [freedom21] measurements Please see my
measurements below. The trailer was a Triad. I believe it might be same as used for J22. You might be ableto get better measurements if you can find one. I’m only a few minutes from the marina where I took the measurements so, if you need anything further, just ask.David Walker <wahooadv@earthlink.net> wrote: My boat is in the water and I am trying to set up a trailer to get her back to my house (so I can make the trailer ‘fit’ well. Does anybody have the following measurements:1. I have the deep keel, 3’9" draft - how deep is the keel itself? 3’2. What is the measurement from the rear of the keel to the outside of the transom? 9’9"3. How long (not tall) is the keel, measured at the hull? 46"I looked for drawings on the internet, but found none. I scored a trailer
for a Chrysler 22, title and trailer for $50! I weld and can easily make the riding boards to fit the hull.Thank you to anyone who can help.Laissez les bons temps rouler Never miss a thing. Make Yahoo your homepage.
