Thanks, will give them all a try.
Douglas M. Payne
Tatum Partners
480-614-4915 Office
480-236-4561 Mobile
480-614-4916 Fax
doug.payne@…
TATUM PARTNERS
computers.
-----Original Message-----
[mailto:sailordude@…]
Sent: Sunday, November 07, 2004
6:44 AM
To:
Re: Mull F28 Camberspar Not Clearing Mast When tacking
Camberspar
adjustment!
There are 4 reasons that I
can think of.
- forestay is too tight
- camberspar is too long
- camberspar has been
bent or other wise modified
- sail design.
The easiest way is to try
putting slack in the forestay. It should be loose and when the sail is
hoisted, should extend forward at the camberspar wheel.
If the sail tension
adjustments at the camberspar is not in one of the last two holes, the spar may
be too long.
When I took ownership of
my 32 and 36, the forestays on both were too tight and had this problem.
I adjusted slack into the forestays which solved that problem.
When I had a new sail
built for my 26, I discovered that the shape of my camberspar was
incorrect. So I replaced it. It comes overlength so one cuts it to
fit. I measure the length so that I could just barely get the pin the
second to last adjustment hole, leaving one more adjustment for stretch
over the life of the sail.
Remember, this is not a
“stayed” rig and the forestay is only there for the jib. It
should be loose enough so that when pushing on at shoulder height, could be
easily displaces up to about 5 in. on a F36. Most of the freedoms I have
been aboard have the forestay far too tight. Riggers tend to be form the
“stayed rig” mentality.
Also, as the main sheet is
tightened, tension on the forestay increases.
This is what worked for me
over 50,000 miles on 2 freedoms.
Brian
