Glad to find this group as a new 21 owner. I bought this boat and have
never owned a sailboat, but have had many powerboats and have been a
marine technician (fancy name for boat mechanic) for 35 yrs. I think I
got a good deal, but someone may tell me otherwise. I paid 1000. It
came with a main sail and 2 jib sails, a 15 Tohatsu, a MightyMite
motor, a trailer, solar panel, VHF, inverter system and I would guess
everything needed to sail it, as it was in the water till about August
last year. Bottom is a little rough, with slight barnacles and algae. I
believe a little scraping and a good pressure wash will clean it right
up. My intentions are to enjoy it for a while, then sell it.
My problem is I do not know the first thing about rigging or sailing
this vessel. So many lines, such little knowlege! I have been to Max’s
site and retrieved what documentation I found, but I just am not
familiar enough with all these sailing terms for all the rigging lines
etc. to make much sense of it all. Aside from trying to get the
previous owner to assist (he is moving soon and busy)this forum seems
my next best bet. Also I’m located near Gainesville FL, so I might be
interested in paying for some help if needed. Can anyone steer me in
the right direction for some direction?
Sounds like you got a great deal!
What is the boat’s name & hull#?
Does she have the gunsight mount?
Did she come with a spinnaker?
If not, fine - sail as a cat-sloop w/jib only.
Glad to find this group as a new 21 owner. I bought this boat and have never owned a sailboat, but have had many powerboats and have been a marine technician (fancy name for boat mechanic) for 35 yrs. I think I got a good deal, but someone may tell me otherwise. I paid 1000. It came with a main sail and 2 jib sails, a 15 Tohatsu, a MightyMite motor, a trailer, solar panel, VHF, inverter system and I would guess everything needed to sail it, as it was in the water till about August last year. Bottom is a little rough, with slight barnacles and algae. I believe a little scraping and a good pressure wash will clean it right up. My intentions are to enjoy it for a while, then sell it. My problem is I do not know the first thing about rigging or sailing this vessel. So many lines, such little knowlege! I have been to Max’s site and retrieved what documentation I found, but I just am not familiar enough with all these sailing terms for all the rigging lines etc. to make much sense of it all. Aside from trying to get the previous owner to assist (he is moving soon and busy)this forum seems my next best bet. Also I’m located near Gainesville FL, so I might be interested in paying for some help if needed. Can anyone steer me in the right direction for some direction?
Thanks for the response Sean.
Hull# si TSP21056M83F
Name: “chillin the Most” -I don’t like the name.
It does have the gunsight mount.
By looking at or unpacking the sails, how can I tell the difference
between a jib and spinnaker, -not on the water and mast lowered?
MessageSounds like you got a great deal!
have
a
think I
guess
August
algae. I
right
sailing
Max’s
lines
seems
be
in
— In freedom21@yahoogroups.com, Sean Mulligan <quadmulligan@…>
Boat’s name is “Chillin’ the most” (I don’t like it.)
Hull#: TSP21056M83F
Yes gunsight mount
I’m not sure how to tell difference (complete novice, but I’ll post
pix)
I could sure use some help, I’d love to try sailing her.
have
a
think I
guess
August
algae. I
right
sailing
Max’s
lines
seems
be
in
Spinnaker will be large, light, colorful and symmetrical measuring about 12’ across the foot between the 2 clews.
Jibs are white, triangular heavier material and have a tack, head and clew (where the sheets attach).
I suggest you do a little research online to learn basic sailing terminology.
Hang around boatyards, join a sailing club, ask lots of questions…you will learn!
Then you will have a lot of fun with this boat (though a 15 hp outboard is too heavy - get an 8hp!)
Thanks for the response Sean.Hull# si TSP21056M83FName: “chillin the Most” -I don’t like the name.It does have the gunsight mount.By looking at or unpacking the sails, how can I tell the difference between a jib and spinnaker, -not on the water and mast lowered? — In freedom21@yahoogroups.com, Sean Mulligan <quadmulligan@…> wrote:>> MessageSounds like you got a great deal! > What is the boat’s name & hull#?> Does she have the gunsight mount?> Did she come with a spinnaker?> If not, fine - sail as a cat-sloop w/jib only.> > Sean> > -----Original Message-----> From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of tjgator50> Sent: Friday, February 23, 2007 9:30 AM> To: freedom21@yahoogroups.com> Subject: [freedom21] New Freedom 21 owner, New to group> > > > Glad to find this group as a new 21 owner. I bought this boat and have > never owned a sailboat, but have had many powerboats and have been a > marine technician (fancy name for boat mechanic) for 35 yrs. I think I > got a good deal, but someone may tell me otherwise. I paid 1000. It > came with a main sail and 2 jib sails, a 15 Tohatsu, a MightyMite > motor, a trailer, solar panel, VHF, inverter system and I would guess > everything needed to sail it, as it was in the water till about August > last year. Bottom is a little rough, with slight barnacles and algae. I > believe a little scraping and a good pressure wash will clean it right > up. My intentions are to enjoy it for a while, then sell it. > My problem is I do not know the first thing about rigging or sailing > this vessel. So many lines, such little knowlege! I have been to Max’s > site and retrieved what documentation I found, but I just am not > familiar enough with all these sailing terms for all the rigging lines > etc. to make much sense of it all. Aside from trying to get the > previous owner to assist (he is moving soon and busy)this forum seems > my next best bet. Also I’m located near Gainesville FL, so I might be > interested in paying for some help if needed. Can anyone steer me in > the right direction for some direction?>
— In freedom21@yahoogroups.com, Sean Mulligan <quadmulligan@>
Hull#: TSP21056M83F
Yes gunsight mount
pix)
have
been
a
think I
It
guess
August
algae. I
right
sailing
Max’s
lines
seems
might
be
in
Posted by esx123 (scott_shuler@…>)
Go to http://www.freedom21.info./ and click on the Video link. Gary hoyt will show you how to REALLY sail the f21. Lots of great info there as well.tjgator50 <tomjefferson@…> wrote: — In freedom21@yahoogroups.com, Sean Mulligan <quadmulligan@…> wrote:Boat’s name is “Chillin’ the most” (I don’t like it.)Hull#: TSP21056M83FYes gunsight mountI’m not sure how to tell difference
(complete novice, but I’ll post pix)I could sure use some help, I’d love to try sailing her.>> MessageSounds like you got a great deal! > What is the boat’s name & hull#?> Does she have the gunsight mount?> Did she come with a spinnaker?> If not, fine - sail as a cat-sloop w/jib only.> > Sean> > -----Original Message-----> From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of tjgator50> Sent: Friday, February 23, 2007 9:30 AM> To: freedom21@yahoogroups.com> Subject: [freedom21] New Freedom 21 owner, New to group> > > > Glad to find this group as a new 21 owner. I bought this boat and have > never owned a sailboat, but have had many
lines > etc. to make much sense of it all. Aside from trying to get the > previous owner to assist (he is moving soon and busy)this forum seems > my next best bet. Also I’m located near Gainesville FL, so I might be > interested in paying for some help if needed. Can anyone steer me in > the right direction for some direction?>Laissez les bons temps rouler
Need Mail bonding?Go to the Yahoo! Mail Q&A for great tips from Yahoo! Answers users.
I agree with Sean. You might also try crewing during a race as this will give you immediate feedback as to any mistakes you might make.Sean Mulligan <quadmulligan@…> wrote: Spinnaker will be large, light, colorful and symmetrical measuring about 12’ across the foot between the 2 clews. Jibs are white, triangular heavier material and have a tack, head and clew (where the sheets
attach). I suggest you do a little research online to learn basic sailing terminology. Hang around boatyards, join a sailing club, ask lots of questions…you will learn! Then you will have a lot of fun with this boat (though a 15 hp outboard is too heavy - get an 8hp!) Sean -----Original Message-----From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of tjgator50Sent: Friday, February 23, 2007 1:12 PMTo: freedom21@yahoogroups.comSubject: [freedom21] Re: New Freedom 21 owner, New to group Thanks for the response Sean.Hull# si TSP21056M83FName: “chillin the Most” -I don’t like the name.It does have the gunsight mount.By looking at or unpacking the sails, how can I tell the difference between a jib and spinnaker, -not on the water and mast lowered? — In freedom21@yahoogroups.com, Sean Mulligan <quadmulligan@…> wrote:>> MessageSounds like you got a great deal! > What is the boat’s name & hull#?> Does she have the gunsight mount?> Did she come with a spinnaker?> If not, fine - sail as a cat-sloop w/jib only.> > Sean> > -----Original Message-----> From: freedom21@yahoogroups.com
algae. I > believe a little scraping and a good pressure wash will clean it right > up. My intentions are to enjoy it for a while, then sell it. > My problem is I do not know the first thing about rigging or sailing > this vessel. So many lines, such little knowlege! I have been to Max’s > site and retrieved what documentation I found, but I just am not > familiar enough with all these sailing terms for all the rigging lines > etc. to make much sense of it all. Aside from trying to get the > previous owner to assist (he is moving soon and busy)this forum seems > my next best bet. Also I’m located near Gainesville FL, so I might be > interested in paying for some help if needed. Can anyone steer me in > the right direction for some direction?> Laissez les bons temps rouler
Cheap Talk? Check out Yahoo! Messenger’s low PC-to-Phone call rates.
Tom, I have a 20 page set of factory setup instructions I will put together for you. Send me your mailing address and I will get it to you as soon as possible.Since you live in Florida you can sail all year.Us Northerners can only sit and wait for the spring thaw.You can send your address to me at biffsail@…tjgator50 <tomjefferson@…> wrote: Glad to find this group as a new 21 owner. I bought this boat and have never owned a sailboat,
I agree with Sean.These are not original sails.That doesn’t mean you can’t sail with them.I am using a jib from a lightning class sailboat and it works just fine.I think some of our members might have some used sails if you choose to change your sails. BiffSean Mulligan <quadmulligan@…> wrote: I don’t know…neither of those look like Freedom21 sails…See: http://www.seanmulligan.com/Stories/Emmylou_Labor_Day_06/target1.html shows Emmylou’s jib flying from the extended spar (which I like) Good idea for you to post more photos with details. Sean -----Original Message-----From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of tjgator50Sent: Friday, February 23, 2007 3:38 PMTo: freedom21@yahoogroups.comSubject: [freedom21] Re: New Freedom 21 owner, New to
group .
I am pleased to see the condition of your boat/trailer when you
consider what you paid. Make sure you post some pics of the
interior, too. You got a great deal. I got mine with a broken mast
and ended up having to buy a SECOND boat to complete the first one.
That being said, I have an “extra” boom and original mainsail. I’m
in D.C. but, would be able to save you a lot compared to a sail
maker/broker.
Biff
sails…See:
You can also check www.baconsails.com
To see what sails they have in stock. The last I checked, they had
one main ($750) and 2 spinnakers ($395 and $475) available.
Biff
sails…See:
Tom,
I’m south of you in St. Petersburg. My freedom is in the water and
being sailed weekly. You’re more than welcome to come down and take a
look at her and her rigging.
