"New" Freedom 35 owner
Posted by fairways31 (fairways31@…>)
Hello again to all. after a two year move to a J32 we are back to the
Freedom line. Having owned a Mull 28 and a 30 it feels like home.
couple of questions:
gell coat crazing on swiam platform common?
setting for autohelm 4000# wont hold a course and hunts back anf forth
macerator installation? anyone done one and could u provisde me tips /
photos cant figure out howi would even get at the holding tank.
Happy to be back.
TJ
S/V Morning Light
Posted by ptecca63 (paul.tecca@…>)
Hi TJ,
I am a new F35 owner as well. I have a '93 F35 and do have some
crazing on my swim platform, but not excessive.
The holding tank is accessed through the starboard cockpit lazerette.
In there you will find two vertically mounted plywood boards. There
are a couple of screws at the bottom of those boards. Unscrew those
and lift the boards out. You then crawl into the lazerette and can get
at the tank from there.
Regards,
Paul
Midnight Star
Posted by T (fairways31@…>)
Congraduations i hope u enjoy here as much as we have our other freedoms. most of the 35s i looked at have some crazing in that area and the j boat had less but was still there thanks for the tip. do u have a macerator pump?ptecca63 <paul.tecca@…> wrote: Hi TJ,I am a new F35 owner as well. I have a '93 F35 and do have some crazing on my swim platform, but not excessive.The holding tank is accessed through the starboard cockpit lazerette. In there you will
find two vertically mounted plywood boards. There are a couple of screws at the bottom of those boards. Unscrew those and lift the boards out. You then crawl into the lazerette and can get at the tank from there.Regards,PaulMidnight Star
Yahoo! oneSearch: Finally, mobile search that gives answers, not web links.
I installed a macerator pump on my F32 last year which was not a
difficult process. You’ll want to mount the pump as low as you can
and reasonably close to somewhere midpoint between the discharge
thru-hull and the tank. Pay attention to the amperage draw and size
your breaker accordingly. You’ll probably need a 20 amp breaker,
minimum. Make sure you purchase high quality tubing meant for the
purpose. Otherwise, you may get odor infiltration, and double clamp
all connections. You’ll find if you take your time, it will be a
fairly intuitive and simple process.
Good luck
TW
F32 Anoush Koon
Pemaquid, ME
Hi TJ,
Regards,
Paul
Midnight Star
<http://us.rd.yahoo.com/evt=48252/*http://mobile.yahoo.com/mobileweb/onesearch?\
refer=1ONXIC>mobile
Checked by AVG Free Edition.
Version: 7.5.488 / Virus Database: 269.13.39/1044 - Release Date:
10/2/2007 11:10 AM
Version: 7.5.488 / Virus Database: 269.13.39/1044 - Release Date: 10/2/2007
11:10 AM
Posted by Mark & Peg (lzranch@…>)
Here are our 4000 settings.Rudder gain=3Response=1Turn limit=20degRudder align.=0Off course alarm=20deg.Auto trim=1Drive type=2Lat=41Rudder dampening=1Cruise speed=5. Strange as it may sound you need to have the drive type set to hydraulic for it to handle the 35. MarkFreeRadicalHello again to all. after a two year move to a J32 we are back to the Freedom line. Having owned a Mull 28 and a 30 it feels like home.couple of questions:gell coat crazing on swiam platform common?setting for autohelm 4000# wont hold a course and hunts back anf forthmacerator installation? anyone done one and could u provisde me tips / photos cant figure out howi would even get at the holding tank.Happy to be back.TJS/V Morning Light
Posted by ron barr (rwhb@…>)
Regarding the autopilot- On our Hoyt F32 I’ve noticed a certain
amount of play when it is in use – a very short back & forth clicking motion
where the ring attached to the wheel engages with the drive spindle or whatever
it is called. Anyone have a similar experience?
Ron
Newport RI
Behalf Of Mark & Peg
Sent: Sunday, October 14, 2007 7:54 PM
Subject: Re: [FreedomOwnersGroup] “New” Freedom 35 owner
Rudder gain=3
Response=1
Turn limit=20deg
Rudder align.=0
Auto trim=1
Drive type=2
Lat=41
Rudder dampening=1
Cruise speed=5.
Mark
FreeRadical
Hello again
feels like home.
holding tank.
Happy to be back.
TJ
S/V Morning Light
