Good to know. I’d imagine even though not solid glass its still a pretty solid location given the hull thickness on both sides.
I’ll put it on my list.
Alan
Sent: Thursday, December 08, 2005 11:28 AM
Subject: Re: [freedomyachts2003] new question for open discussion
Yes, Allen, that is exactly the three bolts I am talking about. I , too, had always assume that these bolts went through solid glass, all the way.
When I had to pull the “muffler” in order to replace the exhaust line, I had observed that this is not the case.
Alan Kusinitz <akusinitz@…> wrote:
On my F-33 there is a large metal backing plate if I remember correctly for the upper attachment. For the lower I had assumed it was solid where the 3 bolts go through from one side to the other. I don’t recall ever seeing it from th inside. Is that what you are referring to?
Alan
Sent: Wednesday, December 07, 2005 9:33 AM
Just last March I pulled my rudder to replace the bushings of the gudgeons (hey, I dont have spell rite, here !) I was astounded to find that the bolts holding the lower gudgeon to the hull , have no backing , with other words, they penetrate the hull, down at the very heel of it, and exit the skin on the other side… with no backing plates reinforcing the holes. I thought that a severe blow to the rudder, (such as falling off a wave while at extreme heel) might rip that fitting right out of there. A lesser blow still might induce leakage which would be impossible to locate, let alone fix, while under way.
I went and poured a mix of epoxy and glass fiber down the inside , after re bolting the gudgeon, so that now these bolts are in solid matter all the way across.
Lot’s of stern hung rudders have been used on many off-shore voyages including in heavy weather. Some have been mentioned on this board from time to time.
I’ve been in some pretty severe weather in the Atlantic in my previous Bristol 32 sloop (modified full keel, keel hung rudder) and believe the F-33 arrangement to be much stronger then on the bristol in several ways. People used to think spade rudders weren’t strong enough but its all a matter of construction details/strength. My 2 cents.
Alan F33 Hull #51
Sent: Wednesday, December 07, 2005 7:55 AM
Subject: [freedomyachts2003] new question for open discussion
I was having a discussion about Bright Star with an old friend of mine, and we were essentially concurring that it’s a great rig - well balanced, sturdy build, well mannered in a sea… when he surprised me by saying, “still, I wouldn’t trust a stern-hung rudder for off-shore work.” I was a little surprised by that. I mean, granted - an event that could possibly shear off my rudder would also take the transom, but with the way the rudder abuts the keel, my feeling is if I lost the rudder, I’ve probably got bigger problems to worry about. Any thoughts on this?Lance
Yahoo! PersonalsLet fate take it’s course directly to your email.See who’s waiting for you Yahoo! Personals
Yahoo! ShoppingFind Great Deals on Holiday Gifts at Yahoo! Shopping
