We have a Freedom 30 in final prep for the trip south.
I will send notes to the group as I can and post some
pictures.
Fargo
F30#12 NARISA
— crwindy@… wrote:
What boat are you sailing from Ct. to the Bahamas?
Can you send a log to the BB?
Date: 2005/11/08 Tue AM 09:07:23 EST
Subject: RE: [freedomyachts2003] Picture of the
sail lubricator made by mdurki
Second on the “want one”. Very nice. I leave
Connecticut on Friday for the Bahamas…so will have
to improvise quickly. Might tie on two sail slides (to
belt and shoe laces) and have my wife run me up and
down the mast.
Fargo
F30#12 NARISA
— “Payne, Doug” <doug.payne@…>
So when are you going into production, I want
one!!! I have seen a
lot of gadgets, this one is right up there for
usefulness.
Douglas M. Payne
Tatum Partners
480-614-4915 Office
480-236-4561 Mobile
480-614-4916 Fax
doug.payne@…
TATUM PARTNERS
Tatum CFO Partners, LLP - Tatum CIO Partners, LLP
www.tatumpartners.com
<file:///C:/Documents%20and%20Settings/Douglas%20Payne/Application%20Dat
a/Microsoft/Signatures/www.tatumpartners.com>
This electronic message is intended for the person
or entity to which it
is addressed and may contain confidential and/or
privileged information.
Any review, dissemination, copying, printing, or
other use of this
electronic message by persons or entities other than
the addressee is
prohibited. If you received this electronic message
in error, please
contact the sender immediately and delete the
electronic message from
any and all computers.
[mailto:freedomyachts2003@yahoogroups.com] On Behalf
Of Bob Tuttle
Sent: Monday, November 07, 2005 3:43 PM
Subject: [freedomyachts2003] Picture of the sail
lubricator made by
mdurki
Go to this ftp site and see the photo.
copy and paste in your browser
http://home.earthlink.net/~tuttlejr24/images/Sail%20track%
The instructions by Jim vaughn are as follows;
I made a very simple device for lubricating my sail
track that can be
used without removing the sails from the track. The
picture is
attached.
I used 1/8" stainless wire that I purchased from a
local hardware
store,
and I used locking nuts, which was probably
unnecessary. You will note
that there are two lines leading downward, one I use
to pull the
device
down and the other to pull the lever that actuates
the spray. At
first I
used only the latter, but I found that it used much
more spray than
was
needed, and I worried that should it come off I
would be stuck with my
halyard up the mast. I then added the pull down line
that you see
attached to the eye at the bottom of the device.
Just to be safe, I
run
the bitter end up to the halyard and secure it
there. There is copper
tubing that separates and spaces the top of the
holder proper from the
activator of the spray.
The sail slides are standard stuff that have been
cut away so that
they
will fit into the track from a horizontal position
and then twisted to
the vertical. The lower arrangement is a little
different. After the
upper one is inserted, obviously the device cannot
be turned to the
horizontal for the lower track. In that case I turn
the eye screw so
that the slide is horizontal though the device
remains vertical; once
the slide is inserted the eye is turned and the
device is then
properly
oriented. (I probably should have used screw eyes
top and bottom.)
Finally, the spray tube is cut so that it fits into
the track,
insuring that the Sailkote does not spray into the
air.
I have used this twice a year for several years with
no difficulty,
though I do find that on windy days it is harder to
keep the can
oriented properly. Incidentally, using the thing
that often also makes
the sail drop much more efficiently.
YAHOO! GROUPS LINKS
http://groups.yahoo.com/group/freedomyachts2003 "
on the web.
email to:
<mailto:freedomyachts2003-unsubscribe@yahoogroups.com?subject=Unsubscrib
e>
Yahoo! Terms of
Service http://docs.yahoo.com/info/terms/ .
