— In freedomyachts2003@yahoogroups.com, “rick_simonds”
<rick_simonds@y…> wrote:
“…Check out the Flagship Marine website for A/C that ISN’T
reverse
cycle…”
One “nay” vote for Flagship Marine here. I have a 16,000 BTU unit
in
my 32 and I’m disappointed with the A/C performance. 16k should be
plenty but mine doesn’t come close to keeping up with the
Tallahassee
summertime heat. Without question it’s nothin’ but HOT here, in
90’s from 10 AM to 6 PM every single day from June 1st to October
1st, but I’m getting A/C performance more like a 10,000 BTU unit.
It
can’t keep up. I should be doing much better than I am.
It’s hot here too!! (Corpus Christi, TX) See below
I’m completely outside my knowledge base about A/C but I’ve had
people look at it and I’ve tried whatever seemed reasonable. I’ve
talked to the Flagship guys repeatedly and they only say if
there’s a
15 degree difference between the temperature of the air going into
the unit and the air coming out, it works as far as they’re
concerned. There is that much difference with mine but I’m not
getting cool. Others with bigger boats and 16k units are walking
around in sweaters.
I would think you ought to be able to cool a 32 with 16k. One of the
things that will make this NOT work is supply vent location. If too
much air is being dumped too close to the unit, you’ll re-cool the
same air over and over and the “nether regions” will never cool
down. Also, make sure you aren’t cooling the bilge by drawing any
return air from it. Light up a cigar with the boat closed up and the
a/c on…you’ll learn a LOT about how the air flows and where.
You didn’t say how old the boat is, but I’ve done the following to
mine and been able to cool it to a bearable temp with a 6000 btu
window unit hanging in the companionway (additional circulation from
interior fans to get the cool air forward).
I bought two of those “patio misters” from Home Depot (they were $17
each last year, about double that now). These are hoses with
compression fittings and tiny nozzles that put out an ultra-fine
mist. Hooked to a garden hose and stretched the length of the
foredeck. Close the valve enough that ALL the water that is emitted
during the day evaporates. This will keep the deck a LOT cooler. I
also blocked off the two deck hatches from inside with pieces of
foil faced bubble pack. This cuts down a tremendous amount of heat
gain, as I have no external hatch canvas. One of these days I’ll get
around to insulating the rear bulkhead between the lazarettes and
the aft cabin with the same stuff. Meanwhile, I blocked off the
engine air supply that pulls air from the aft cabin into the engine
compartment. My headliner’s getting tired. When I replace it, I’ll
insulate the inner side of the deck in the living areas with the
same foil faced bubble pack.
If you want to “figure further” on what might be wrong with your
installation…check the cfm on your fan versus some of the ones on
other installations that “work”. If you can “catch” the owner when
he’s doing a startup from a hot cabin, measure the return air temp
and the cooled air at the supply grill. If it’s close to what you
have, then his unit wouldn’t do any better in your boat and the
problem lies in the air flow design or the heat gain or the air
infiltration from somewhere.
The resistance heat in a Flagship unit is a bit different, too.
The
air coming out isn’t hot, it’s warm. That’s OK, it ultimately
heats
up the boat, but it does so slowly and you can’t huddle by a vent
when you get back to the dock and you’re freezing your a__ off.
Again, the heat works, but slowly.
If you have propane, get a couple of clay flower pots and put them
upside down on the stove burners for “immediate warmth”…do NOT go
to sleep with the stove burning!! If you don’t have propane, get one
of those $15 ceramic heaters from Wal-Mart to give yourself a “hot
spot”
I thought I did my homework on this purchase and Flagship does
have
some nice features: it’s mostly stainless, it’s quiet, resistance
heat is simpler, it uses a standard thermostat, etc. I also
thought I
was buying a unit of more than ample size but if you work through
numbers at the Flagship website they seem to be recommending much
larger capacity than any other manufacturer. I didn’t really
directly
compare this until mine was already bought and installed.
My flush deck hull (and all others) put most btu calculations on
the “light” side for cooling, methinks! No “shady side” on the
raised cabintop, you know? All that freeboard…it’s like the whole
boat should be calculated as if you were cooling a pilothouse!
I haven’t found another owner of a Flagship unit to compare notes
with but, so far, put this Flagship Marine owner in the “nay”
column.
