I took apart my booms and found not only nests and other junk but tangled lines and blocks needing replacement. I changed the lines and the block arrangements in some cases amd most of the friction is gone. In addition I taped over the ends of my booms (ISOMATS with open ends) but left a few drain holes and figure this will prevent wildlife in the booms going forward.
Alan F-33 Hull #51 1982
Sent: Friday, August 26, 2005 9:42 AM
Subject: RE: [freedomyachts2003] Re Adding an autopilot on a F-21
I don’t know whether the reefing lines are rigged the same on the F21 as on my F30, but I had similar problems with my reefing lines until I discovered just how much junk can accumulate in a hollow boom. I pulled the lines out the aft end as far as they’d go and cleaned out all manner of junk, including birds nests. Then I put a hose in as far as it would go and and shot water through until it no longer ran out brown (helps to have the boom amidships at this point). I also changed the reefing blocks at the base of the mast. Problem solved.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of bill weberSent: Friday, August 26, 2005 7:19 AMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] Re Adding an autopilot on a F-21Did you mount the cup on the seat? If so how did youcompensate for the lip on the seat? Also do you havethe reefing lines hooked up. I have a real problemraising the main. I have to keep pulling out thereefing lines out aft end of the boom to get the mainup. — Nick Marino <blueraven1@…> wrote:> Bill,> I have an Autohelm 1000 which I use when raising or> lowering my main > when I singlehand. I also do singlehand cruising> and use it a lot. > To avoid current drain on stand-by, I have a ON/OFF> switch in the > cockpit. > Nick,> Blue Raven> F-21, #295> > > > ____________________________________________________Start your day with Yahoo! - make it your home page http://www.yahoo.com/r/hs
