Re: F32 Hoyt Portlights
Car wax and a buffer works ok.
I am going to replace mine this summer. Mine are starting to crack and when I pried one off it was a bit brittle.
Scott
Girlfriend
f-32 Hoyt
See what’s free at AOL.com.
Posted by Kevin Taylor (kevin683@…>)
Hi All,Any tips out there for polishing out the scratches in the black portlights on the F32 Hoyt? Mine are leak free but they look pretty bad.Thx,–KevinS/V Sway
Hi Kevin,
I purchased a product called Novus which is a polishing compound
specifically engineered to remove scratches from plastic. I, too, have a
Hoyt 32 which had the same problem. Novus comes in 3 versions, 1, 2 and
3. Novus 1 is a cleaner, 2 and 3 are polishing compounds, 2 for fine
scratches and 3 for heavier ones. You apply it as you would your one step
hull cleaner, rubbing in circles and letting it dry. Then wipe away with a
clean cloth. I did my hatch covers, port lights, weather board and the
plastic on my dodger. It works great. Bear in mind this plastic is over
20 years old, so it won’t look brand new, but I found it to be a great
improvement.
I got my supply at a local plastic supply house. You can google
Novus to find the website and perhaps find a distributor nearby.
Good Luck.
TW F32 #20 Anoush Koon, Pemaquid, ME
At 07:03 AM 4/11/2007 -0500, you wrote:
Hi All,
Thx,
–Kevin
S/V Sway
Checked by AVG Free Edition.
Version: 7.5.446 / Virus Database: 269.2.0/756 - Release Date: 4/10/2007
10:44 PM
Attachment: (application/octet-stream) 1506b0.jpg [not stored]
Attachment: (application/octet-stream) 1506fe.jpg [not stored]
Attachment: None [not stored]
Version: 7.5.446 / Virus Database: 269.2.0/756 - Release Date: 4/10/2007 10:44
PM
Thanks, guys. I will check out Novus.
–Kevin
S/V SwayOn 4/11/07, Thomas Wales <twales@…> wrote:
Hi Kevin, I purchased a product called Novus which is a polishing compoundspecifically engineered to remove scratches from plastic. I, too, have aHoyt 32 which had the same problem. Novus comes in 3 versions, 1, 2 and
3. Novus 1 is a cleaner, 2 and 3 are polishing compounds, 2 for finescratches and 3 for heavier ones. You apply it as you would your one stephull cleaner, rubbing in circles and letting it dry. Then wipe away with a
clean cloth. I did my hatch covers, port lights, weather board and theplastic on my dodger. It works great. Bear in mind this plastic is over20 years old, so it won’t look brand new, but I found it to be a great
improvement. I got my supply at a local plastic supply house. You can googleNovus to find the website and perhaps find a distributor nearby. Good Luck. TW F32 #20 Anoush Koon, Pemaquid, ME
At 07:03 AM 4/11/2007 -0500, you wrote:>Hi All,>>Any tips out there for polishing out the scratches in the black portlights>on the F32 Hoyt? Mine are leak free but they look pretty bad.
Thx,>–Kevin>S/V Sway>>>No virus found in this incoming message.>Checked by AVG Free Edition.>Version: 7.5.446 / Virus Database: 269.2.0/756 - Release Date: 4/10/2007
10:44 PMNo virus found in this outgoing message.Checked by AVG Free Edition.Version: 7.5.446 / Virus Database: 269.2.0/756 - Release Date: 4/10/2007 10:44 PM
I’ve used the stuff from auto parts
places for cleaning vinyl convertible rear windows. Usually their two
containers, one cleaner and one polish. Worked great on my ports.
Alan F33 Hull #51 1982 SEAPR
freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Kevin Taylor
Sent: Thursday, April 12, 2007
12:45 PM
To:
F32 Hoyt Portlights
–Kevin
S/V Sway
On 4/11/07, Thomas
Wales <twales@adelphia.net>
Hi Kevin,
have a
step
with a
plastic is over
improvement.
Good Luck.
Hi All,
Thx,
–Kevin
S/V Sway
10:44 PM
PM
I just finished replacing all the portlights on my H32. If your present ones are Lexan (poly carb’) they really don’t clean-up very well. It’s not really to bad a job unless, of course, some PO bedded them with 5200, then I pity you. PWMKevin Taylor <kevin683@…> wrote: Hi All,Any tips out there for polishing out the scratches in the black portlights on the F32 Hoyt? Mine are leak free but they look pretty bad.Thx,–KevinS/V
Sway
Ahhh…imagining that irresistible “new car” smell? Check out
new cars at Yahoo! Autos.
Hi Paul, Haven’t seen your name in a long time!!! What did you replace your portlights with? Sward Paul McFadden <pwhitmac@…> wrote: I just finished replacing all the portlights on my H32. If your present ones are Lexan (poly carb’) they really don’t
clean-up very well. It’s not really to bad a job unless, of course, some PO bedded them with 5200, then I pity you. PWMKevin Taylor <kevin683@gmail.com> wrote: Hi All,Any tips out there for polishing out the scratches in the black portlights on the F32 Hoyt? Mine are leak free but they look pretty bad.Thx,–KevinS/V Sway Ahhh…imagining that irresistible “new car” smell?Check out new cars at Yahoo! Autos.
Posted by Bernard (lousleech@…>)
I used Brasso (brass polish) It works great.
Bernard F-36 “Simple Pleasures”
— In freedomyachts2003@yahoogroups.com, “Alan Kusinitz”
<akusinitz@…> wrote:
I’ve used the stuff from auto parts places for cleaning vinyl
convertible
rear windows. Usually their two containers, one cleaner and one
polish.
Sent: Thursday, April 12, 2007 12:45 PM
Subject: Re: [freedomyachts2003] F32 Hoyt Portlights
–Kevin
S/V Sway
On 4/11/07, Thomas Wales <twales@adelphia. mailto:twales@... net>
Hi Kevin,
compound
have a
2 and
fine
one step
away with a
is over
great
improvement.
google
Good Luck.
Hi All,
portlights
Thx,
–Kevin
S/V Sway
4/10/2007
10:44 PM
4/10/2007
10:44 PM
Tooth Paste - if you are on a budget. It works.
