Re: F35
Posted by asilverman@… (asilverman@…)
I am looking very closely at an F35 that is for sale. Are there any F35 owners out there who have not listed their boats but are interested in selling.
Requirements: Shoal draft; excellent condition; electric winch
Alan Silverman
Posted by Fred Molden (fredmolden@…>)
I have a 1996 F35 and am thinking of doing the ICW next year. I am considering changing my folding two blade prop to a three blade Max Prop. Is anyone currently using a three blade and is there a significant improvement over the two blade prop? What sort of speed/RPM do you get and would a 3/4 - 1 1/8 shaft taper fit the F35? Thanks for any help.
Fred
sv VOLANT
Posted by Jeff Chale (jwchale@…>)
The three-blade will give you better performance into a chop. If you call PYI directly, simply tell them the shaft diameter and I am sure you have a standard taper. They will know what prop size/pitch for the 35 with a 3GM30F will be. Jeff Fred Molden <fredmolden@…> wrote: I have a 1996 F35 and am thinking of doing the ICW next year. I am considering changing my folding two blade prop to a three blade Max Prop. Is
anyone currently using a three blade and is there a significant improvement over the two blade prop? What sort of speed/RPM do you get and would a 3/4 - 1 1/8 shaft taper fit the F35? Thanks for any help. Fred sv VOLANT
Low, Low, Low Rates! Check out Yahoo! Messenger’s cheap PC-to-Phone call rates.
Thanks Jeff…I am a novie and don;t know your terms: Who is PYI ?, How do I contact? What is 3GM30F Please explain. I am cosidering buying the Freedom 35. Do you like yours? What do you find great about yours, and what are some faults? The modified keel I am considering is where they cut off part of keel, and add a shorter lead one. I will try to send pictures of what I saw a boat yard doing…understand, this is not the boat I am considering. Thank you for your response. LolaJeff Chale <jwchale@…> wrote: The three-blade will give you better performance into a chop. If you call PYI directly, simply tell them the shaft diameter and I am sure you have a standard taper. They will know what prop size/pitch for the 35 with a 3GM30F will be. Jeff Fred Molden <fredmolden@comcast.net> wrote: I have a 1996 F35 and am thinking of doing the ICW next year. I am considering changing my folding two blade prop to a three blade Max Prop. Is anyone currently using a three blade and is there a significant improvement over the two
blade prop? What sort of speed/RPM do you get and would a 3/4 - 1 1/8 shaft taper fit the F35? Thanks for any help. Fred sv VOLANT Low, Low, Low Rates! Check out Yahoo! Messenger’s cheap PC-to-Phone call rates.
Turns out I can;t seem to attach the 2 photos.SorryLola Jackson <lolaltd@…> wrote: Thanks Jeff…I am a novie and don;t know your terms: Who is PYI ?, How do I contact? What is 3GM30F Please explain. I am cosidering buying the Freedom 35. Do you like yours? What do you find great about yours, and what are some faults? The modified keel I am considering is where they cut off
part of keel, and add a shorter lead one. I will try to send pictures of what I saw a boat yard doing…understand, this is not the boat I am considering. Thank you for your response. LolaJeff Chale <jwchale@yahoo.com> wrote: The three-blade will give you better performance into a chop. If you call PYI directly, simply tell them the shaft diameter and I am sure you have a standard taper. They will know what prop size/pitch for the 35 with a 3GM30F will be. Jeff Fred Molden <fredmolden@comcast.net> wrote: I have a 1996 F35
and am thinking of doing the ICW next year. I am considering changing my folding two blade prop to a three blade Max Prop. Is anyone currently using a three blade and is there a significant improvement over the two blade prop? What sort of speed/RPM do you get and would a 3/4 - 1 1/8 shaft taper fit the F35? Thanks for any help. Fred sv VOLANT Low, Low, Low Rates! Check out Yahoo! Messenger’s cheap PC-to-Phone call rates. Low, Low, Low Rates! Check out Yahoo! Messenger’s cheap PC-to-Phone call rates.
Check out the New Yahoo! Mail - Fire up a more powerful email and get things done faster.
I have a 3 blade Vari-prop taken off a F 33 ,I inch shaft,SAE taper,with accessories,that I’d like to sell. If interested,emailme @ zayde@… It was used for 30 hrs. Includes spares,2 zincs,special grease,and prop puller
Sent: Sunday, October 29, 2006 6:00 PM
Subject: [freedomyachts2003] F35
Fred
sv VOLANT
I have a variprop on my f-33 and am very
happy with it. It’s a custom size.
Curious why you took yours off?
ALan
is intended only for the personal and confidential use of the recipient(s) named
above and may be subject to attorney client privilege if so marked. If the
reader of this message is not the intended recipient or an agent responsible
for delivering it to the intended recipient, you are hereby notified that you
have received this document in error and that any review, dissemination,
distribution, or copying of this message is strictly prohibited. If you have
received this communication in error, please notify us immediately by e-mail,
and delete the original message.
freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of jerry weinraub
Sent: Monday, October 30, 2006
8:50 AM
To:
F35
interested,emailme @ zayde@optonline.net.
29, 2006 6:00 PM
Subject:
any help.
Fred
sv VOLANT
3 blade whether fixed or feathering can be set up for a little more speed in forward ( less prop. slip due to more blade area ) and also a LOT more reverse. Necessary when you will go aground. If you cruise ,you go aground. With a three blade you have a chance to back off, with a folder forget it. Do get unlimited towing ins.for the ditch. Those that tell the truth all say they went aground coming down the ICW.Jeff Chale <jwchale@…> wrote: The three-blade will give you better performance into a chop.
If you call PYI directly, simply tell them the shaft diameter and I am sure you have a standard taper. They will know what prop size/pitch for the 35 with a 3GM30F will be. Jeff Fred Molden <fredmolden@comcast.net> wrote: I have a 1996 F35 and am thinking of doing the ICW next year. I am considering changing my folding two blade prop to a three blade Max Prop. Is anyone currently using a three blade and is there a significant improvement over the two blade prop? What sort of speed/RPM do you get and would a 3/4 - 1 1/8 shaft taper fit the F35? Thanks for any help. Fred sv VOLANT Low, Low, Low Rates! Check out Yahoo! Messenger’s cheap PC-to-Phone call rates.
The best gets better. See why everyone is raving about the All-new Yahoo! Mail.
Hi Lola, PYI imports the Max Prop to the US from Italy. You can find them on the web at http://www.pyiinc.com/. They are very friendly to talk with and very helpful. The 3GM30F is your Yanmar 27hp engine. JeffLola Jackson <lolaltd@…> wrote: Turns out I can;t seem to attach the 2 photos.SorryLola Jackson <lolaltd@yahoo.com> wrote: Thanks Jeff…I am a novie and don;t know your terms: Who is PYI ?, How do I contact? What is 3GM30F Please explain. I am cosidering buying the Freedom 35. Do you like yours? What do you find great about yours, and what are some faults? The modified keel I am considering is where they cut off part of keel, and add a shorter lead one. I will try to send pictures of what I saw a boat yard doing…understand, this is not the boat I am considering. Thank you for your response. LolaJeff Chale <jwchale@yahoo.com> wrote: The three-blade will give you better performance into a chop. If you call PYI directly, simply tell them the shaft diameter and I am sure you have a standard taper. They will know what prop size/pitch for the 35 with a 3GM30F will be. Jeff Fred Molden <fredmolden@comcast.net> wrote: I have a 1996 F35 and am thinking of doing the ICW next year. I am considering changing my folding two blade prop to a three blade Max Prop. Is anyone currently using a three blade and is there a significant improvement over the two blade prop? What sort of speed/RPM do you get and would a 3/4 - 1 1/8 shaft taper fit the F35? Thanks for any help. Fred sv VOLANT Low, Low, Low Rates! Check out Yahoo! Messenger’s cheap PC-to-Phone call rates. Low, Low, Low Rates! Check out Yahoo! Messenger’s cheap PC-to-Phone call rates. Check out the New Yahoo! Mail - Fire up a more powerful email and get things done faster.
Want to start your own business? Learn how on Yahoo! Small Business.
