Photos of the UK F-21 cockpit showed at least four line hangers on
each side of the companionway to hang halyards, traveler lines and
spinnaker lines. They were Ronstan Line Hangers with shock cords
(see bottom of 2004 West Marine Catalog page 728) and were mounted
vertically on the curved comming.
On my F-21 I have mounted 5 Beneteau Buttons P/S (mounted
horizontally on top of the coming) on each side of the companionway
to hang halyards, traveler lines and spinnaker lines
This helps in keeping an organized cockpit underway or at rest.
Those clips and shockcord attach to the outside bulkhead. At one
time they were shown on the UK page for Freedom 21’s but I don’t
believe that it is active any longer. If the clips were inside
cabin there would be a problem with the lines going through the
companionway plus there would be no reason to mount them there.
I also mounted a track P & S for some Harken blocks for the sheets
for the jib. They also had cam cleats on them which made it quite
handy for trimming.
May I ask exactly where you attached the shock cord and plastic
hooks to hold the lines? Are they inside the cabin or inside the
cockpit? It sounds like a good idea, but lots of the boats around
me
have nylon bags (the J-24s) on either side of the passageway. Most
of
these bags look custom made–at least I can’t find any
commercially.
They have stainless steel snaps which attach the bags to the boat,
plus shock cords to draw the opening tight.
Sent: Saturday, September 04, 2004 5:40 PM
Subject: [freedomyachts2003] Re: Freedom 21 tip
The scupper check valve does not go inside the hole. They are
mounted on the stern over the 2 openings. It is best to do it
out of
the water if possible. I installed them in the water and
dropped
one
of the rubber valves but Atwood sent me another. You have to
drill
several holes for the screws so you don’t want to use a corded
drill
when you are wet. They really do the job.
I also copied a tip from the English F-21’s by attaching most
of
loose lines to the bulkhead using a shock cord and a plastic
hook.
These can be found at most marine chandleries. Cleans up the
cockpit.
Hi Bob, and thank you for the scupper tip. Did you have to
make
any
adaptations, or did they just fit into the drain holes?
(with
some
sealer?). Thank you again for this tip, and any other F 21
tips
advice you can give to us. Charlie on Mobile Bay, AL
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms
Thank you for the reply. Could you tell me what a Beneteau Button is, please?
F-21 #102
Sent: Sunday, September 12, 2004 7:26 PM
Subject: [freedomyachts2003] Re: Freedom 21 Tip - UK Freedom 21 Cockpit Halyard Hangers
UK Freedom 21 Cockpit Halyard Hangers:Photos of the UK F-21 cockpit showed at least four line hangers on each side of the companionway to hang halyards, traveler lines and spinnaker lines. They were Ronstan Line Hangers with shock cords (see bottom of 2004 West Marine Catalog page 728) and were mounted vertically on the curved comming.On my F-21 I have mounted 5 Beneteau Buttons P/S (mounted horizontally on top of the coming) on each side of the companionway to hang halyards, traveler lines and spinnaker lines This helps in keeping an organized cockpit underway or at rest.Blue RavenF-21 #295— In freedomyachts2003@yahoogroups.com, “Bob Tuttle” <2rats@e…> wrote:> Those clips and shockcord attach to the outside bulkhead. At one > time they were shown on the UK page for Freedom 21’s but I don’t > believe that it is active any longer. If the clips were inside the > cabin there would be a problem with the lines going through the > companionway plus there would be no reason to mount them there.> > I also mounted a track P & S for some Harken blocks for the sheets > for the jib. They also had cam cleats on them which made it quite > handy for trimming.> > > > > — In freedomyachts2003@yahoogroups.com, “Allen McClung” > <amcclung@f…> wrote:> > May I ask exactly where you attached the shock cord and plastic > hooks to hold the lines? Are they inside the cabin or inside the > cockpit? It sounds like a good idea, but lots of the boats around me > have nylon bags (the J-24s) on either side of the passageway. Most of > these bags look custom made–at least I can’t find any commercially. > They have stainless steel snaps which attach the bags to the boat, > plus shock cords to draw the opening tight.> > > > > > ----- Original Message ----- > > From: tuttlejr > > To: freedomyachts2003@yahoogroups.com > > Sent: Saturday, September 04, 2004 5:40 PM> > Subject: [freedomyachts2003] Re: Freedom 21 tip> > > > > > The scupper check valve does not go inside the hole. They are > > mounted on the stern over the 2 openings. It is best to do it > out of > > the water if possible. I installed them in the water and dropped > one > > of the rubber valves but Atwood sent me another. You have to > drill > > several holes for the screws so you don’t want to use a corded > drill > > when you are wet. They really do the job.> > > > I also copied a tip from the English F-21’s by attaching most of > the > > loose lines to the bulkhead using a shock cord and a plastic > hook. > > These can be found at most marine chandleries. Cleans up the > cockpit.> > > > I miss my Freedom 21.> > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “Charlie L.” > > <clivaday@y…> wrote:> > > Hi Bob, and thank you for the scupper tip. Did you have to make > any > > > adaptations, or did they just fit into the drain holes? (with > some > > > sealer?). Thank you again for this tip, and any other F 21 tips > and > > > advice you can give to us. Charlie on Mobile Bay, AL> > > > > > — In freedomyachts2003@yahoogroups.com, “tuttlejr” > <2rats@e…> > > > > > > > > Yahoo! Groups Sponsor > > ADVERTISEMENT> > > > > > > > > > > > --------------------------------------------------------------------> ----------> > Yahoo! Groups Links> > > > a… To visit your group on the web, go to:> > http://groups.yahoo.com/group/freedomyachts2003/> > > > b… To unsubscribe from this group, send an email to:> > freedomyachts2003-unsubscribe@yahoogroups.com> > > > c… Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service.
Beneteau Sailboat Company installs their own line hangers on their
boats. They are 1/3 of a metal sphere with a slot in back to hook a
line which goes around the line you want to hang. Even though it is
a simple design - not easy to describe. Find a Beneteau Dealer to
see one.
is, please?
F-21 #102
on
cords
mounted
companionway
one
don’t
inside
sheets
quite
handy for trimming.
plastic
around
me
Most
of
commercially.
boat,
are
do it
out of
dropped
one
to
drill
corded
drill
most
of
plastic
hook.
cockpit.
to
make
any
(with
some
21
tips
Terms
of
Service.
ADVERTISEMENT
Yahoo! Groups Links
Thanks again. There’s a Beneteau on the lake where I sail. I’ll take a look at his boat this week. Thanks again.
Sent: Monday, September 13, 2004 1:57 AM
Beneteau Sailboat Company installs their own line hangers on their boats. They are 1/3 of a metal sphere with a slot in back to hook a line which goes around the line you want to hang. Even though it is a simple design - not easy to describe. Find a Beneteau Dealer to see one.Blue RavenF-21, #295— In freedomyachts2003@yahoogroups.com, “Allen McClung” <amcclung@f…> wrote:> Thank you for the reply. Could you tell me what a Beneteau Button is, please?> > F-21 #102> ----- Original Message ----- > From: Nick > To: freedomyachts2003@yahoogroups.com > Sent: Sunday, September 12, 2004 7:26 PM> Subject: [freedomyachts2003] Re: Freedom 21 Tip - UK Freedom 21 Cockpit Halyard Hangers> > > UK Freedom 21 Cockpit Halyard Hangers:> > Photos of the UK F-21 cockpit showed at least four line hangers on > each side of the companionway to hang halyards, traveler lines and > spinnaker lines. They were Ronstan Line Hangers with shock cords > (see bottom of 2004 West Marine Catalog page 728) and were mounted > vertically on the curved comming.> > On my F-21 I have mounted 5 Beneteau Buttons P/S (mounted > horizontally on top of the coming) on each side of the companionway > to hang halyards, traveler lines and spinnaker lines > > This helps in keeping an organized cockpit underway or at rest.> > Blue Raven> F-21 #295> > > — In freedomyachts2003@yahoogroups.com, “Bob Tuttle” <2rats@e…> > wrote:> > Those clips and shockcord attach to the outside bulkhead. At one > > time they were shown on the UK page for Freedom 21’s but I don’t > > believe that it is active any longer. If the clips were inside > the > > cabin there would be a problem with the lines going through the > > companionway plus there would be no reason to mount them there.> > > > I also mounted a track P & S for some Harken blocks for the sheets > > for the jib. They also had cam cleats on them which made it quite > > handy for trimming.> > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “Allen McClung” > > <amcclung@f…> wrote:> > > May I ask exactly where you attached the shock cord and plastic > > hooks to hold the lines? Are they inside the cabin or inside the > > cockpit? It sounds like a good idea, but lots of the boats around > me > > have nylon bags (the J-24s) on either side of the passageway. Most > of > > these bags look custom made–at least I can’t find any > commercially. > > They have stainless steel snaps which attach the bags to the boat, > > plus shock cords to draw the opening tight.> > > > > > > > > ----- Original Message ----- > > > From: tuttlejr > > > To: freedomyachts2003@yahoogroups.com > > > Sent: Saturday, September 04, 2004 5:40 PM> > > Subject: [freedomyachts2003] Re: Freedom 21 tip> > > > > > > > > The scupper check valve does not go inside the hole. They are > > > mounted on the stern over the 2 openings. It is best to do it > > out of > > > the water if possible. I installed them in the water and > dropped > > one > > > of the rubber valves but Atwood sent me another. You have to > > drill > > > several holes for the screws so you don’t want to use a corded > > drill > > > when you are wet. They really do the job.> > > > > > I also copied a tip from the English F-21’s by attaching most > of > > the > > > loose lines to the bulkhead using a shock cord and a plastic > > hook. > > > These can be found at most marine chandleries. Cleans up the > > cockpit.> > > > > > I miss my Freedom 21.> > > > > > > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “Charlie L.” > > > <clivaday@y…> wrote:> > > > Hi Bob, and thank you for the scupper tip. Did you have to > make > > any > > > > adaptations, or did they just fit into the drain holes? > (with > > some > > > > sealer?). Thank you again for this tip, and any other F 21 > tips > > and > > > > advice you can give to us. Charlie on Mobile Bay, AL> > > > > > > > — In freedomyachts2003@yahoogroups.com, “tuttlejr” > > <2rats@e…> > > > > > > > > > > > > Yahoo! Groups Sponsor > > > ADVERTISEMENT> > > > > > > > > > > > > > > > > > -----------------------------------------------------------------> —> > ----------> > > Yahoo! Groups Links> > > > > > a… To visit your group on the web, go to:> > > http://groups.yahoo.com/group/freedomyachts2003/> > > > > > b… To unsubscribe from this group, send an email to:> > > freedomyachts2003-unsubscribe@yahoogroups.com> > > > > > c… Your use of Yahoo! Groups is subject to the Yahoo! Terms > of > > Service.> > > Yahoo! Groups Sponsor > ADVERTISEMENT> > > > > > ------------------------------------------------------------------------------> Yahoo! Groups Links> > a… To visit your group on the web, go to:> http://groups.yahoo.com/group/freedomyachts2003/> > b… To unsubscribe from this group, send an email to:> freedomyachts2003-unsubscribe@yahoogroups.com> > c… Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
