Re: Freedom 35 ?
Posted by T (fairways31@…>)
anyone have a humming noice when sailing with a fixed 2 blade prop locked in reverse?Louis Spitz <aronella@…> wrote: ( I ,have #23 F35, bound for the bahamas). Chech that no metal around the fluxgate comp[ass. Mine went ‘loco’ until I discovered thre location of the fluxgate ( inside the aft bulkhead accessabler through the 2 small lazarette seats.) hI inadvertently stowed some anchors back there. Removing them
did the trick. Good luck. Lou ----- Original Message ----- From: fairways31 To: freedomyachts2003@yahoogroups.com Sent: Tuesday, October 02, 2007 11:46 AM Subject: [freedomyachts2003] new Freedom 35 owner Hello again to all. after a two year move to a J32 we are back to the Freedom line. Having owned a Mull 28 and a 30 it feels like home.couple of questions:gell coat crazing on swiam platform
common?setting for autohelm 4000# wont hold a course and hunts back anf forthmacerator installation? anyone done one and could u provisde me tips / photos cant figure out howi would even get at the holding tank.Happy to be back.TJS/V Morning Light No virus found in this incoming message.Checked by AVG Free Edition. Version: 7.5.488 / Virus Database: 269.13.39/1044 - Release Date: 10/2/2007 11:10 AM
Tonight’s top picks. What will you watch tonight? Preview the hottest shows on Yahoo! TV.
I’d check to make sure that when you’re locked in reverse, the shaft is
in fact not turning. If it’s not, then is this something that happens
every time, or is it intermittent? If it’s intermittent then maybe the
prop is going into an orientation that sets up a weird harmonic… or
maybe you’re just sailing too fast :wink:
Lance
locked in reverse?
thanks lance. it is intermittent and i think it has to do with where the prop has stoppedlance_ryley <lance_ryley@…> wrote: I’d check to make sure that when you’re locked in reverse, the shaft is in fact not turning. If it’s not, then is this something that happens every time, or is it intermittent? If it’s intermittent then maybe the prop is going into an orientation that sets up a weird harmonic… or maybe you’re just sailing too fast ;)Lance— In freedomyachts2003@yahoogroups.com, T <fairways31@…> wrote:>> anyone have a humming noice when sailing with a fixed 2 blade prop locked in reverse?
Catch up on fall’s hot new shows on Yahoo! TV. Watch previews, get listings, and more!
Once I had a humming noice that I thought
was due to addition of a windvane. Turned out to be too much slack in the
steering cables in the edson pedestal. I had rebuilt and replaced the pedestal
and cables and hadn’t put enough tension on them. So the rudder was
actually moving/vibrating back and forth somewhat under certain conditions.
freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of T
Sent: Tuesday, October 09, 2007
9:08 AM
To:
Freedom 35 ?
anyone
Louis Spitz
hI inadvertently stowed some anchors back there. Removing them did the trick.
Good luck.
Lou
02, 2007 11:46 AM
Subject:
it feels like home.
gell coat crazing on swiam platform common?
Happy to be back.
TJ
S/V Morning Light
size=2 width=“100%” align=center>
11:10 AM
