Posted by Scott Forgey (jsforgey@…>)
Great advice!!!
Scott Forgey
Creative Thinking Guru
21362 Summertrace Circle
Boca Raton, FL 33428
561.445.5179
skype: sforgey1
“My hovercraft is full of eels.”
M. Python
freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of rick_simonds
Sent: Saturday, December 22, 2007
9:31 PM
To:
Fuel Contamination
— In freedomyachts2003@yahoogroups.com,
“Michael Gillin”
<michael_w_gillin@…> wrote:
The Freedom 32 I recently purchased had no use last year.
I believe that algae built up in the fuel tank clogging primary and
Whatever fuel you have in there, just get rid of it. It’s not worth
risking $30 of fuel filters to attempt to save $30 worth of fuel.
About every other year I let the fuel level on my Hoyt 32 get as low
as I dare, perhaps a gallon or two. I just open up the inspection
port and pump that fuel out. (Most “Quicky Lube” places will take
your cruddy old fuel for free.) Pump it into jugs and just get rid
of it. Soak up the last few ounces with paper towels. Put the jugs in
a plastic trash bag while filling them and have another plastic trash
bag open and ready for the paper towels (diesel is terrible stuff
when it gets loose, it stinks for weeks.)
You can easily reach your arm through the inspection port and scrub
out the inside of the tank. Slosh in some “Fuel Dryer” (it’s at boat
stores. It smells suspiciously like rubbing alcohol) and go after the
inside surfaces with a plastic scrubby pad. You have to get into
different positions and maybe use either arm but once you get your
elbow into the tank it is possible to reach every surface. You can
shine a flashlight in there and see much of the tank but not all of
it. You’ll probably see a thin, black, stuck-on coating on most
surfaces. The fuel dryer and scrubby pad will quite easily get the
aluminum back to a bright shine.
Once you’ve got it scrubbed, wipe it down with a dab of fuel dryer on
a paper towel, then wipe all the tank surfaces with clean, dry paper
towels. Soak up the excess fuel dryer with paper towels. Everything
should get back to bright, shiney and dry when you’re done. Clean up
any mess and thoroughly wash your arms. Re-fill the tank with clean,
fresh fuel. Adding some stabilizer and/or algae killer is optional.
I do this every few years. The first time takes maybe 45 minutes. Any
time after that takes about 10 minutes, tops. It ends the fuel
problems.
Rick
Tallahassee
Checked by AVG Free Edition.
Version: 7.5.516 / Virus Database: 269.17.6/1192 - Release Date: 12/21/2007 1:17 PM
