The canal I was in connects the city of Goes in Zeeland to the
Oosterschelde, which is salt and tidal, and so is the canal. The
Oosterschelde has a world famous series of (some 22)concrete doors
across the mouth of the estuarium to close it at spring tides and
extreme westerlies. This is to prevent the disaster of February
1953, a spring tide combined with westerly winds, taking the lives
of 1800 persons and thousends of cattle. The whole province Zeeland
was flooded. So far the free Dutch history and geography lesson.
I’m going to check on the internal anode as soon as I’ve found and
reached it. My heat exchanger was nice and clean inside.
— In freedomyachts2003@yahoogroups.com, “geraldfreshwater”
<freshwater@…> wrote:
Sounds like Dutch freshwater is saltier than British freshwater,
too! Electolytic corrosion
requires an electrolyte as well as some dissimilar metals. Is
there anything left of your
engine’s internal anode?
I think you should go with Alan’s suggestion, and take up electric
boating whilst you are in
the canals!
Kind regards,
Gerald Freshwater
— In freedomyachts2003@yahoogroups.com, “webmaster” <akusinitz@>
Sounds like you could run some wires and use it as a battery.
Alan
[mailto:freedomyachts2003@yahoogroups.com] On Behalf Of
michel.capel
Sent: Sunday, November 26, 2006 3:36 PM
Subject: [freedomyachts2003] Re: Heavy electrolitic corrosion! -
Help needed
After reading about the subject of bonding, corrosion and zincs,
I
had a look at the situation today. The two magnesium anodes were
clean and pitted, the zincs were covered in white sodium-
something
and the antifouling paint had peeled off the stainless steel P-
strut. No stray currents but a textbook example of
overprotection by
too much zinc or worse, magnesium. I forgot that this boat has
lived
in the salty and warm waters of the Gulf and now moved to the
colder
and less salty waters of North Western Europe. I removed the
magnesiums and will replace them for one small zinc. I will also
remove one of the zincs on the propshaft and see if the balance
between kathode and anode is better.
— In freedomyachts2003@ <mailto:freedomyachts2003%
40yahoogroups.com>
yahoogroups.com, “michel.capel”
<michel.capel@> wrote:
Hi all,
After being on shore for 7 months, my F44 went back in the
water
like new a month ago. Today she was hauled again and guess
what?
All 5 new anodes (2 magnesium on the strut, 2 zinc on the
shaft, 1
zinc on the rudder connected to the rudder shaft) were heavily
corroded! From the shaft towards the rudder, the corrosion
seems
to
worsen.
The boat was in a fresh water canal without steel pilings, I
had
never connected shore power (we have 230v here, and the boat
is
still 110v). I only ran the generator with battery
charger/inverter
for a few hours every friday (three times).
My house batteries were completeley depleted while on shore,
generator battery (separate) was still okay.
Where could this problem originate? (obviously the
generator…)
but
which connection is wrong??
There is a bonding wire running to the rudder quadrant; would
that
be the culprit? I don’t know yet where this wire leads to.
Thanks for your help and suggestions!
Posted by Norm Friberg (nfriberg@…>)
Michel,
Please send those Dutchmen to New Orleans to teach our engineers how to protect against storms.
Regards,
Norm
Sent: Monday, November 27, 2006 10:10 AM
Subject: [freedomyachts2003] Re: Heavy electrolitic corrosion! - problem solved
The canal I was in connects the city of Goes in Zeeland to the Oosterschelde, which is salt and tidal, and so is the canal. The Oosterschelde has a world famous series of (some 22)concrete doors across the mouth of the estuarium to close it at spring tides and extreme westerlies. This is to prevent the disaster of February 1953, a spring tide combined with westerly winds, taking the lives of 1800 persons and thousends of cattle. The whole province Zeeland was flooded. So far the free Dutch history and geography lesson.I’m going to check on the internal anode as soon as I’ve found and reached it. My heat exchanger was nice and clean inside.— In freedomyachts2003@yahoogroups.com, “geraldfreshwater” <freshwater@…> wrote:>> Sounds like Dutch freshwater is saltier than British freshwater, too! Electolytic corrosion > requires an electrolyte as well as some dissimilar metals. Is there anything left of your > engine’s internal anode?> > I think you should go with Alan’s suggestion, and take up electric boating whilst you are in > the canals!> > Kind regards,> > Gerald Freshwater> > > > > — In freedomyachts2003@yahoogroups.com, “webmaster” <akusinitz@> wrote:> >> > Sounds like you could run some wires and use it as a battery. :-)> > > > Alan> > > > > > > > _____ > > > > From: freedomyachts2003@yahoogroups.com> > [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of michel.capel> > Sent: Sunday, November 26, 2006 3:36 PM> > To: freedomyachts2003@yahoogroups.com> > Subject: [freedomyachts2003] Re: Heavy electrolitic corrosion! - Help needed> > > > > > > > After reading about the subject of bonding, corrosion and zincs, I > > had a look at the situation today. The two magnesium anodes were > > clean and pitted, the zincs were covered in white sodium-something > > and the antifouling paint had peeled off the stainless steel P-> > strut. No stray currents but a textbook example of overprotection by > > too much zinc or worse, magnesium. I forgot that this boat has lived > > in the salty and warm waters of the Gulf and now moved to the colder > > and less salty waters of North Western Europe. I removed the > > magnesiums and will replace them for one small zinc. I will also > > remove one of the zincs on the propshaft and see if the balance > > between kathode and anode is better.> > > > > > — In freedomyachts2003@ mailto:freedomyachts2003%40yahoogroups.com> > yahoogroups.com, “michel.capel” > > <michel.capel@> wrote:> > >> > > Hi all,> > > > > > After being on shore for 7 months, my F44 went back in the water > > > like new a month ago. Today she was hauled again and guess what? > > > All 5 new anodes (2 magnesium on the strut, 2 zinc on the shaft, 1 > > > zinc on the rudder connected to the rudder shaft) were heavily > > > corroded! From the shaft towards the rudder, the corrosion seems > > to > > > worsen.> > > > > > The boat was in a fresh water canal without steel pilings, I had > > > never connected shore power (we have 230v here, and the boat is > > > still 110v). I only ran the generator with battery > > charger/inverter > > > for a few hours every friday (three times). > > > > > > My house batteries were completeley depleted while on shore, the > > > generator battery (separate) was still okay.> > > > > > Where could this problem originate? (obviously the generator…) > > but > > > which connection is wrong?? > > > > > > There is a bonding wire running to the rudder quadrant; would that > > > be the culprit? I don’t know yet where this wire leads to. > > > > > > Thanks for your help and suggestions!> > > > > > Michel> > >> >>
There has been a Dutch delegation over to Nawlins to advise. US
politics however prevents foreign contractors to do much actual work
there, so the learning curve is not very steep. I was surprised to
learn that the US coast defence (against the sea, not the Enemy) is
in the hands of the Army (or Navy, or Marine) Corps of Engineers. In
our country we have a non-military agency responsible for this since
1798.
— In freedomyachts2003@yahoogroups.com, Norm Friberg
<nfriberg@…> wrote:
Michel,
Regards,
Norm
problem solved
doors
lives
Zeeland
freshwater,
electric
the canals!
Kind regards,
Gerald Freshwater
<akusinitz@>
battery.
Alan
michel.capel
corrosion! -
Help needed
zincs,
I
were
something
P-
overprotection by
has
lived
colder
also
balance
40yahoogroups.com>
Hi all,
water
what?
shaft, 1
heavily
seems
to
worsen.
I
had
boat
is
charger/inverter
shore,
generator…)
but
would
that
Posted by Bill Cimino (magicseeker@…>)
Fellow sailors,
In our country (US of A) we must be ever vigilant to possible attacks from Al Qaida. This is why we depend on the knowledge and talents of the Army Corps of Engineers. Unless…of course if Hallibuton bids unopposed for the job. Need any US $ for tulip research? or for developing energy efficient red light bulbs over there in Holland? I’m sure we have a lobby group available in Washington to assist you! (just kidding NSA, if you are reading this)
stillbillythekid
From: “michel.capel” <michel.capel@…>Reply-To: freedomyachts2003@yahoogroups.comTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Heavy electrolitic corrosion! - problem solvedDate: Tue, 28 Nov 2006 11:40:06 -0000
There has been a Dutch delegation over to Nawlins to advise. US politics however prevents foreign contractors to do much actual work there, so the learning curve is not very steep. I was surprised to learn that the US coast defence (against the sea, not the Enemy) is in the hands of the Army (or Navy, or Marine) Corps of Engineers. In our country we have a non-military agency responsible for this since 1798. — In freedomyachts2003@yahoogroups.com, Norm Friberg <nfriberg@…> wrote:>> Michel,> > Please send those Dutchmen to New Orleans to teach our engineers how to protect against storms.> > Regards,> Norm> > > ----- Original Message ----- > From: michel.capel > To: freedomyachts2003@yahoogroups.com > Sent: Monday, November 27, 2006 10:10 AM> Subject: [freedomyachts2003] Re: Heavy electrolitic corrosion! - problem solved> > > The canal I was in connects the city of Goes in Zeeland to the > Oosterschelde, which is salt and tidal, and so is the canal. The > Oosterschelde has a world famous series of (some 22)concrete doors > across the mouth of the estuarium to close it at spring tides and > extreme westerlies. This is to prevent the disaster of February > 1953, a spring tide combined with westerly winds, taking the lives > of 1800 persons and thousends of cattle. The whole province Zeeland > was flooded. So far the free Dutch history and geography lesson.> > I’m going to check on the internal anode as soon as I’ve found and > reached it. My heat exchanger was nice and clean inside.> > — In freedomyachts2003@yahoogroups.com, “geraldfreshwater” > <freshwater@> wrote:> >> > Sounds like Dutch freshwater is saltier than British freshwater, > too! Electolytic corrosion > > requires an electrolyte as well as some dissimilar metals. Is > there anything left of your > > engine’s internal anode?> > > > I think you should go with Alan’s suggestion, and take up electric > boating whilst you are in > > the canals!> > > > Kind regards,> > > > Gerald Freshwater> > > > > > > > > > — In freedomyachts2003@yahoogroups.com, “webmaster” <akusinitz@> > wrote:> > >> > > Sounds like you could run some wires and use it as a battery. :-)> > > > > > Alan> > > > > > > > > > > > _____ > > > > > > From: freedomyachts2003@yahoogroups.com> > > [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of > michel.capel> > > Sent: Sunday, November 26, 2006 3:36 PM> > > To: freedomyachts2003@yahoogroups.com> > > Subject: [freedomyachts2003] Re: Heavy electrolitic corrosion! - > Help needed> > > > > > > > > > > > After reading about the subject of bonding, corrosion and zincs, > I > > > had a look at the situation today. The two magnesium anodes were > > > clean and pitted, the zincs were covered in white sodium-> something > > > and the antifouling paint had peeled off the stainless steel P-> > > strut. No stray currents but a textbook example of > overprotection by > > > too much zinc or worse, magnesium. I forgot that this boat has > lived > > > in the salty and warm waters of the Gulf and now moved to the > colder > > > and less salty waters of North Western Europe. I removed the > > > magnesiums and will replace them for one small zinc. I will also > > > remove one of the zincs on the propshaft and see if the balance > > > between kathode and anode is better.> > > > > > > > > — In freedomyachts2003@ mailto:freedomyachts2003% 40yahoogroups.com>> > > yahoogroups.com, “michel.capel” > > > <michel.capel@> wrote:> > > >> > > > Hi all,> > > > > > > > After being on shore for 7 months, my F44 went back in the > water > > > > like new a month ago. Today she was hauled again and guess > what? > > > > All 5 new anodes (2 magnesium on the strut, 2 zinc on the > shaft, 1 > > > > zinc on the rudder connected to the rudder shaft) were heavily > > > > corroded! From the shaft towards the rudder, the corrosion > seems > > > to > > > > worsen.> > > > > > > > The boat was in a fresh water canal without steel pilings, I > had > > > > never connected shore power (we have 230v here, and the boat > is > > > > still 110v). I only ran the generator with battery > > > charger/inverter > > > > for a few hours every friday (three times). > > > > > > > > My house batteries were completeley depleted while on shore, > the > > > > generator battery (separate) was still okay.> > > > > > > > Where could this problem originate? (obviously the > generator…) > > > but > > > > which connection is wrong?? > > > > > > > > There is a bonding wire running to the rudder quadrant; would > that > > > > be the culprit? I don’t know yet where this wire leads to. > > > > > > > > Thanks for your help and suggestions!> > > > > > > > Michel> > > >> > >> >>
