Posted by kholden@…> (kholden@…>)
Dear Daddy, It’s hard to know where to begin. A bent mast is a big deal. Perhaps there are some people who can help you with that here.
Gelcoat is part of what most people call the fiberglass. Its basically the top layer and normally doesn’t need to be added except if it is scratched thru.
The hulls are normally cleaned and re-painted with a special bottom paint that is expensive but can be done yourself.
I’m not sure what you mean by “lanyards”. If you mean the ropes to pull up the sails, us yankees call them halyards, and it will be important to get the correct length and diameter. There are certain different types of rope (called line when on a boat) that stretch differently or have other characteristics for certain situations. Line can be fairly reasonable or expensive. There are lots of sources. If by “lanyards” you mean the safty lines around the edge of the boat, that is not as expensive although they normally have a very long life.
The sleeve you refer to is probably something particular to a Freedom 21 and is very important. Some other F-21 owner will be better to answer where you can get one.
The sails may be able to be cleaned and refurbished. There are a number of places that do that kind of work.
A name and port is more a custom than a law. You will probably need a State registration but I would wait until Jan to get next years. People either paint on the name of more commonly use decals, made by a sign maker. Typically your port is where you keep the boat. I imagine San Antonio would fit nicely on the back.
I would suggest you order a magazine called Good Old Boat. It has a bunch of advertisements for services or products you might need, along with some helpful stories. As for cost of all this, some people go with an open checkbook to a full service marina, which makes it easy but expensive. Others are able to do all but the most difficult tasks themselves. The group here is very helpful in that area. Good Luck-Skipper
Kent H
F-30 Breakaway
Connecticut
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com]On Behalf Of DaddySent: Friday, October 28, 2005 3:58 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] i finally got herI finally picked up the Freedom 21! It is a 1983 shoal keel sailboat with trailer. The boat looks pretty good for an '83, but it does need work. I hope it aint a money pit!I got in my driveway two nights ago and it rained yesterday so I havent been able to do a lot of research on the condition of the sails, lanyards, etc.The lanyards are old, probably original, as are the sails. The underwater part of the hull is dirty, and does not clean easily. The mast is missing a sleeve(?) where the mast slides connects to the boat.Here are my questions: How important is that sleeve, and where do I get a new one? About how much will new lanyards (100%) cost? The mast has a slight bow in it, is that ok? Does the mast need a cap on the top? How do I clean the grime off the hull without damaging the fiberglass? What is gel coat? And should I get it put on the boat.I am so excited! I remember sailing this boat as a kid and look forward to sharing sailing with my family. I would rather fix her than sell/dump her. I just cant afford costly repairs. Routine and scheduled maintenance will not be a problem. The traier is in excellent condition, other than being rusted. I towed the trailer with the boat on it from Texarkana to San Antonio almost averaging 60 - 70 mph with zero problems.And my biggest concern - SHE HAS NO NAME OR HOME PORT! Is it bad luck to sail her otherwise? I think someone said it was. And, what do I need to do to name her, ie registering etc? I have never been on the owning side of sailing before.I have been told sailing is going nowhere fast while spending large amounts of money. I would hate to give up on sailing this fine vessel if its gonna cost an arm and a leg to get her lake ready.Thank you for your help with my dumb questions,
DISCLAIMER Do not transmit instructions regarding your account by e-mail; instructions transmitted by e-mail will not be accepted by us, and Gagnon Securities will not be responsible for carrying out such instructions. Gagnon Securities archives and reviews all outgoing and incoming e-mail. It may be produced at the request of regulators or in connection with civil litigations. Information contained herein has been obtained from sources believed to be reliable, but its accuracy and completeness, and that of the opinions based thereon, are not guaranteed. This e-mail is not an offer to buy or sell or a solicitation of an offer to buy or sell securities.
