Re: I finally got her
Posted by Daddy (ymgalvez1969@…>)
thanks for all the great info
— In freedomyachts2003@yahoogroups.com, mitya fonin <mitbok1@y…>
Congratulations !
The sleeve prevents water frog going down the mast below deck. One
of the fixes described here : http://brutter.co.uk/page_changes.htm
Lines could be expensive, but you can try EBay. I get everything
there (including my boat itself) For rerigging you will need Rigging
parts list which could be found in here :
http://www.freedom21.info/originals.htm.
My mast bows a little bit as well, could be under tension of the
boom but that’s an interesting question, my be we get some input.
Definitely need a cup on top, probably much easier to fashion it out
of some material and tape it in place than fabricating that missing
mast boot.
Hull can be cleaned with a pressure washer but stuff that yellows
the jell coat will need some chemicals.
I don’t think Freedom 21 is a complicated boat that will take a lot
of money to revive.
Yahoo! FareChase - Search multiple travel sites in one click.
