Hi Max.
Map looks real good as you zoom in enough to separate indivdual boat locations.
Do you envision being able to see the F-21’s name if one clicks on the balloon?
Anyway, Here is my info::
Blue Raven
Hull # 295
Des Monies Marina,
Des Monies, WA
Lat: 47 degrees, 23’ 52" N
Long: 122 degrees, 19’ 39" W
Nick Marino
On your map - my boat should be on the water, just to the left of the “K” in the city of “Kent”.
I just went back to your current map and it appears my balloon is inland and south of the above.
THANKS for a great job Max.
P.S. Jake’s boat at Boston Harbor looks correct.
To: freedom21@yahoogroups.com
Sent: Tuesday, December 26, 2006 2:43 PM
Subject: [freedom21] Map experiment test
Hi All,I have a test page published that displays where Freedom 21 boats arelocated around the world. At this moment I only have two locations,but this is enough for you to see the map and to let me know if thisis what you all visualized.The location is http://www.freedom21.info/map.htm What would be useful for me is for you to send me your latitude andlongitude and your boat name to my email address to reduce the numberof trivial messages on the group. max (at) maxlent.com replace the atwith @.There are a number of ways to look up your latitude and longitude. Gotohttp://jan.ucc.nau.edu/~cvm/latlon_find_location.html#address%20locationfor instructions.Once we get this version of the map online we can discuss if morefeatures are needed or useful.Adapting and writing additional Java script code takes a while, so bepatient.Happy New Year,Max
