Re: Sail slide issue-
Posted by Kirt (simmonskirte@…>)
My only caution about the sail slides is the “weakest link” issue- I would
rather have the sail
slides pull out of the track than the track pull out of the mast or worse- :wink:
Kirt
F21 Red Rocket - planned heirloom!
You also have to deal with the sail-slides. They can and will peel
off the track (break) if a stong gust hits a reefed sail (try Zero to
25Mph as I did on lake Superior and someone else did on SF Bay). Add
two more slides on the topplate and maybe a couple below that on the
sail and use a slightly flexible attachment scheme like nylon rope.
I think an F21 would make a great family heirloom, the quality is
there.
Yes,
That reminds me of the sail slide being attached with too short
rivets. The original rivets did not exit behind the mast wall - but
only expanded inside it. Plastic is flexible so rivets that do not
squeeze both sides of the mast wall will eventually pull out.
