RE: Traveler position and Jib
Posted by j32080@…> (j32080@…>)
When you’re sailing with the jib you can sail the boat as a sloop. When sailing close hauled you can bring the boom to center line by bringing the traveler to windward. However, without the jib you are sailing the boat as a catboat. When sailing close hauled you cannot bring the boom to centerline and maintain forward momentum. The boat will stall and start to skid sideways. I’ve tried it without success trying to pinch around a mark during racing. You’ll need to sail “low” with the boom about over the end of the traveler. Any yes, your tacking angle will be larger. About 100-110 degrees. Best way to measure if you are sailing too tight is to use a VMG (to windward or waypoint) measure. To measure VMG to windward by instruments you’ll need a knotlog AND wind instrument at the top of the mast. Or
calculate by wind angle and boat speed using a VMG “predictor” reference card (probably obsolete by now). It is easier to calculate by a GPS that has a VMG display. This is VMG to waypoint so you’ll need to have entered a GOTO waypoint. Trim the sail slowly and carefully and see the difference in VMG. Sailing low will have more boat speed but you’ll be covering more distance. Sailing high points better but at reduced boat speed. -John Former owner “Blue Merle” #259 http://www.freedom21.info/images/bluemerle/BMMainJib.jpg mitya fonin <mitbok1@…> wrote: Looks like the traveler is right in the middle here ! This issue was raised before. I had some pictures of sailing my boat and some one noticed that my traveler was on the center line. I was told that cats don’t sail this way and traveler has to be right at the edge of the hatch but nu further towards the middle when going upwind. I wanted to bring this up again. It does make sense when sailing under main only, but with the jib raised would puling main in closer get a better performance ?Sean Mulligan <quadmulligan@yahoo.com> wrote: Yes, John, you are of course correct. We were getting overpowered as the wind rose from about 10 earlier. I made the decision to drop the main and sail on just the jib (still making 4.8) 15 minutes after these photos. Normally I would go forward with the jib halyard around the winch a half turn and lower the sail to the deck, then unclip the tack and stuff it down the forward hatch. That didn’t seem wise with the wet deck/conditions so I opted to simply and safely drop the main. It got me thinking I would like to have a remote way to detach the tack of the jib so I could luff up and lower from the cockpit. Anyone have ideas on this? I thought of: A. turning the gun mount spar so the tack was back on the lifeline and more easily reached. B. Getting a release mechanism like found on Spinnaker poles C. Drop the main, then drop and manage the headsail, then re-raise the main. I’m not interested in going roller-furl (a la Blue Raven). Sean More Photos from this weekend: http://www.seanmulligan.com/Stories/Emmylou_Labor_Day_06/index.html http://pg.photos.yahoo.com/ph/quadmulligan/album?.dir=/f503scd&.src=ph&.tok=phlGLdFBW05KmrOW http://pg.photos.yahoo.com/ph/quadmulligan/album?.dir=f503scd&.src=ph&store=&prodid=&.done=http%3a//photos.yahoo.com/ph//my_photos Sean P. Mulligan (203) 981-1021 seanpmulligan@gmail.com -----Original Message-----From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of j32080@yahoo.comSent: Tuesday, September 05, 2006 4:20 PMTo: freedom21@yahoogroups.comSubject: Re: [freedom21] Flying the Jib - Labor Day Sean, Looks nice, but with a “stiff NW breeze”, in my opinion, the boat looks overpowered – lots of heeling, weather helm (based upon the rudder angle) What was the wind speed? By 10 knots, the jib has to come down (unless you’re racing and you’re got all of your crew sitting on the windward rail) Granted, you’ll loose the pointing angle but the boat will sail flatter. -John Sean Mulligan <quadmulligan@yahoo.com> wrote: http://photos.yahoo.com/ph/mattlosnick/slideshow?.dir=/.3229scd&.src=mail&.tok=phow2cFB54pKsIa0We were 3 hours into our Long Island Sound crossing, beating into a stiff NW breeze, when friends in a Moody 44 snapped these shots.Sean / Vivian / Jamie All-new Yahoo! Mail - Fire up a more powerful email and get things done faster. Talk
is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min. Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
Do you Yahoo!? Everyone is raving about the all-new Yahoo! Mail.
I agree with everything John says here. I have a little handheld GPS, but no wind speed instrument. Still, I know my waters and am a good judge of “how am I doing.” Speed rules.
Sean
-----Original Message-----From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of j32080@…Sent: Wednesday, September 06, 2006 11:41 AMTo: freedom21@yahoogroups.comSubject: RE: [freedom21] Traveler position and Jib
To measure VMG to windward by instruments you’ll need a knotlog AND wind instrument at the top of the mast. Or calculate by wind angle and boat speed using a VMG “predictor” reference card (probably obsolete by now).
-John
Sean
http://pg.photos.yahoo.com/ph/quadmulligan/album?.dir=/f503scd&.src=ph&..tok=phlGLdFBW05KmrOW
Sean P. Mulligan
(203) 981-1021
Sean,
-John
Do you Yahoo!?Everyone is raving about the all-new Yahoo! Mail.
