Posted by laucodjen (laucodjen@…>)
How difficult is it to remove and replace masts on a freedom 33 cat
ketch? Wondering about trucking one
I have an F-33 hull # 51 1982 with carbon fiber masts. They are removed each year. As long as the rigger knows what he’s doing (since there are no spreaders to wrap around) its quite straightforward unless someone along the way has epoxied your mast to the base or cabin top.
On mine you:
Sent: Tuesday, January 18, 2005 9:50 PM
Subject: [freedomyachts2003] Removing Masts
How difficult is it to remove and replace masts on a freedom 33 cat ketch? Wondering about trucking oneThanks
Thanks for the info, I am looking at an '82 and am wondering if there
is a particular area to be aware of for core damage in the hull when
I inspect it. Also any other help would be appreciated. My cell is
909-856-4263 if you have the time to discuss it, I’ll call back on my
dime. Thanks, Ron
I strongly recommend you get a competent,impartial surveyor to do the
inspection. Even the best of boats may have some problems. Surveyors have
access to survey records of other similar boats,and,by knowing what to look
for, can render a more informed,and informative,report…BTW,core damage is
detectable by moisture measurements,or at least the moisture leading to
damage is .
I have F33 # 68,1982Original Message -----
Sent: Wednesday, January 19, 2005 4:20 PM
Subject: [freedomyachts2003] Re: Removing Masts
dime. Thanks, RonYahoo! Groups Links
My surveyor percussion tested the entire hull. Took a while. He used
a moisture meter on a spot or two on the deck. Moisture meters are
not as simple and straight forward as you’d think. They can be
tricked particularly on horizontal surfaces. It’s critical that you
find a highly competent surveyor. This will not be someone
recommended by many brokers. When we bought our 39 in San Diego I
flew my surveyor down from the Bay Area to conduct the survey.
— In freedomyachts2003@yahoogroups.com, “laucodjen”
there
when
my
dime. Thanks, Ron
