Posted by C. D. Myers (lambdazeta_tke@…>)
Hi all,
What a pleasant non-surprise… I was supposed to have Saturday off and I actually did get it off!
The Sailing Assoc. planned a cruise to the new Guntersville city pier on the other side of the bridge. Paul will remember it as where the old Harbor House restaurant used to be. I got to the clubhouse just after 10 a.m. Due to threatening weather we decided to take a “land yacht” into town for lunch and then weather permitting walk down to the new pier. It rained cats and dogs with lots of lightening from 10:45 until 11:30 so we made the right choice.
After our lunch and walk we decided to go on over to Lake Guntersville State Park. The Teachers Retirement Fund has taken over operation of the Lodge and spent a couple of million dollars renovating the lodge (removing asbestos, etc.). There are fantastic views of the lake from the back decks. We then drove down to the park’s boat ramps and transient piers. The piers are nice floating units with a pebble terrazzo cement deck. The slips all have power and water and rent for $22 per night. The Mutineer class will have their national regatta at this facility in 2009 and Browns Creek Sailing Association is the host club of record. The Mutineer is basically a Buccaneer with the last 3 feet cut off. We have several of both classes at BCSA.
We got back to the clubhouse around 3pm and I started stripping the old name (Winners Bitch) off of the boat. I used a heat gun to loosen the glue and soften the vinyl letters. I finished the port side using Goof Off and an old t-shirt to remove the glue residue. It was now after five and I started asking around the clubhouse if anyone was interested in going back to town for some dinner. We decided to pitch in together and have a cook out. One of the ladies had some Bratwursts and I pitched in for soda and German potato salad and while some of the ladies went to town for more supplies I went back and stripped the letters from the starboard quarter. It was time to help with the food prep so I left the glue on that side for Sunday. We had a great meal and about 8pm with full dark I went back to the boat to test the deck lights I mounted on the masthead last weekend. They worked perfectly! They target the foredeck just where I will need them if I am trying to set an anchor after dark. I closed the boat up and drove back to HSV for the night. You may be asking why I did not sleep aboard. The answer is I had to read the first lesson and lead the psalm in church this morning.
After church today I drove back over to the marina in Guntersville. I ate lunch at a local dive called Char Burger and went to work on the glue residue on the starboard quarter. It took about an hour and a half to get it all off. I then lightly sanded and cleaned a couple of places on the hull that had small cracks or chips in the gel coat. I mixed up some white epoxy putty and filled the quarter-sized chip in the bow as well as the just sanded areas.
Next weekend (08/02-03), if the weather permits:
On Saturday I plan to sand the entire hull above the water line as well as the side of the deckhouse. On Sunday I hope to clean, mask and prime the sanded areas.
The following weekend (08/09-10):
Saturday - fine sand and clean primed areas and then apply first finish coat of paint. Sunday - fine sand and clean painted areas then apply second and final finish coat.
The next weekend (08/16-17):
Saturday - paint boot stripe and waterline then work on rewiring the electrical system (manual should have arrived by then). Sunday - Apply new name (either “Aiolis” or “Teke’s Pride”) and registration numbers to boat. Finish wiring if needed. Rig all lines.
The fourth weekend in August:
Saturday - Christening party and launch boat. Sunday - Shakedown cruise.
Fifth weekend:
Saturday - fix anything turned up by last weekend’s shakedown. Sunday - more sailing
September 6th is the first race day of the fall series. Lets see what we can do!
Clark
P.S.: Driving home this evening I noticed that the first Freedom 21 that I had considered buying was out of the water and on a trailer at the marina across the lake. It turns out to be a fin keel not a shoal keel as I had been told. I still think I made the right choice even though the other boat is half the cost. CDM— In freedom21@yahoogroups.com, “C. D. Myers” <lambdazeta_tke@…> wrote:>> As most of you know by now, I went to South Carolina last weekend and > took possession of my new boat. I bought “Winners Bitch” from her > original owner, Bob Penland. > > I spent yesterday getting supplies for the boat’s renovation. Today > I went to the marina in Guntersville, AL after church and I was able > to get the new Main and Spinnaker halyards installed before the > afternoon thunderstorm came thru. This was challenging since the old > halyards were not on the mast. I was able to use a wire > electrician’s fish to thread the halyards.> > Around 4pm the storm had cleared out leaving lower humidity and a > nice breeze. I went back to work on the boat and got new wiring > installed in the mast (this went much faster as I was able to use the > old wires as messangers for the new ones). The old wiring consisted > of a coax for the VHF antenna and a single marine grade duplex cable > for the masthead steaming light (there was no anchor light). > > I ordered a new combination steaming and anchor light yesterday but > it is a three-wire unit. Apparently nobody makes a 3-wire through > deck fitting so I had to buy a 4-wire fitting. The smallest marine > grade wire available in triplex cable is 16 gage but it would not fit > through the clamp end of the fitting. I was able to find quad 18 > gage sprinkler cable from Home Depot that fits the fitting like it > was made for it. The sprinkler control wire is rated for wet > environment so I think it will work OK. It is also a good match for > the gage of the wires on the new combo light. > > I have decided to leave the old 2-wire through deck fitting in place > (I went ahead and replaced the old duplex cable with new duplex > cable). I will use the duplex cable to rig deck lights for the > boat. That should make mooring easier after dark. I will try to > send pictures of that project next week.> > I ran into some clear “tape” strips clogging the mast durring the > above tasks. The are clear plastic about 3" wide. There was no > adheasive on the 2 foot strip I fished out of the mast but I did find > a thumbnail sized peice of epoxy on the tape. Please tell me my mast > is not de-laminating from the inside. Has anyboay run into this sort > of thing before?> > I spent another thirty minutes removing the old California > registration numbers (1st owner lived in CA before retiring to SC) > from the port and starboard bows of the boat. I tried to remove the > 10" high name from the quarters but I was getting sore and tired so I > knocked off about 7pm and drove back to Huntsville. > > Next weekend I plan to mount the lights plus mount a combination VHF > antenna and windex and finally seal the masthead before raising the > mast. I also plan to start on rewiring the electrical panel and > replacing any worn wiring I come across. > > The following weekend I plan on starting the prep for a new paint job > for the boat. My plan is to have the boat re-christened and in the > water by early August (in time for the start of the Fall Race Series > at Browns Creek Sailing Association).> > Fair winds and following seas,> Clark Myers> Hull #345>
