Posted by margaret ibbotson (gratton1932@…>)
We have a 1987 Freedom 30, and would like to replace our old factory installed sounder with a Lowrance Sonar/GPS Chartplotter combo. However, we do not want to cut into the balsa cored hull!!! Will a transducer work efficiently THROUGH the balsa core? We would appreciate any suggestions. Thanks, Margaret
All new Yahoo! Mail Get news delivered. Enjoy RSS feeds right on your Mail page.
Take out the old transducer if it is a thru hull,and re-use the hole.
Transducers will not reliably perform thru a cored hull-
Thanks, Margaret
*All new Yahoo! Mail *
http://us.rd.yahoo.com/evt=40705/*http://mrd.mail.yahoo.com/try_beta?.intl=ca
Transducers on the inside are not
recommended for balsa. Many of the freedom models (not sure about the 30) have
solid fiberglass below a certain point. On my 33 the depth transducer does not
go through the balsa.
I wouldn’t worry about going through
the balsa though. Just do it properly such as scraping back the balsa a inch
and filling with epoxy and filler compound so there can be no water intrusion.
I had one thru hull that must have been
added by a previous owner that had some leakage and was through the core. I
took it out and the balsa was fine. I scraped it back and filled with epoxy and
put in a new thru hull.
Please consider joining the freedom owners
group http://groups.yahoo.com/group/FreedomOwnersGroup/
instead of this one. Many of us have moved to it due to spam.
Alan F-33 Hull # 51 1982.
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of margaret ibbotson
Sent: Sunday, September 23, 2007
3:34 PM
Subject: [freedomyachts2003]
replacing a depth sounder
combo.
Thanks, Margaret
All new Yahoo! Mail
Posted by Al Lorman (ajl@…>)
The
area around the centerline of a Freedom 30 is solid glass so if you choose not
to reuse the old hole, cutting a new one is straightforward. My depth
sounder transducer goes through solid glass directly in front of the keel.
Al
Lorman
F30
Ab Initio
[mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Alan Kusinitz
Sent: Sunday, September 23, 2007 4:01 PM
Subject: RE: [freedomyachts2003] replacing a depth sounder
Transducers
on the inside are not recommended for balsa. Many of the freedom models (not
sure about the 30) have solid fiberglass below a certain point. On my 33 the
depth transducer does not go through the balsa.
I
wouldn’t worry about going through the balsa though. Just do it properly
such as scraping back the balsa a inch and filling with epoxy and filler
I had one
thru hull that must have been added by a previous owner that had some leakage
and was through the core. I took it out and the balsa was fine. I scraped it
back and filled with epoxy and put in a new thru hull.
Please
consider joining the freedom owners group http://groups.yahoo.com/group/FreedomOwnersGroup/
Alan F-33 Hull
51 1982.
ibbotson
Sent: Sunday, September 23, 2007 3:34 PM
Subject: [freedomyachts2003] replacing a depth sounder
We
combo.
However,
Will
We
Margaret
All
new Yahoo! Mail
Get
Posted by John Dough (available239@…>)
I have a freedm 40/40 2001 and added a garmin transducer just ahead of the keel. the area is solid fiberglass and the transducer works great through the hull, no holes needed. Richardjerry weinraub <zayde@…> wrote: Take out the old transducer if it is a thru hull,and re-use the hole. Transducers will not reliably perform thru a cored hull-margaret ibbotson wrote:> We have a 1987 Freedom 30, and would like to replace our old factory > installed sounder with a Lowrance Sonar/GPS
Chartplotter combo. > However, we do not want to cut into the balsa cored hull!!!> Will a transducer work efficiently THROUGH the balsa core?> We would appreciate any suggestions.> Thanks, Margaret>> ----------------------------------------------------------> *All new Yahoo! Mail * > http://us.rd.yahoo.com/evt=40705/*http://mrd.mail.yahoo.com/try_beta?.intl=ca >> ----------------------------------------------------------> Get news delivered. Enjoy RSS feeds right on your Mail page.>
Tonight’s top picks. What will you watch tonight? Preview the hottest shows on Yahoo! TV.
Thanks for your help - the old hole is the wrong size for the new transducer, however, we should be able to rough up the fibreglass a little, and resin the transducer directly to the hull. Margaret Al Lorman <ajl@…> wrote: The area around the centerline of a Freedom 30 is solid glass so if you choose not to reuse the old hole, cutting a new one is straightforward. My depth sounder
transducer goes through solid glass directly in front of the keel. Al Lorman F30 Ab Initio From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Alan KusinitzSent: Sunday, September 23, 2007 4:01 PMTo: freedomyachts2003@yahoogroups.comSubject: RE: [freedomyachts2003] replacing a depth sounder
Transducers on the inside are not recommended for balsa. Many of the freedom models (not sure about the 30) have solid fiberglass below a certain point. On my 33 the depth transducer does not go through the balsa. I wouldn’t worry about going through the balsa though. Just do it properly such as scraping back the balsa a inch and filling with epoxy and filler compound so there can be no water intrusion. I had one thru hull that must have been added by a previous owner that had some leakage and was through the core. I took it out and the balsa was fine. I scraped it back and filled with epoxy and put in a new thru hull. Please consider joining the
freedom owners group http://groups.yahoo.com/group/FreedomOwnersGroup/ instead of this one. Many of us have moved to it due to spam. Alan F-33 Hull # 51 1982. From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of margaret ibbotsonSent: Sunday, September 23, 2007 3:34 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] replacing a depth
sounder We have a 1987 Freedom 30, and would like to replace our old factory installed sounder with a Lowrance Sonar/GPS Chartplotter combo. However, we do not want to cut into the balsa cored hull!!! Will a transducer work efficiently THROUGH the balsa core? We would appreciate any suggestions. Thanks, Margaret All new Yahoo! Mail
Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail
Thanks for your speedy reply. Al Lorimer confirmed solid fibreglass in front of the keel. MargaretAlan Kusinitz <akusinitz@…> wrote: Transducers on the inside are not recommended for balsa. Many of the freedom models (not sure about the 30) have solid fiberglass below a certain point. On my 33 the depth transducer does not go through the balsa. I wouldn’t worry about going through the balsa though. Just do it properly such as scraping back the balsa a inch and filling with epoxy and filler compound so there can be no water intrusion. I had one thru hull that must have been added by a previous owner that had some leakage and was through the core. I took it out and the balsa was fine. I scraped it back and filled with epoxy and put in a new thru hull. Please consider joining the freedom owners group http://groups.yahoo.com/group/FreedomOwnersGroup/ instead of this one. Many of us have moved to it due to spam. Alan F-33 Hull # 51 1982. From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of margaret ibbotsonSent: Sunday, September 23, 2007 3:34 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] replacing a depth sounder We have a 1987 Freedom 30, and would like to replace our old factory installed sounder with a Lowrance Sonar/GPS Chartplotter combo.
However, we do not want to cut into the balsa cored hull!!! Will a transducer work efficiently THROUGH the balsa core? We would appreciate any suggestions. Thanks, Margaret All new Yahoo! Mail Get news delivered. Enjoy RSS feeds right on your Mail page.
Ask a question on any topic and get answers from real people. Go to Yahoo! Answers.
thaks for your speedy response. All Lorman confirmed the F30 solid fibreglass in front of the keel. So that’s a relief. Margaretjerry weinraub <zayde@…> wrote: Take out the old transducer if it is a thru hull,and re-use the hole. Transducers will not reliably perform thru a cored hull-margaret ibbotson wrote:> We have a 1987 Freedom 30, and would like to replace our old factory > installed sounder with a Lowrance Sonar/GPS Chartplotter combo. > However, we do not want to
By
the way, I neglected to note that although I have a through hull depth transducer,
it worked sporadically when I first boat my boat. Rather than have it hauled
mid-season to be replaced, I bought a cheap depth sounder on eBay and epoxied
the transducer inside the hull just in front of the through hull. It
worked fine. (I did replace the transducer when I had the boat hauled
later, so now I have a spare.)
Al
Lorman
F30
Ab Initio
Sent: Monday, September 24, 2007 12:40 PM
Margaret
ibbotson
combo.
core?
Thanks, Margaret
All
new Yahoo! Mail
