The engine control on our F32 is showing signs of wear. The transition from
forward to reverse or vice versa requires a stop at neutral and the clutch
button held in. Given the criticality of this function, I’ve decided to
replace the whole control with a new one. I’ve looked at Teleflex Morse and
Kobelt and they both have offerings that appear to be able to handle the
job. Does anyone have experience in this area?
We changed to dual controls on the steering pedestal. Changing
to the pedestal instead of foot level is really nice. The dual
was felt to be more reliable than the mechanically complex
single lever shift-throttle control. I do miss the easy back
and fill of the single lever. The old corroded long control cables
were part of the problem and they were also replaced. All this work
added up to something too much for me and the yard did the work.
Now at the critical reverse to ease into the dock all works
smoothly.
Charles
transition from
clutch
decided to
Morse and
handle the
My Hoyt 32 had, some time prior to my buying it, the engine control changed to a single lever control on a separate pedestal fastened to the starboard side of the steering pedestal. The control itself is a Morse, as well may be the pedestal it’s mounted on, I’d have to double check. It works very well, with all the convenience of the single lever action, and the benefit of being at the proper height. If you’re interested, I’ll drop you a dig-pic of the installation.
PWMjohn reed <john-reed@…> wrote:
Folks,The engine control on our F32 is showing signs of wear. The transition fromforward to reverse or vice versa requires a stop at neutral and the clutchbutton held in. Given the criticality of this function, I’ve decided toreplace the whole control with a new one. I’ve looked at Teleflex Morse andKobelt and they both have offerings that appear to be able to handle thejob. Does anyone have experience in this area?John & Karen ReedLangsam__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Paul,
I would also be interested in seeing a picture of the installation. I don’t have the clutch, but have to be at idle speed - go to neutral- then shift. It is a bit hectic when making quick menuvers.
Sward
Let me know, and i will send you my address.Paul McFadden <pwhitmac@…> wrote:
No problem. Give me an email addr’, or whatever, and I’ll send you a couple or three shots so you can get an idea of how it looks/works.
PWMSward <swardfullsail@…> wrote:
Paul,
Sward
Do you Yahoo!?
Yahoo! Mail Address AutoComplete - You start. We finish.
