Posted by andyandbarbara@… (andyandbarbara@…)
Arrived at the boat yesterday to a disaster! The rudder has completely broken off, leaving a small amount of sheared off metalwork but no pintels or gudgeons etc. Does anyone have the specs for the rudder and tiller? I think I have found somewhere that can make a replacement but they need something to go from.
A friend is going to dive around the mooring to see if it is lying in the mud but I’m not holding my breath.
Many thanks
Barbara
Many thanks
Barbara
I have no idea - it was checked over whilst out of the water - no problems - the only thing I can think of is that there was a big blow and a couple of boats came off their moorings, so perhaps it got sideswiped by a passing boat.
Hi Wilf
Thank you for offering to do that! Our friend has just managed to recover the whole thing from the bed of the lake - minus all the metal work apart from some mangled brackets. We will have to find a way of getting it all replaced.
You’re right though - it would be a useful thing to have on the information site.
Thanks again
Barbara
Please let us know what caused you to loose the rudder!
-----Original Message-----From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of andyandbarbara@…Sent: Wednesday, March 28, 2007 10:27 AMTo: freedom21@yahoogroups.comSubject: [freedom21] Rudder and Tiller dimensions
Many thanks
Barbara
Posted by Wilfred Bishop (wilf.bishop@…>)
Hi Barbara,
I have checked & measured a number of F21 rudders as I need to make up a new lifting rudder for my twin lifting keel UK F21 as my current “butchered” fixed rudder is a joke & looks nothing like the right shape. I will draw-up a dimensioned sketch for you and post it on the website - since there was no “official” set of dimensions I trust that my measured rudder dimensions will serve your purpose? As for the tiller Ii will give you my tiller dimensions but I guess that tiller dimensions are a matter of personal taste anyway. I’ll not be able to do this until the weekend - hope that’s OK?
Regards,
Wilf Bishop
UK F21 DAYDREAM
Sent: Wednesday, March 28, 2007 3:26 PM
Many thanks
Barbara
Posted by Nick Weideman (nweideman@…>)
Wilf,
I am about to take to my 6ft rudder blade with a saw to cut it down to
a more realistic length. Seeing as I normally sail comfortably with a
foot or so of the blade sticking up out of the rudder box I was going
to take a foot off the bottom. Do you have the measurements handy
mentioned in the message below? I just want double check before I cut
it too short and end up losing a young’n over the side in the throws
of a wild broach caused by not having enough rudder in the water.
Also if anyone has any advice about the best side profile for the
bottom of the blade it would be much appreciated. It seems to be a
NACA section but it is U shaped at the bottom with the bias of the U
aft of centre. I find it vibrates madly in 12-15 knots in flat water
when the boat hits top speed. I am guessing a straight edge angled
down lower as it moves aft would be better to avoid the vibration and
still rise without breaking if we ever hit the mud unintentionally.
The current U shape just doesn’t look right.
Many thanks,
Nick
Freelance #273
— In freedom21@yahoogroups.com, “Wilfred Bishop” <wilf.bishop@…>
Hi Barbara,
do this until the weekend - hope that’s OK?Regards,
Wilf Bishop
UK F21 DAYDREAM----- Original Message -----
Subject: [freedom21] Rudder and Tiller dimensionsArrived at the boat yesterday to a disaster! The rudder has
Many thanks
Barbara
Hi Nick,
I have sent Max Lent today a copy of my sketch of the F21 standard rudder planform plus some notes on rudder design that I collected from the currently available references on yacht design & rudder selection. Hopefully Max can get these notes & the sketch on our site within the next week or so?
Best regards,
Wilf Bishop
Sent: Tuesday, October 16, 2007 5:24 AM
Subject: [freedom21] Re: Rudder and Tiller dimensions
Wilf,I am about to take to my 6ft rudder blade with a saw to cut it down toa more realistic length. Seeing as I normally sail comfortably with afoot or so of the blade sticking up out of the rudder box I was goingto take a foot off the bottom. Do you have the measurements handymentioned in the message below? I just want double check before I cutit too short and end up losing a young’n over the side in the throwsof a wild broach caused by not having enough rudder in the water.Also if anyone has any advice about the best side profile for thebottom of the blade it would be much appreciated. It seems to be aNACA section but it is U shaped at the bottom with the bias of the Uaft of centre. I find it vibrates madly in 12-15 knots in flat waterwhen the boat hits top speed. I am guessing a straight edge angleddown lower as it moves aft would be better to avoid the vibration andstill rise without breaking if we ever hit the mud unintentionally.The current U shape just doesn’t look right.Many thanks,NickFreelance #273— In freedom21@yahoogroups.com, “Wilfred Bishop” <wilf.bishop@…>wrote:>> Hi Barbara,> > I have checked & measured a number of F21 rudders as I need to makeup a new lifting rudder for my twin lifting keel UK F21 as my current"butchered" fixed rudder is a joke & looks nothing like the rightshape. I will draw-up a dimensioned sketch for you and post it on thewebsite - since there was no “official” set of dimensions I trust thatmy measured rudder dimensions will serve your purpose? As for thetiller Ii will give you my tiller dimensions but I guess that tillerdimensions are a matter of personal taste anyway. I’ll not be able todo this until the weekend - hope that’s OK?> > Regards,> > Wilf Bishop> UK F21 DAYDREAM > > > ----- Original Message ----- > From: andyandbarbara@… > To: freedom21@yahoogroups.com > Sent: Wednesday, March 28, 2007 3:26 PM> Subject: [freedom21] Rudder and Tiller dimensions> > > > Arrived at the boat yesterday to a disaster! The rudder hascompletely broken off, leaving a small amount of sheared off metalworkbut no pintels or gudgeons etc. Does anyone have the specs for therudder and tiller? I think I have found somewhere that can make areplacement but they need something to go from. > A friend is going to dive around the mooring to see if it is lyingin the mud but I’m not holding my breath.> Many thanks> Barbara>
Hi Wilfred and Nick,
Wilfred’s article has been published to the Freedom 21 site at
http://www.freedom21.info.
Wilfred, thank you again for your contributions to the body of
knowledge about freedom 21 sailboats.
Sincerely,
Max
Max Lent
Max Lent Communications
http://www.maxlent.com
Posted by devoid154 (nweideman@…>)
Max,
Many thanks for the uploading article and your great website. Being
able to get this information online makes owning a F21, so much fun.
Wilf, this was exactly the information I was looking for. Looks like I
can cut a fair bit more off the blade than I had planned to. The
current tip shape and profile details also explain the vibration I
have been experiencing at good speeds on flat water. Let’s hope
squaring the profile up and adding a knife edge improves the overall
performance a little. I’ll probably go with the elliptical profile as
it seems this may save the blade a little if I ever inadvertently hit
the bottom for some reason.
cheers and thanks again,
Nick
http://www.freedom21.info.Wilfred, thank you again for your contributions to the body of
knowledge about freedom 21 sailboats.Sincerely,
Max
Max Lent
