Posted by Russell Bonham (rabonham2000@…>)
My Freedom 32 “Pelagic”, hull # 122, has slightly loose rudder
bearings. The yard thinks they are good enough for another season or
two. Does anybody know what types of bearings were used in this model
(1991)? Also, are replacement bearings available, and at what cost?
Posted by ADScott (ADScott@…>)
Have you tightened the bolt circle on the coupling around the rudder
shaft? I’m betting you can take the play out of it by simply tightening
the coupling; I did.
Al Scott
F-32 MECORIAN
— In freedomyachts2003@yahoogroups.com, ADScott <ADScott@f…>
rudder
tightening
Al Scott
F-32 MECORIAN
I think Al is right, all you can do is replace the packing and/or
snug up the bolts and my guess is your packing might be worn out or
maybe even gone. In mine (hull #59) there isn’t a mechanical bearing,
there’s just a smooth stainless steel sleeve molded onto the
rudderpost that slides against 2 rings of conventional half inch
(9/16? I`m not sure) flax packing held by the bolt ring. Snugging the
bolts presses on the flax packing to seal out the water but still let
the rudderpost turn freely, exactly like to prop shaft stuffing box.
New packing costs maybe $10 but the real trick is to evenly snug all
8 separate bolts enough to seal the water out but not so tight to
feel drag on the wheel. And to do so with a wrench while lying on
your belly on the aft bunk and not being at the wheel to try it.
If you can figure out a good way to do that, let me know.
Thanks for the help!
Russ (“Pelagic”)
<ADScott@f…>
around the
rudder
it by simply
tightening
Al Scott
F-32 MECORIAN
packing and/or
be worn out or
mechanical bearing,
onto the
ring. Snugging the
water but still let
shaft stuffing box.
evenly snug all
not so tight to
while lying on
wheel to try it.
know.
Do you Yahoo!?
Yahoo! Finance Tax Center - File online. File on time.
http://taxes.yahoo.com/filing.html
