Can anybody tell me how the F-33 rudder is constructed? I want to connect a
rudder
position sensor for an autopilot (Autohelm ST4000+MKII). I have to figure out
how best to
attach a rod or cable from the sensor to the rudder.
Thomas
F-33 #66 Finesse.
It is made of two halves laminated together with a stainless tube
laminated in the front edge. You will need a waterproof rudder angle
sensor, because there are no below-deck parts on an F33 rudder (at
least, not on my European version, the F35 catketch).
connect a rudder
figure out how best to
Thomas
F-33 #66 Finesse.
On my F35 the autohelm rudder position sensor attaches to the rudder
quadrant gear, inside the boat.
Sent: Tuesday, February 14, 2006 5:57 AM
Subject: [freedomyachts2003] Re: Rudder F-33
connect a rudder
Thomas
F-33 #66 Finesse.
angle
to
connect a rudder
to
Thomas
F-33 #66 Finesse.
I had to replace my new ST4000 plus after a lightning strike this summer and discovered that Raymarine now includes a rudder sensor unit as part of the package (at no apparent change of price). When I bought the first unit a year ago, the rudder angle sensor was an option.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of macks011Sent: Tuesday, February 14, 2006 8:43 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Rudder F-33Doesn’t the Autohelm 4000 have a rudder angle algorithim built in, displaying as a dark bar either side of center on the LCD?-- In freedomyachts2003@yahoogroups.com, “Michel Capel” <mike_c_f35ck@…> wrote:>> It is made of two halves laminated together with a stainless tube > laminated in the front edge. You will need a waterproof rudder angle > sensor, because there are no below-deck parts on an F33 rudder (at > least, not on my European version, the F35 catketch). > > — In freedomyachts2003@yahoogroups.com, “tgcmd” <Finesse@> wrote:> >> > Can anybody tell me how the F-33 rudder is constructed? I want to > connect a rudder > > position sensor for an autopilot (Autohelm ST4000+MKII). I have to > figure out how best to > > attach a rod or cable from the sensor to the rudder.> > Thomas> > F-33 #66 Finesse.> >>
