Posted by thalloin (lhalloin@…>)
Our 1987 F-30 has a sagging vinyl headliner. I am hoping to reuse the
vinyl and glue it back to the plywood ceiling. I am interested in
ideas on what to use for glue and any suggestions and hints.
I reused the vinyl after scarping the old foam off both the vinyl and the plywood. I used 3M heavy duty spray adhesive, which worked only so-so, as well as a thick, spreadable adhesive that someone of this board recommended. That worked better; now if I could just remember the name of the product.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of thalloinSent: Sunday, March 12, 2006 8:39 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] sagging headlinerOur 1987 F-30 has a sagging vinyl headliner. I am hoping to reuse thevinyl and glue it back to the plywood ceiling. I am interested inideas on what to use for glue and any suggestions and hints.
<ajlorman@…> wrote:
Henry’s 386 adhesive. New material is available from Paul Dennis at
$10.00/ running yard off a 39" wide roll. To the original poster,
It’s not too much more work to replace with new than to try to re-
establish the old head liner. I did this project last season. If you
have questions, feel free to e-mail.
only
remember the
name of the product.Al Lorman
F30 Ab Initio-----Original Message-----
ideas on what to use for glue and any suggestions and hints.SPONSORED LINKS
Sailing schools
<http://groups.yahoo.com/gads?
t=ms&k=Sailing+schools&w1=Sailing+schools&
w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing
+ad
venture&w6=Sailing&c=6&s=122&.sig=nM_33Bwh2_UhuqSYWZR8Xw>
Sailing
instruction
t=ms&k=Sailing+instruction&w1=Sailing+scho
ols&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sai
lin
g+adventure&w6=Sailing&c=6&s=122&.sig=PLKTippWs7H3hJMQiiV1Dg>
Sailing
lesson
t=ms&k=Sailing+lesson&w1=Sailing+schools&w
2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+
adv
enture&w6=Sailing&c=6&s=122&.sig=BW-ssa-AtK1bKwgxZtYhsg>
Sailing course
t=ms&k=Sailing+course&w1=Sailing+schools&w
adv
enture&w6=Sailing&c=6&s=122&.sig=iJziK8qHrpaIJG_Q19twrg>
Sailing
adventure
t=ms&k=Sailing+adventure&w1=Sailing+school
s&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Saili
ng+
adventure&w6=Sailing&c=6&s=122&.sig=luRjwGYgtoRAVO_RIh446A>
Sailing
t=ms&k=Sailing&w1=Sailing+schools&w2=Saili
ng+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adventu
re&
w6=Sailing&c=6&s=122&.sig=H5HiiLFUXHyIpCEv0TmINg>
YAHOO! GROUPS LINKS
Visit your group "freedomyachts2003
http://groups.yahoo.com/group/freedomyachts2003 " on the web.To unsubscribe from this group, send an email to:
<mailto:freedomyachts2003-unsubscribe@yahoogroups.com?
subject=Unsubscrib
e>Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service http://docs.yahoo.com/info/terms/ .
Brown, Rowe & Maw LLP to be used and cannot be used by any taxpayer
than Mayer, Brown, Rowe & Maw LLP) of that transaction or matter,
I had the same problem of “sagging headliner” when I purchased my Hoyt32. Inasmuch as all the “sag” was located in the main saloon/galley area, I removed all of it, inspected things and decided to replace it all with new stuff. Having never been a fan of foam backed vinyl, I went to a commercial material shop and got vinyl that is used on auto soft tops (exterior) which has a “fuzzy” backing and is literally indistinguishable from the original headliner. Using the old panels as templates, I cut new ones out of mahogany door skin (home Depot/Lowe’s). I used commercial contact adhesive and a cheap spray gun for application. My overheads now look like new, and that was four years ago. If you want any further detail about the procedure, mail me direct. PWMthalloin <lhalloin@…> wrote: Our 1987 F-30 has a sagging vinyl headliner. I am hoping to reuse thevinyl and glue it back to the plywood ceiling. I am interested inideas on what to use for glue and any suggestions and hints.
Yahoo! Mail
Bring photos to life! New PhotoMail makes sharing a breeze.
