Posted by Douglas April (dougie131313@…>)
I would have to say that both Bob and Charlie are right on. You are only going to use the motor 10%-20% of the time you are on the water, and if you consider yourself a real sailor you will use wind power as much as you can. If you need to charge your battery get a solar panel. So you need to balance HP to WT. You will never need a motor to get you to hual speed (WT), yet you want a motor that will power yourself out of a bad situation if you ever get into one. I would go with a motor that is 4-5 HP, yet money talks and BS walks. Bottom line is how much it’s going to set you back.
Doug
----- Original Message ----From: Nick Marino <blueraven1@…>To: freedom21@yahoogroups.comSent: Monday, September 15, 2008 6:36:11 PMSubject: [freedom21] Re: Seeking Motor Opinions
Sean,Bob is right on. Nick— In freedom21@yahoogrou ps.com, “Bob Broder” <RABroder@… .> wrote:>> In my opinion: It is worth $500 for a new motor: quieter, smoother, > no mixing crap… and above all, much better for environment! !Good > Luck, and let us know how you decide!> — In freedom21@yahoogrou ps.com, Sean Mulligan <quadmulligan@ > > wrote:> >> > Thanks for the response Bob. > > Now, with the 15 hp out of the picture, it gets interesting: the > used Evinrude 8 hp 2-stroke will cost $920. The new Tohatsu 6hp 4-> stroke with warranty is $1430. Both have charging systems.> > This
makes choice harder for me. Any thoughts anyone??> > > > Sean> > > > — On Mon, 9/15/08, Bob Broder <RABroder@> wrote:> > > > From: Bob Broder <RABroder@>> > Subject: [freedom21] Re: Seeking Motor Opinions> > To: freedom21@yahoogrou ps.com> > Date: Monday, September 15, 2008, 1:46 PM> > > > > > > > > > > > > > Sean: I have an Evinrude Yacht-Twin 6 hp long shaft on Daiquiri, > > have had since 1994 when it was new. Works fine, gets us up to hull > > speed with no sweat… it is ok.> > > > Of the three choices you present: I would avoid the Mercury due to > > its weight… you still have to haul it up and
down on the bracket, > a > > pain in the a…s, and 15 hp is simply too big, guzzles gas and is > > just that much heavier to take on and off the boat.> > > > The used Evinrude 6 hp, Long shaft, is still a bit too large (8hp) > > but ok if you get a REAL deal on it and have it thoroughly checked > by > > a competent Mechanic. > > > > My preference would be for the 4 stroke Tohatsu, although you dont > > really need a 25" leg unless you have a really wierd bracket!! I > find > > that even my 20 incher sometimes drags in the water when the boat > is > > heeled. I also feel it is important to go “Green” where possible… > > and avoid dumping that oil in the pristeen CT waters! Make sure, > > however, there is a Tohatsu dealer reasonably near, as 4 strokers > are >
somewhat more complicated that the oil burners! > > > > That being said, I too have a question for the board: Most brackets > > (fulton, Garelic, etc… about $150, for up to 10HP engines > > state: “Not for 4 stroke outboards”… Why not,if the weight is the > > same? The answers I received from dealers range from “Nonsense”, > > to “Torque too high” to " 4 strokes dont do well when you keep them > > tilted out of the water, due to the oil reservoir!" None makes too > > much sense to me… and I may replace my 'rude next year! > > bob— In freedom21@yahoogrou ps.com, “Sean Mulligan” > > <quadmulligan@ …> wrote:> > >> > > Freedom Friends: I am shopping for an engine for Emmylou #307 in > > > Stamford, CT where I ply the waters of Long Island
Sound.> > > I have 3 choices in front of me that I would like feedback on > > (price > > > is NOT a part of the discussion - just the suitability of the > > motor).> > > > > > 1) Used 2-stroke 15 hp Mercury Mariner Long Shaft with F/R on the > > > throttle handle. Weighs about 100 lbs (don’t know exactly). > Buying > > > from a captain friend of mine.> > > > > > 2) Used 2-stroke Evinrude 8hp Outboard Long Shaft from online > > dealer > > > AFA. Weighs “around 65lbs”. > > > Link: http://www.smallout boards.com/ e898l.htm > > > > > > 3) New 2009 TOHATSU 6hp Four-Stroke Outboard Motor with 25" ultra > > > long (25") shaft and alternator
for battery charging. Weighs 55 > lbs > > > Link: http://www.onlineou tboards.com/ 6hp_tohatsu_ outboard_ > motor.html> > > > > > Thanks, as always, for your insights!> > > > > > Sean Mulligan, Emmylou #307 > > > Photos of me sailing in 18 knots with full main and jib:> > > http://picasaweb. google.com/ seanpmulligan/ LaborDay06#> > >> >>
