Posted by tlynchlaw (pass@…>)
My batteries are nearing the end of their life and I’m not sure I want
to keep the charger on them this winter. I run a 130 watt
dehumidifier on the boat to keep the chill out, but otherwise it is
not heated. Do I risk freezing the water in the batteries if I don’t
charge them constantly?
I’ve considered removing them from the boat, but I may want to keep
some charge on them from time to time in order to make sure the bilge
pump will run if needed.
A deeply discharged lead acid battery can indeed freeze solid. According to one source, a battery 50% discharged will freeze at 5 degrees.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of tlynchlawSent: Friday, December 09, 2005 9:11 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] simple questionMy batteries are nearing the end of their life and I’m not sure I want to keep the charger on them this winter. I run a 130 watt dehumidifier on the boat to keep the chill out, but otherwise it is not heated. Do I risk freezing the water in the batteries if I don’t charge them constantly?I’ve considered removing them from the boat, but I may want to keep some charge on them from time to time in order to make sure the bilge pump will run if needed.
If you give the batteries a charge once a month, that will do.
— In freedomyachts2003@yahoogroups.com, “tlynchlaw” <pass@t…>
want
is
don’t
keep
bilge
