Single ply sails
Does anyone have any info on changing to single ply sails. I now have wrap around on my 28 ck. These have to be the worst design ever put on a rig. I’m tacking through 130 degrees true. Any higher and the boat falls on its face. The sail shape on the lee side looks like the sheets of a well frequented brothel. I cant even imagine the dissapointment Hoyt felt after reality set in.
So what I need to know is what can I expect in improved pointing ability going to single ply full batten and large roach. Money is an object so just ease of handling isn’t reason enough. I have come to the conclusion that this boat is a motorsailor at heart. Maybe the only answer for better pointing ability on a Freedom ck is a 3 bladed prop. Thanks Numbknots
Two comments:
The F-28 ketch is not a “hot rod”! The PHRF and other handicap numbers for this boat support this. It’s a cruising boat, and given its hull shape will never be an upwind/upwave rocket no matter what rig you put on it. That said, the Freedom 40 ketch, with wrap-around sails acquitted itself very well in cruising boat races, both in the early '80s, and more recently.
I don’t know whether you have one of the early F-28s with a centerboard, or the later ones with ugly grafted-on keel. I doubt that this retrofitted keel idea helps the F-28’s speed (but adds room in the cabin).
If the sails you have are as old as the boat, they’re likely stretched out, and would need to be replaced. Lastly, you need to seek others with this boat (F-28, 33, or 40), to get an idea of what you are doing right, and wrong, with your sail trim. Herm
Numbknots, have a look around on this board; there are discussions about single ply sails that you find interesting.
Here is GPS track of my Freedom 28 Cat Ketch, centerboard model, single ply sails, “conventional” boom and high roach sails with full battens. Boat is striped, no extra weight at all, flat waters. As you can see, boat can perform very well.
It is true that fully loaded in cruising mode she wont perform as well, After putting 3000 miles last season on a boat, I would say, that she can sail, albeit not so close to wind, I’d say 50 degrees is a right number.
Her PHRF number actually put her in “Somewhat fast” category; it is 186 for centerboard model. It is as fast or faster than similarly sized cruising boats.
For fixed keel model PHRF numbers are anywhere between 186 and 240 (US Sailing website has a table), lower number indicates that boat can be brought to decent performance.
I’m impressed with your tacking angle! See what a modern set of sails and a good skipper can do!
To be frank, GPS tracks impressed me too. I did a few test runs after I bought the boat, fixed it and cleaned a bottom. I did test runs in different days and conditions, trying to exclude tide interference.
The boat is very deceptive, she doesn’t feel like going upwind well – too quiet, very little drama compare to “other” boats. Later, looking at computer screen, I couldn’t believe in what I see.
Also, I raced cat rigged dinghies and beach catamarans, I guess, single sail on a mast is something I know how to read.
Reading replys to my question on single ply sails. I wonder what the phrf ratings are for the double ply sails. I have sailed a number of boats over the last 30 yrs from sailboards multi hulls catamaran trimarans
and monohulls. I can read a sail and get around bouys competively. Last boat I had was a 25 O’day not a scorcher by any means but I always finished around #3 position in regattas sometimes better sometimes not. With my 28ck I’ve never done better than last place. For instance today I thought I would try to see where I would finished in fleet if I started way early. My start time was 1:28 so I started at 12:46 staying out of everyones way though. Winds were 12knts nice day right, I finished 2nd to last just in front of a san juan. I beleive the other boats were 15 miniutes ahead at finish. I cleaned the botom yesterday so it wasn’t fouled. Now I can go up wind better than 60 degrees but its very slow. Those single ply sails must make an huge difference to have such a fast rating.
Thanks guys Numbknots
Numbknots, do you have fixed keel model?
PO told me that he met Garry Hoyt once, they discussed the boat and Hoyt told him that he has one of the earlier “fast boats”. It is hull#10, centerboard model with simple open interior. So, I guess, it explains a lot. My boat made in 1979, however, at some point first owner replaced entire rig, including masts from wrap-around to conventional rig, he did it somewhere in late 80-s, and my masts looks a lot better than all masts I saw on F28 and F33. So, I guess, I have some king of improved, second generation masts also.
There was F28 racing in NE with wrap-around sails, its PHRF was somewhere in 230 neighborhood.
CrazyRU I have a centerboard model 1981. The interior has the round door on head and very nice wood work. The boat made a single handed atlantic crossing in 81 also traveled into med.
I must have blown out sails plus the added problem of air flow seperation from the round mast on the lee side. Both main and mizzen suffer but main is far worse.
I have about 3yrs of labor in boat an quite a few bucks to match. I figure another 7K for sails etc is what Im looking at to stay in the game. I like the boat very much and am in a place where I’m thinking, is it better to sell while it looks good and put the extra 7k towards another boat that works.
It does have a very large cooler which comes in handy when I’m on the course an extra 45 min. Not sure which will give out first though my ego or my liver. Thanks Numbknots
Numbknots. I have same boat, just different rig.
You can convert the rig into same rig wyliecats use
http://www.wyliecat.com/
Keep your booms and hardware, attach sailtracks to masts and make new, one ply fully batten sails.
I guess, you can make it under $5000
Where are you located? My boat is at Staten Island, NY, if you are in the area, I can give you a test ride.
My sails are getting worn too.
Best
CR
CrazyRU,
Thanks! I suppose its only right to fix the sails as I’ve worked on every thing else. I will check out the wiley website. I was wondering why I don’t see any Freedoms with Fathead sails like the cats and tris all have now. Seems like they would be the way to go if new sails are in order. Numbknots
You will need to figure out how to store fatheads on a mast. They typically have top few battens spread at different angle each, it could be an issue fitting them into cover or taking a sail down in a blow.
However, I guess, Farrier Trimarans guys had to figure out it already.
Bitting the bullet, I have now purchased new fathead full batten sails for my F28 ck(Yes in this economy). New strong track system and mast brackets, rigging and other essentials I figure 7k, but who’s counting right. Trying to get up wind at any cost. Have been tacking at 130 degrees through the true wind. So figure 65 degrees each way.
I was looking at the print out of crazyru previously. I was thinking, hopefully, that the speed of 4kn was VMG come to find out its the actual boat speed going up wind. Figuring a 50 degrees your doing close to twice the distance necessary to get to your destination making your VMG 2kns. OMG, how can a boat rate a 186 phrf with a vmg of 2 kns upwind? Can anyone explain this? Bk
hi
i have found that big differences in performance are possible with decent sail trim
they need to have plenty of draft and not to be oversheeted oversheeting and pinching kill boatspeed i find my 35 ck dosent go below 10 knots app but then a 6 ton boat with a sa/disp ratio of 17. 5 isnt going to.
as a guide if you are reefing in 17 knots of wind its about right. thats top end for a standard #1 genoa in a racer. we dont reef til its nearer 30 knots so i think more area is required.
pointing angle is dictated by hull shape you can achieve less by having bad sails but the hull sets a limit on how close you can point
im going for gigantic sails when i can afford to and hopefully push s/a displ up around 22 and with better shape use the area more effectively im quite sure this will fix things , our tacking angles are fine but the sails lack the drive you would expect from their size, which i put down to bad shaping.
anyway why worry, a freedom is still unbeatable as a reaching machine and when no one can set their kite because it s too tight a reach we can set a dirty great staysail and sail past boats that leave us for dead normally.
and running get a gigantic cruising chute and get her surfing waves its ace! only way off the wind she dosent plane like a sportsboat so the j boats get away from us with ease.
dead running is a bit of a problem for us as the staysail gets blanketed by the mizzen im coming to the conclusion that offshore its faster to gybe the downwind angles even if it means dropping it and hoisting again. 130 apparent downwind is our optimum angle very quick indeed with main over to windward and a big cruising chute up. 8 + knots in a good breeze
a freedom cat ketch is a fast comfortable cruiser that steers herself upwind and off the wind sails at hull speed with a comfortable sea kindly motion and takes heavy weather in her stride. which is precisely what you want to go places further than just around the bay. they were never designed to race even back in the 70s and if you compare her to the average 70s cruiser , shes a rocketship.
perhaps you want a raceboat like a j boat a superb modern cruiser racer which is as inovative as freedoms were in their day, and actually planes downwind at 15 knots, incidentaly also built by tpi who made freedoms
most sane people round here lust after j s and the 109s+ 105s dominate the doublehanded racing classes in the uk but their so expensive and cant dry out and have rod rigging you have to change every 5 years at great expense so there still a compromise
a damn fast one though that gives us 8 miniutes an hour on handicap.
phil, “kusi” uk
Hi Numbknots,
I’m very interested in your changeover to single-ply sails. How did you (or will you?) fix the track on the mast, transfer wishbone hoist etc. and of course how is the performance?
Martijn
So I dropped the 7k into new fathead full batten single ply sails withlarge roach and new strong track system. I still use the wishboom system from old rig as switching to conventional booms was a budget buster. What I found was not much difference in pointing ability overall. Maybe a little in speed and angle to wind but not 7k worth. Faster off wind and easier on eyes to look at sails now which is nice. I did find a problem using the wishbones with a fixed luff sail. Going off wind the tack no longer follows booms around mast so the foot tightens excessively once set for dwn wind. Tightens so much so it pulled the cars out of track on both main and miz at tack. Figured it out finally and now loosen the outhaul quite a bit to ease foot. Can’t let either saill out much beyond 90 degrees like before, which I miss, going dwn wind as it puts to much pressure on new strong track at batten connections. I’m not sure how much new sail area I have now but it must be a 1/3 bigger. My angle up wind is 50ish but my speed is around 4knts at 6o degrees things come together nicely but nobody plays that game do they. Thanks guys Bk
Numbnots,
The problem you describe when sailing of the wind is common on all yachts with sail on track; if you sheet out, the sail tightens in stead of loosens, what you want on a run. You need to loosen your outhaul or - on a wishbone rig - loosen the choker.
Michel,
Thanks for info. I did figure that out, only a little late though. Sailmaker fixed the tear in mizz and we put larger slides at tack and head. Also now have a strap at the tack of each sail holding the lowest car fast to mast. Sails do look very good! Now I need to work on rigging the stay sail and chute. Bk
I also have 2"wide webbing straps around the mast with D-rings on both ends to keep the bottom slide (and the track) to the mast. I pulled the lowest part of my mizzen track off the mast too, like you. Because we lack the sail being laced to a boom, there is much more tension on the foot. You could alter this by hanging the front of your wishbone a bit higher up the mast.
Michel,
I did want to raise the booms a bit but sailmaker thought different. Booms are a little more towards level than I would have liked but seem to work. I would think that having them at a steeper angle would also deflect some of the pressure upwards instead of so directly fwd. I cant really raise them now because as I dont want to drill that carbon fiber mast anymore. I just have to be careful and release outhaul religiously.
I was reading one of your posts last night and liked what you had to say about rigging main sheet from each side of cabin top. Mine is rigged from center and think it would be more efficient if I changed it and the mizzen also. Just have to look at the wiley cat set up. Hey, thanks for all this information. Im just guessing and scratching my head most of the time with this boat. Bk
