Here are some things I learned from buying
my F30 in July:
Have
tools with you, including digital camera (helps remember what you looked
at), plus if the surveyor falls overboard, have a backup.
Get
a well known surveyor! Or at least with a national group.
Work
you way outside to inside don’t skip any steps along the way.
Work
every system for as long as time permits. If you can not see the
lights on top of the mast during the day come back and look at it at night.
Sounds picky but unless you have suction cups on your feet and heights don’t
scare its going to cost some boat bucks!
Look
at everything the surveyor looks at plus everything he doesn’t look
at.
Sea
trials are very important not just a two hour cruise. It takes two
hours just to shake down the diesel! Full power 20 minutes, mid
power 20 minutes, etc, reverse which way will it walk, does it have enough
guts to stop and reverse in a certain length. Is the screw matched
to the engine and boat? Again test every system, all sails, clam
cleats, etc again.
Engine
should have a compression test it will tell you a lot. Look for oil
leaks, engine bilge, check stuffing box under load, especially in reverse
different torque direction. I have a very good solid engine its
starts on the first flick of the key, but it has an elusive oil leak,
waterlock is cracked (2 boat bucks), mixing elbow was clogged with carbon,
engine shutdown going into Key West (10 very large boat bucks)
Anchor,
chain, rope inspect it all.
Check
every hatch, seals, and dogs. Each dog cost at least $20.
If
a floorboard needs to be unscrewed to get to bilge do it.
I got a good solid boat but all of the
little things that broke only short time after I signed the paper almost put me
in the poor house. Average price for a F30 is somewhere between $35k and
$55k, not peanuts and if the broker tell you not to dwell on the little things
or cosmetics I would tell him to take a hike!
Bob
[mailto:FreedomOwnersGroup@yahoogroups.com] On
Behalf Of Sward
Sent: Monday, October 15, 2007
2:25 PM
To:
Spider cracks
Freeman,
I have a friend that was looking at that boat too. I saw pictures
and a friend who is a surveyer looked at it and the cracks are not just
superficial, the deck is wet. This friend is not interested in that boat
anymore. I’ll try to forward pictures she took of that at your email
address
Sward
Havelock,
NC - not far from Oriental
T <fairways31@yahoo.com>
i believe the 32 had a run with some “bad” gelcoat batch that
caused it advanced composites come to mind Boston whaler had same issue at the same
time.
but i have them on my 1999 35 so who know just a cosmetic problem
but irritating
Freeman Dodsworth
<freemandodsworth@yahoo.com> wrote:
All,
Thanks for the great response to my newbie questions. Yet another: I
am looking at an F32 down in NC (via YW of course) and the broker
reports extensive spider cracks on deck and in the cockpit. He
further states (being a broker after all) that “every Freedom he has
ver sold had this problem”. After I choke down the 5 pound grain of
salt required to swallow that remark, the question remains: Is spider
cracking a problem endemic to Freedoms? Should I expect to see a lot
of this as I look further? Thanks again for your kind attention.
Freeman
Tonight’s top picks. What will you watch tonight? Preview
the hottest shows on Yahoo! TV.
“Life is a Reach, then you
Jibe”
SWARD
