I’m investigating tank monitoring systems at the moment. In the course of that, I found a very nice piece of software that helps you calculate the contents of odd shaped tanks. And more, it calculates the relation of the liquid level in the tank to the volume of the liquid in the tank for heigth levels 20%, 40%, 60% and 80%. The software is made by BEP Marine, a company from New Zealand that produces lots of marine electrics products. They are widely available in the NL’s.
I use a much more complex system… I start with an empty tank and pull into a dock with a metered gauge. I then stand at the fuel/water gauge and have Sue start filling the tank. At 1/4, 1/2, 3/4 and full I have her record the readings. I then stick a label next to the gauge with the amount in the tank at each level. This does away with any calibration effects from the measuring level and is just plain simple.
We don’t have metered water connections here, at least I’ve never met one. For fuel, I do the same drill as you do, only I seldom fill up the tank, because then it sits too long.
We have terrible problems with condensation in high humidity parts of the country here. We try and keep our fuel tanks full at all times. The diesel actually keeps surprisingly well for years and if I’m not mistaken your diesel over there might even start out at a higher cetane rating than ours (not too sure about that one). The old Perkins are not so picky as their newer higher compression cousins.
Thanks for the software lead. I’m going to be making some odd shaped tanks soon. One is to replace the swiss cheese one and a new one to go in near it. That software will give me a good idea of how much tankage I want to add.
The story of condensation in diesel tanks goes around here too. But I’ve never found a drop of water in the drain well of any of my boats (all Freedoms). Wit the sandwich hull, the headliner and the diesel tank sitting in the middle of the boat away from the hull and inside a wooden box with airspace all around the tank, condensation won’t be too bad. Only on the inside of my deckhatches there is condensation.
I’d fill a container of known volume and then calculate [liters/gallons] per minute. Record the time at which it gauge reads 1/4, 1/2, 3/4 and full, and then use this to calculate actual volumes. My diesel tank is incredibly non-linear. However, I’d guess that we’re talking about a water tank here, as I’ve always seen well metered fuel dispensers!
Unless you have some way of de-humidifying the air that’s drawn into the tank through the vents, you’ll ALWAYS get condensation in a diesel tank…for the following reasons.
The fuel that leaves the tank in the inlet line to the filters and thence the engine is not all used by the engine. That which goes back into the tank (via the return line) is warmed, at least slightly. The warmer the fuel, the more it is “expanded” in the tank itself, and the warmer the air space (in the tank) above the fuel.
The moisture that is driven out of the air in the air space by this process falls to the bottom of the tank. The (cooler, more moisture laden) air that replaces the burned fuel flows in through the vent line. As the fuel in the tank cools (and shrinks), more of this air flows in through the vent line. No matter how well the tank is insulated, condensation occurs on the inner walls of the tank when the cooler outside air meets the warm “top surface” of the fuel and the tank walls which have been warmed by the fuel. It also occurs when warm, moisture laden air meets cold fuel & tank walls.
As the outside air temperature rises and falls, the air in the space above the fuel “breathes” in and out, and more moisture gets into the tank. Any differential in air & fuel temperature is going to result in moisture migration, but the moisture in the tank (that’s settled under the fuel) is never going to migrate out.
Less air space = less moisture laden air within the tank = less condensation within the tank…every time.
If your tank consisted of a collapsing bladder (closed, unvented system), you’d never get any water in the fuel that wasn’t there when you bought it.
All of this holds true only when there’s humidity IN the air. As the outside air temperature approaches freezing, there is less humidity (and thus less water available to condense). It may be that your winter air temperature is such that you aren’t getting much of this in winter. It’s at it’s worst when it’s foggy outside.
Of course you’re totally right with the theory, but nonetheless I never found water in the drain well of the diesel tank or in the Racor separators. So there is probably not much condensation water in my tank.
Our Freedom is the first boat I ever saw where the vent line for the tank has a shut off valve. Such a sensible addition and I never thought of it before.
That shutoff in the vent line is just there in case you find yourself in conditions where a rollover is imminent…
(tongue firmly in cheek)
Actually, it’d probably be a good idea to shut it when filling the tank (to prevent foamed fuel from overflowing…or liquid fuel if you get really lunchy and fill the tank up to the level of the deck fill).
If you shut it when you went off and left the boat, then a temperature rise would pressurize the tank…which I can’t see as being very good for anything…especially since the weak point in the system is probably the hose-clamped connection between the fill hose and the tank itself…one of the places that you don’t want to discover a leak when off on a trip…
Another weak spot is likely to be the o-ring in the deck fill…and if that “pops out”, the next rain is gonna put a whole lot more water in the tank than whatever condensation that might have occurred would.
But then again, that pressurized fuel might “only” find its way through the filters, past the fuel pump, through the injectors, and simply flood a cylinder or two. No worries there, it’d probably just run past the rings (by the time you got back and restarted the boat) and just end up diluting the crankcase oil a litte (tongue in cheek again).
I recently studied a couple of yacht disaster reports (Fastnet Race 1979, Queen’s Birthday storm 1994 btween Fiji and NZ and Sydney-Hobart Race 1998). You’d be amazed how often water was entering through small or big built-in holes causing problems. Even when knocked flat you could get water in through the diesel vent line. Ever thought of what would happen in a knock-down if your cockpit locker hasps have no locking mechanism other than a padlock? Right, I am replacing my hasps with a version with a swivel padeye to secure them without padlock. And I’m making a securing pin in my companionway washboard. And I looked up the lids that were supplied with the transom air scoops and put those lids with the safety gear. All other dorades I replaced with modern Plastimo ones with a self closing mechanism in addition to a manual lock from inside. I also replaced the large flat Perko anchor chain lid with a swan neck type hawsepipe with lid. Look at all modern boat factory yachts; they are outfitted with vents and slides and grids as if they are RV’s and only have to cope with vertical rain.
If these are the Perko hasps, my experience with them is that within a year or two they corrode and don’t swivel. Perhaps that’s my lack of exercising them, but this is what has happened to mine.
When you get ready to go out (and no longer need the security of the lock), you take off the padlock and replace it with a small, snag-free snap shackle (or a mini-carabiner)…or a whittled stick for that matter.
You could keep it tethered to the hasp with a piece of light line and it would always be there where it’s supposed to be instead of down in the cockpit grate or drain somewhere.
Smart guys you are! I thought of a wooden dowel but those would get lost in a day. But a smal carbiner with as piece of string is a good idea. Anyone has a KISS way to secure the washboard?
There’s a tradeoff between function & beauty here…
If you use slide bolts (on the inside of the washboard, into holes in the trim adjacent to it), then the board is no longer “flat” when storing.
For pure utility, a vinyl strap with the lift-off curtain buttons (not the lift-a-dot) would do it.
You’d put a “male button” (the kind with a screw in the center) in the bulkhead on the cockpit side centered below the washboards and another inboard opposite it (behind the ladder, below the bottom of the companionway), and run the strap up, over, and back down. It would have to be strong enough to hold, but thin enough to allow the hatch to close over it (but you’d only use it when you “might need it”…too wide and you’ll run into problems with the curve at the top of the washboards.
You could then release the strap from either the cockpit or inside the boat.
For sure you don’t want to close the hatch and put anything in the hasp if anybody’s down below…the time it might take them to kick their way out might be more than they have to save themselves…nevermind if the helmsman goes overboard or gets incapacitated.
The reason not to use the lift-a-dot is that little male spike would be prone to “holing” a knee or a bare toe.
On your “whittled dowel”, you could always drill a hole in one end, tie a piece of small line (like nylon mason’s twine) on it in a loop, then pass one end of the loop through the hasp hole, followed by the dowel through the loop end that you passed through the hasp, cinch it down & not lose that dowel. When time comes to put the padlock back on, just undo it, leaving the loop tied together. Same works for the carabiner, the “dog leash snap” or anything else. If any of them are “loose”, sure enough they’ll end up “gone” when you take one loose to get something out of the locker.
Two of the three swivel hasps have failed on my 13 yr old boat (F35). Both failed at the swivel. Apparently they just push the swivel through the hasp and swedg it in place just enough to let it swivel but stay in place. With any load it will pop out of the hasp. Not a real secure device for security. Offshore I found that the swivel can rotate and could align itself in the open position, so a pin of some sort is still a good idea.
I suppose you had the Perko hasps. They are made of Zamac (zinc/aluminum) with a layer of chrome that keeps them shiny until the warranty is gone.I think the zinc is added to make them heavier, so they feel like iron. Zamac is only suitable to cast Dinky toys, i.m.h.o… There are now reasonable quality (made in China) cast stainless replacements.
I was thinking of a slide bolt, but then with the bolt on the trim edge and the hole (2/3 of the way) in the washboard. I was still chewing on the best place to mount the slide bolt. You don’t want to tear your clothes when entering the cabin. So the bottom outboard corner is probably the best location; the washboard is so low there that you can reach over it from outside to open the bolt.
To your question about hatchboard holddowns. I’m trying to come up with a better method but on my old boat I screwed in eyestraps on both sides inside and outside of the companionway below the top of the lowest board (if yours is in several sections like mine). I ran lines on each side. They could be released from inside or outside and used to hold down 1, 2 or all of the boards and the eyestraps were on the sidetrim so not where they could be stepped on. I did not have to drill holes in the boards for the lines as there was space to get it through even with all the boards in.
It worked well but involved either getting the tension right or retying each time. I’m considering this approach again but maybe instead of eyestraps small clam or jam cleats.
Alan
