Posted by Paul Monette (plmonette@…>)
Joe,
I agree 100% with your observations about the different wind conditions.
Paul Monette
#128
On Wed, Sep 17, 2008 at 8:40 AM, Joe Conron <joeconron@…> wrote:
Doug,
PHRF ratings are a form of time-on-distance handicapping. In this system, each boat is given a provisional rating that estimates how much longer it would take that boat to sail one nautical mile compared to some baseline “imaginary” boat.
The ratings take into account (among other things) waterline length, displacement, sail area, and keel depth.
Then, local PHRF organizations are supposed to record finish times for sailed races and adjust the rating based on actual performance in that area (ratings really vary based on local conditions*).
So, the way finish position is computed is as follows:
Take the smallest PHRF hdcp time from all competitors, and subtract that value from every competitor’s hdcp.
I’ll assume that the E22 was the fasted rated boat in the fleet, so, E22 rates about 120 and you rate about 240 (only if you hoist your staysail – if not, then your PHRF should be about 255**). Hence, E22 gives you 120 seconds per mile, and gets zero seconds per mile from everyone else.
Your race is 10 miles, so, your adjusted finish time gets adjusted by subtracting 10*120 = 1200 seconds from your actual finish time. Similarly, the J24 rates about 170, so it gives you 70 seconds per mile.
- The F21 is a great light air PHRF competitor, or when most of the course is off-wind. On the other hand, if wind is in the ideal sailing range (10 – 15), and much of the course is upwind, an F21 will find it very hard to finish in the top half of a good fleet of sloop-rigged boats.
** In the north-east, F21 rates 255 as a cat rig, and 243 as a sloop rig
Best regards,
Joe Conron
Former owner F21 #179
From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of Doug
Sent: Tuesday, September 16, 2008 9:22 PMTo: freedom21@yahoogroups.com
Subject: [freedom21] The Race
We sailed the race Saturday, it was a 10 mile race. My boat came in fith place but with the handicap we were fourth. I got beat out by an E22, and 2 J24’s. The race was a lot of fun, it was so much fun for my
wife that she can’t wait to enter the next race. I still don’t understand how the handy cap is equated, is it 240 seconds for each NM? and then is it subtracted from your over all time in seconds? Could someone please clarify.
10 NM race2h 53m = 10380240s * 10 nm = 240010380-2400=7980Is that the correct way to figure out your corrected time?Thanks,Doug
