Topsides blisters
Posted by Chuck Bates (c3g2b3@…>)
I have Freedom 33 CK #58. She has developed blisters in the topsides on
the port side of the boat.
Has anyone any experience with topside blisters? I’d like to know what
the cause is, so I can determine a repair technique that will last.
Chuck Bates
I can’t imagine osmotic blistering on the topsides. Where in
relation to the ports is this occurring? Have the topsides been
repainted? Are the blisters on the side of the boat more or less
frequently exposed to sun, assuming you keep your boat in the same
slip most of the time. Can you put a picture in the photo section?
What part of the country?
— In freedomyachts2003@yahoogroups.com, Chuck Bates <c3g2b3@d…>
topsides on
what
last.
Chuck Bates
The blisters are in the hull and are unlikely to be related to the
ports. The topsides have not been repainted and are in an area that is
partially shaded from the sun by the pier. The boat is located in
Oriental, NC. I will try and put a picture in the photo section later
this week.
Chuck Bates
Dave_Benjamin wrote:
I can’t imagine osmotic blistering on the topsides. Where in relation to the ports is this occurring? Have the topsides been repainted? Are the blisters on the side of the boat more or less frequently exposed to sun, assuming you keep your boat in the same slip most of the time. Can you put a picture in the photo section? What part of the country? — In freedomyachts2003@yahoogroups.com, Chuck Bates <c3g2b3@d…> wrote:
topsides on
the port side of the boat. Has anyone any experience with topside blisters? I’d like to know
what
last.
Chuck Bates
------------------------ Yahoo! Groups Sponsor --------------------~–> Meet the McDonald¿s® Lincoln Fry get free digital souvenirs,
Web-only video and bid on the Lincoln Fry prop charity auction.
http://us.click.yahoo.com/2YkgMD/fV0JAA/Y3ZIAA/A1TolB/TM
--------------------------------------------------------------------~-> Yahoo! Groups Links
<> To visit your group on the web, go to:
> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
Yes I have the same problem in the hull above the waterline and below
the deck line… I think my problem originated in a “leaky” stern
pulpit rail fitting which I removed and rebedded. My blisters were only
in the pulpit area on one side and corresponding transom. I drilled
the blisters and most were damp but the balsa had not suffered YET. One
hole low and alomst down to the boot stripe produced about 4oz of water.
Amazing to say the least. I chose to ignore the minor cosmetic problem
at least for the time being… Probably some day the gelcoat and damaged
balsa (?) will have to be removed and replaced. WOW!! This is F33
#55, Lady Marion.
Chuck Bates
Yahoo! Groups Links
Leaks around the stern pulpit seem to be a common issue amoung the 33s. I was told that the original owner of mine (Hull #51) had this problem on the stern quarter and some major repair was needed including balsa removal etc. The owner sued Freedom at the time. In addition to the repair they cut additional drainage holes in the teak toerail to permit water to run off. I don’t see exactly how the water intrusion occurs since on mine the pulpit stanchion bolts don’t go through the cored sections of the hull. The rub rail seemed a possibility but it doesn’t seem designed in a way that would allow intrusion.
If there are blisters occurring due to water in the core then it would be a lot cheaper to fix it sooner then later.
Alan
Sent: Tuesday, February 08, 2005 11:13 AM
Subject: Re: [freedomyachts2003] Topsides blisters
Yes I have the same problem in the hull above the waterline and below the deck line… I think my problem originated in a “leaky” stern pulpit rail fitting which I removed and rebedded. My blisters were only in the pulpit area on one side and corresponding transom. I drilled the blisters and most were damp but the balsa had not suffered YET. One hole low and alomst down to the boot stripe produced about 4oz of water. Amazing to say the least. I chose to ignore the minor cosmetic problem at least for the time being… Probably some day the gelcoat and damaged balsa (?) will have to be removed and replaced. WOW!! This is F33 #55, Lady Marion.Chuck Bates wrote:>I have Freedom 33 CK #58. She has developed blisters in the topsides on >the port side of the boat. >>Has anyone any experience with topside blisters? I’d like to know what >the cause is, so I can determine a repair technique that will last.>> >Chuck Bates>>>>>> >Yahoo! Groups Links>>>> >>>>> >
Chuck,
Sorry I got confused and thought the blisters were in the side of
the house. I’ve read about Oriental. Sounds like a nice area. A
while back I noticed a F-33 for sale in Oriental. It’s not yours is
it?
that is
later
this week.
Chuck Bates
same
section?
<c3g2b3@d…>
topsides on
know
what
last.
Chuck Bates
Yahoo! Groups Links
topsides on
what
last.
Chuck Bates
Chuck
My F40 AC (Hull 61) has significant blistering above the water line
on the port side stern quarter. When I bought the boat, I also had
major blistering below the waterline. Everything above the waterline
showed bone dry on the moisture meter from day one. I didn’t open
any of the blisters above the waterline. There’s really NO place for
water intrusion to have occurred other than the rub rail attachment
screws. My stanchions are all attached only to the toe rail. My
pushpit is through bolted in the deck. These blisters are apparent
only below the rub rail and extend forward only to the bulkhead
separating the port lazarette from the aft cabin. I removed some of
the paint on the inside of the lazarette which permitted “seeing”
the core through the final layers of glass & mat. There was
no “darkening” or evidence of water intrusion into the core.
There was significant water intrusion into the MAT layers below the
waterline, but I never saw any evidence that any of it got into the
core (even in the last places to drain/dry in the 6 month process of
drying out the boat).
My repair consisted of grinding off everything below the waterline
down to the first layer of mat, then regular (at least weekly) steam
cleaning to heat up the hull and drive out the water (assisted by
summertime Texas Gulf Coast temperatures). It took 6 months to get
things dry. As the “glycol mess” continued to from the outer mat
layer, it left behind “dry mat” spots (no remaining resin) in
numerous areas. These were ground out down to solid glass. In no
case did this require grinding BEYOND the outer mat layer. The glass
below that was solid, the core was dry. (The wettest part of the
boat was the “barn door rudder” which POURED water (for days) out of
the core after we drilled holes “high and low”. If I had it to do
over again, the whole repair would have been a lot faster if
we’d “kept on grinding” when we got to the first mat layer, but we
really didn’t know at that point whether or not the core was wet,
and I sure didn’t want to grind off everything down to the balsa and
build it back up.
We spot-filled the ground out areas with pieces of mat & resin, then
applied a complete mat layer on top of that and finished off with
vinylester (5 layers) epoxy and reapplied bottom paint. That was 7
years ago and there is no evidence of further blistering below the
waterline. The end result is, below the waterline, I have one more
mat layer between the core and the water than “anybody else” (and no
gelcoat).
The conclusion of all involved is that there was a problem with the
mix in the first layer applied to the gelcoat in the molding
process. Maybe the mat was contaminated, maybe the mix wasn’t right,
but the breakdown that occurred probably BEGAN internally (as
opposed to water intrusion)and the resulting failure of the gelcoat
in the blistered areas permitted the water to intrude and further
exacerbate the problem. Lots of the (particularly deeper) blisters
were a really nasty gunky thick mess that was highly “chemical” as
opposed to “watery”. It really appeared to be uncatalyzed resin.
The very existence of the same type of blistering in areas ABOVE the
water line would bear out this conclusion, particularly since they
are highly localized.
Your options for repair are fairly limited. If your hull is in need
of paint, then grind them out, fill them back in, fair the repair
and paint. My hull still has good gelcoat (after 24 years) and I
don’t plan on doing anything about the topsides blisters until I’m
ready to repaint the whole hull.
They aren’t getting “worse”. I don’t think they’re structural, and
they haven’t resulted in any apparent cracking of the overlying
gelcoat (Yet).
