Transition to LFP house bank
Wow thats a thorough check list. AI is pretty amazing. I have used it to help me with some things but i have found it loves to blow smoke up my ass and placate me with half ass answers occasionally but it sure is good for most things.
For my Lithium conversion, i was going to wait until my Lifeline house batteries get tired and replace with what ever looks like a high quality battery with a built in BMS. Id keep my starter battery as an AGM and use a victron Dc/DC charger to chsrge the house through my AGM. I have some really nice Solbian semi rigid panels on my bimini that can put in about 15 amps on a sunny day so I feel like the house bank will pretty much always be charged by them. Im sure theres other things i would have to change in the conversion but have not done the deep research dive yet.
Eben,
if you have a ‘smart’ externally regulated alternator, consider using it to charge your house bank and use the DC-DC to charge your start battery. You need temperature control on your alternator, especially if it’s small (mine is 135 amp). You can stack DC-DC converters to get more capacity out of your alternator, but why when you can safely go directly to batteries?
I have a Balmar 618 controller which automatically derates the alternator if it gets to 100c.
But you have a choice to make - if you have a small alternator, then the DC-DC might be a better option because, while it will take a lot longer to charge, you probably won’t get hot enough to derate the alternator. In the direct to house bank model, you may reach a point where the batteries are so thirsty the alternator will reach its derating temperature. A properly sized alternator helps - on my list for next season. :slight_smile:
I just have the stock 80 amp hitachi alternator that comes with the 3jh2-te. I hear you about the risks of damaging it. The Victron Orion DC/DC charger should throttle the house batteries from overworking the alternator, No?
I just poked around the internet and noticed that ecoworthy 4D sized batteries are around $400. Thats tempting.
I am an AI enthusiast (don’t shoot me :joy:) but I do agree everything with grain of salt. And you are right, it does blow smoke, I’ll tell it to shut up and color sometimes but ,I admit, a little encouragement after a hard day of boat yoga and zero progress is not hard to listen to.
I made my own alternator temp sensors after paying $50 for a balmar replacement for the third time. In doing so I ordered duetch connectors so I could change the sensors out quickly when they inevitably fail. So I get this box of connectors and bits and pieces with no instructions. I take a picture of them all laid out on a piece of paper and Gemini provided detailed instruction how to put them together. I think stuff like this is pretty cool.
My 40/40 didn’t change when I made the switch. I had three 200 Ah AGMs and switched to three 200 Ah LiP04
if you only have the 80 amp stock with no external regulator, then you’ll want to set up your DC/DC so that you’re charging your start battery, and your DC/DC should be set for 40 amps. you’ll never burn out the alternator, but depending on your bank size it might take quite a while to recharge if you’re really discharged.
Updates: I’ve been thrilled this year to have remained totally unplugged from shore power, while having refrigeration, autopilot, electronics, and lights as needed. My setup ended up with four 100w flex panels on my Bimini, two in series connected to a Victron 75/15 controller, and two in parallel connected to a LiTime combination DC-DC converter and charge controller. These both connect to a pair of LiTime 100AH Lithiums in parallel. The Victron and the LiTimes are monitored via Bluetooth.
The series pair of panels optimizes the early light/late light and cloudy conditions while the parallel pair give the highest charge current midday or in bright conditions. Each pair can be operated independently, with their own controller for redundancy.
What I wasn’t getting from that setup was a way to keep the engine AGM topped off via solar, so I added a simple small “reverse” DC-DC module to trickle charge the AGM when the Lithiums were over a certain threshold. I can monitor the AGM via Bluetooth as well and this setup works incredibly well. By mid day most days, everything is fully charged. Even cloudy days rarely go below 70 percent charge. My alternator barely has any work to do anymore.
Good going ! Thats the first time I have heard of using 4 panels in that way. Good idea. I have 2 Solbian SR panels on my bimini and they never sees to amaze me. At high noon they can almost reach 20 amps.
Hi. Does transitioning to lithium affect your insurance coverage? I have heard of people having difficulty getting insurance because of the lithium batteries. Some insurances I have heard also require professional install and are leery of DIY installs.
What’s your experience. I too am considering installing LiFePO4 in my boat
My insurance company did not ask what batts I had or anything else except for boat type and age. Of course I have a little old freedom 30
