Posted by Joe Conron (joeconron@…>)
Peter,
The traveler is through-bolted with 5 inch
SS bolts and barrel nuts – these are what appear to you to be
rivets.
There is definitely balsa core in the
cabin roof and you have wet core. You will have to figure out how far the
core has been compromised and decide how to proceed.
When I removed and re-bedded the traveler
on my F21, I was quite surprised to find that TP did not install the
traveler using the standard approach for through-bolting in cored
decks (over-drill hole, fill w/ epoxy, then re-drill smaller hole through epoxy)
– they just dilled straight on through and inserted the bolts.
Good luck,
Joe
Conron
Formerly 1984 F21 Real-Time
From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of Patrick Weaver
Sent: Tuesday, March 04, 2008 2:14
PM
To: freedom21@yahoogroups.com
Subject: [freedom21] Re: Traveller
etc.
— In freedom21@yahoogroups.com,
“Peter Devlin” <devlin_peter@…>
<<Water has gotten into my cabin roof–I’m not sure where or how much-
-and when it froze, it popped off the washer and rivet(?) associated
with the traveller, on the inside port side. I have seen brown
yucky iquid ooze out from the same place, a bummer the magnitude of
which I can’t or don’t want to consider too much. My inclination is
to remove the traveller “track” completely, apply silicon and re-
attach the track. What are those things holding the track to the
roof? Are they aluminum bolts, or rivets or what? What do you think
of my idea/ problem? Thanks.>>
Peter,
Not owning a Freedom 21, I don’t know if you have a balsa-cored deck
but your symptoms would suggest you do. If so, I can provide you with
some information about making repairs. The bummerness may not be of
the magnitude you anticipate if the problem is not too old. However,
if you DON’T contemplate it, the problem can increase in magnitudinal
proportion.
As far as bedding, in general, I would not recommend silicone unless
you are bedding something that must be removed later. Polysulfide,
while much sloppier to work with, gives better results. Also, when
bedding, do not fasten down all the way until after the compund has
cured or the compound will all squeeze out and your item will be
without a bed.
Let me know if the core repair info would be of assistance and I will
dig it out. I am currently making repairs to the deck(s) of MY cat
which is of the two-hulled variety.
Patrick
