Posted by Wilf Bishop (wilf.bishop@…>)
Regarding mast lifting on the F21 - I posted two articles on this on our site. One describes the gear needed and the other shows step-by-step photos of the whole operation. Although my F21 mast is only 30ft long I guess that the F25 mast at 40ft is no greater problem - only needing longer sheer legs? I find that with good sheer legs and lifting tackle the weight of the mast is not the problem - only the possibility of the mast moving around in a stiff breeze when suspended from the hoisting tackle. So lift in light wind conditions & have two helpers to steady & guide the mast foot and everything should be OK? Also treat yourself (and your helpers) to a stiff drink afterwards.
Wilf Bishop
F21 DAYDREAM
UK Sail No 205
Sent: Tuesday, October 17, 2006 10:22 PM
Subject: Re: [freedomyachts2003] Re: unstepping mast on a 25
Please be careful. I have a Freedom 21, that I trailer. I unstep the mast every time. It gets heavy all of a sudden. I wouldn’t want to hear about someone dropping the mast.
Bill… Blue Lightning F21
Sent: Tuesday, October 17, 2006 4:31 PM
Subject: [freedomyachts2003] Re: unstepping mast on a 25
— In freedomyachts2003@yahoogroups.com, Herman and Gail Schiller <hschiller2@…> wrote:>> I had an ‘82 F-25 with wing mast, so some of this may not apply to > your boat which I assume has a round mast. I don’t know how the mast > is attached; the wing mast is held down by the halyard, vang and > reefing lines. If it’s like my F-28, then the mast is also wedged in > place by a rubber wedge compressed by the alloy collar at the deck > level. The boom is attached to the mast very conventionally with a > clevis pin and cotter pin. I lifted the mast out of the boat using an > A-frame made of two 20 foot 2"x4"s, and to increase power, I used > the mainsheet tackle. The A-frame was steadied by lines to the bow, > and the stern of the boat. the bottom of the A-frame was also tied to > the stanchions to keep them from moving. I think 16 foot 2x4s could > do the job provided you have someone securing/controlling the bottom > of the mast as it comes out of the hole. I also had two wooden > cradles, one each on each of the pulpits, with the one on the front > pulpit having a trailer roller to let me move the mast by myself. I > secured the lifting line at the gooseneck, and it looped around the > mast. The loop was lifted by the lifting tackle to just above the > center of gravity of the entire mast. If you use 16’ A-frame, you’ll > need to let the loop up to a spot low enough to withdraw the mast > from the deck, but as high as possible. This situation will be below > the center of gravity, and when the mast is free of the deck, it be > “top-heavy”, and hence must be controlled by someone, while the guy > on the mainsheet tackle slowly lets the mast down to the deck.> Good luck, Herm SV Impulse> My boat is also an '82, with a wing mast. The yard is pulling the mast with their crane, but they claimed that they needed to ‘unrig’ the mast, ie detach all the shrouds and stays. I told them the boat has neither shrouds nor stays. There is only a running backstay and the boom, which can be unfastened at the gooseneck in less than a minute. I’m going to have them simply lay the mast on the deck with several foam blocks fore and aft, beneath it. I’ll secure it with tie downs.> At 08:07 AM 10/17/2006, you wrote:> > >I just bought a Freedom 25 and will be trailering it home (about 110 > >miles). I didn’t get a> >chance to look closely at the gooseneck. How is the boom attached to > >the mast? Also, other> >than the bolt at the mast step, are there any other attachment > >points? I’d like to prepare it for> >trailering myself because this yard where the boat’s located (New > >England) is nickle and> >diming me for everything. Any other advice on trailering the boat > >would be appreciated as> >well.> >> >>
No virus found in this incoming message.Checked by AVG Free Edition.Version: 7.1.405 / Virus Database: 268.13.2/472 - Release Date: 11/10/2006
