Posted by fgljff (fgljff@…>)
Does the F-25 have a boom vang? If so, where does it attach to the boom and
mast?
mast?
The F25 needs the vang for safety, among many other reasons. The vang
attaches to a bail on the bottom of the boom, and an eye on the deck,
just aft of the mast
boom and mast?
In heavy weather, and broad reaching or running, the F-25 will roll
to the point where the boom will hit the water. Herm
just aft of the mast— In
“fgljff” <fgljff@…> wrote:Does the F-25 have a boom vang? If so, where does it attach to the
boom and mast?
My F25 came with what appears to be a boomkicker to keep the boom up without a
topping
lift. But it didn’t come with a vang. I’d like to put one in. There are two
bails beneath the
boom. The aft one is for the mainsheet. I assume the forward one is for the
vang. But what
kind of purchase do I need? Would two blocks do it? I guess what I’m asking is
how to set a
vang up for this boat.
just aft of the mast— In freedomyachts2003@yahoogroups.com, “fgljff” <fgljff@> wrote:
boom and mast?
topping
bails beneath the
vang. But
what
how to
set a
vang up for this boat.— In freedomyachts2003@yahoogroups.com, “Charlie L.” <clivaday@> wrote:
Do you know the purchase combination to make one up? Is it sufficient to use a
single
block with a becket and a double? Or do I need a double and triple?
boom and mast?
The vang on my F25 hass a 4:1 purchase. It has 2 large Harken fiddle
blocks. Both have snap shackles for attachment. One fiddle is a
ratchet, with cam. 4:1 is barely enough purchase to adjust under a
load, but the Harken catalog shows how to add another block on a wire
to double the purchase. I intend to do this in the near future. You
can learn a lot about rigging from the Harken catalog. Good luck.
Charlie. PS you do need a vang for safety, to keep the boom end from
flying up, especially on a jibe when it will rise, and then slam
down. If you do not have a vang, you can just tie a strong line to
the bail and the eye to keep the boom from rising, until you get an
adjustable vang.
up without a
topping
There are two bails beneath the
is for the vang. But
what
I’m asking is how to
set a
<clivaday@> wrote:The F25 needs the vang for safety, among many other reasons.
The vang
deck,
wrote:Do you know the purchase combination to make one up? Is it
sufficient to use a single
block with a becket and a double? Or do I need a double and triple?Does the F-25 have a boom vang? If so, where does it attach
to the
boom and mast?
