Water in engine pan
Posted by Rick Higgens (higgens@…>)
Hello all, when we were motoring our F30 from CT to RI for the recent
survey there was a little oily water in the pan under the engine. Not
more than 1/2" but I dryed it up after the first day and at the end of
the 2nd day it was there again. I couldn’t see any leaking hoses or
obvious source and the surveyor couldn’t either. And the coolant/oil
levels weren’t lower. Anyone ever experience anything similar that
can give me a hint where to start looking? Thanks…
Rick Higgens
F30 #12
Posted by webmaster (akusinitz@…>)
I can’t explain the water. I have
had the dipstick on my yanmar vibrate loose and some oil get out. It was hard
to locate the source.
Alan
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Rick Higgens
Sent: Wednesday, January 10, 2007
10:11 AM
Subject: [freedomyachts2003] Water
in engine pan
for the recent
Rick Higgens
F30 #12
Is the water salty? That will give you direction as to where to look.Rick Higgens <higgens@…> wrote: Hello all, when we were motoring our F30 from CT to RI for the recent survey there was a little oily water in the pan under the engine. Not more than 1/2" but I dryed it up after the first day and at the end of the 2nd day it was there again. I couldn’t see any leaking hoses or obvious source and the surveyor couldn’t either. And the coolant/oil levels weren’t lower. Anyone ever experience anything
similar that can give me a hint where to start looking? Thanks… Rick Higgens F30 #12
Want to start your own business? Learn how on Yahoo! Small Business.
Rick, If you have fresh water cooling ( a heat exchanger ) your header tank could be overfilled and when the coolant expands it has no space to go so it overflows into bilge if you do not have an overflow tank. Andre.Frank Minelli <myslo@…> wrote: Is the water salty? That will give you direction as to where to look.Rick Higgens <higgens@…com> wrote: Hello all, when we were motoring our F30 from CT to RI for the recentsurvey there was a little oily water in the pan under the engine. Notmore than 1/2" but I dryed it up after the first day and at the end ofthe 2nd day it was there again. I couldn’t see any leaking hoses orobvious source and the surveyor couldn’t either. And the coolant/oillevels weren’t lower. Anyone ever experience anything similar thatcan give me a hint where to start looking? Thanks…Rick HiggensF30 #12 Want to start your own business? Learn how on Yahoo! Small Business.
The best gets better. See why everyone is raving about the All-new Yahoo! Mail.
I do have fresh water cooling but if it were overflowing wouldn’t the
coolant levels drop? Plus it’s for sure not coolent in the pan.
Someone else asked if the water was salty, but I didn’t taste it
(yuck) and couldn’t smell anything obvious. It’s on the hard now so I
can’t do much testing till Spring. Was just hoping someone might have
been down this path before. It’s only in the drip pan and it wasn’t
like filling it up.
— In freedomyachts2003@yahoogroups.com, andre laviolette
<andrelaviolette@…> wrote:
Rick,
Andre.
where to look.
Rick Higgens
F30 #12
Yahoo! Mail.
Posted by Karl F (kfffreemail@…>)
Mine has a drip on the shaft seal…you may want to check there. I tightened the clamps, but will probably put a new shaft seal in the Spring.Good LuckRick Higgens <higgens@…> wrote: Hello all, when we were motoring our F30 from CT to RI for the recent survey there was a little oily water in the pan under the engine. Not more than 1/2" but I dryed it up after the first day and at the end of the 2nd day it was there again. I couldn’t see any leaking hoses or obvious source and the surveyor couldn’t
either. And the coolant/oil levels weren’t lower. Anyone ever experience anything similar that can give me a hint where to start looking? Thanks… Rick Higgens F30 #12
Cheap Talk? Check out Yahoo! Messenger’s low PC-to-Phone call rates.
Posted by Michael G Katz (mgkatz@…>)
What about a leaking stuffing box…I think that could be a candidate.
Michael Katz
Freedom 38 “Acquittal”
Sent: Wednesday, January 10, 2007 11:35 AM
Subject: [freedomyachts2003] Re: Water in engine pan
I do have fresh water cooling but if it were overflowing wouldn’t thecoolant levels drop? Plus it’s for sure not coolent in the pan. Someone else asked if the water was salty, but I didn’t taste it(yuck) and couldn’t smell anything obvious. It’s on the hard now so Ican’t do much testing till Spring. Was just hoping someone might havebeen down this path before. It’s only in the drip pan and it wasn’tlike filling it up.— In freedomyachts2003@yahoogroups.com, andre laviolette<andrelaviolette@…> wrote:>> Rick,> > If you have fresh water cooling ( a heat exchanger ) your headertank could be overfilled and when the coolant expands it has no spaceto go so it overflows into bilge if you do not have an overflow tank.> > Andre.> > Frank Minelli <myslo@…> wrote:> Is the water salty? That will give you direction as towhere to look.> > Rick Higgens <higgens@…> wrote: Hello all, when we weremotoring our F30 from CT to RI for the recent> survey there was a little oily water in the pan under the engine. Not> more than 1/2" but I dryed it up after the first day and at the end of> the 2nd day it was there again. I couldn’t see any leaking hoses or> obvious source and the surveyor couldn’t either. And the coolant/oil> levels weren’t lower. Anyone ever experience anything similar that> can give me a hint where to start looking? Thanks…> > Rick Higgens> F30 #12> > > > > > > > ---------------------------------> Want to start your own business? Learn how on Yahoo! Small Business. > > > > > ---------------------------------> The best gets better. See why everyone is raving about the All-newYahoo! Mail.>
Posted by f35sail (s.goward@…>)
We fought this last summer with our Yamar. Turned out the raw water
pump seals were worn out. For us it was cheaper to replace than
rebuilt . This is discussed in the manual.
Of course once we replaced it took a couple of runs to get the hoses
clamped tight, which is actually what I did first and then replaced
the hoses.
Our F35 is a 1994 and all parts were original.
Good luck
Sam Goward
F35
— In freedomyachts2003@yahoogroups.com, “Rick Higgens” <higgens@…>
Rick Higgens
F30 #12
Posted by Fred Molden (fredmolden@…>)
I was just starting to see some occasional water in the pan and found a
loose hose clamp. I also checked the hoses at that time and found they were
getting soft so I have preemptively replaced all water hoses and have not
had any further leaks. Engine had about 1600 hours.
Sent: Wednesday, January 10, 2007 11:15 PM
the hoses.
Good luck
Sam Goward
F35
Rick Higgens
F30 #12
Yahoo! Groups Links
Posted by ketchman47 (katch47@…>)
Rick- two things I can think of are the stuffing box and the “exhaust
riser”- the piece that the water in pumped into after exiting the
exhaust manifold- check for pinholes rusting through- these have to
be replaced fairly frequently- as often as every 5 years- easy job!
Lenny
