Wench maint.
Hi Everyone,
My F-21 is out of the water and on the hard here in my condo complex,
about a quarter mile away. If you can’t sail, then you can mess
around the boat. It doesn’t get too cold here in Kentucky.
The object of my messing around this time will be greasing the wheel
bearings on the trailer. There’s a very good videotape from a guy in
Texas who shows you how, step by step. I’ll be glad to post here it
if somebody tells me how.
Next, I wanted to do maintenance on my wenches. I seem to remember
somebody posting something on this task, but can’t find it. Any ideas?
Lastly, I need to take the sliding overhead entrance to the cabin off
to replace a plastic track that it slides on. Any advice in that
department?
Thanks for your help.
Allen McClung
Posted by Patrick Weaver (patrick@…>)
I wanted to do maintenance on my wenches. …. Any ideas?>>
First step is to determine whether you have a high maintenance wench or
a low maintenance wench. Chances are, if the wench is on your sailboat, she is a
low maintenance model.
Sorry. It was too good an opportunity for a punster to turn up.
Patrick
-----Original Message-----
From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of Allen McClung
Sent: Thursday, October 18, 2007
10:17 AM
To: freedom21@yahoogroups.com
Subject: [freedom21] Wench maint.
Hi Everyone,
department?
Allen McClung
Change the “e” to “i” and go with that.
I can hardly winch my wench aboard.
— In freedom21@yahoogroups.com, “Patrick Weaver” <patrick@…>
<< I wanted to do maintenance on my wenches. … Any ideas?>>
wench or a
sailboat, she is
a low maintenance model.
Patrick
On Behalf
Of Allen McClung
Sent: Thursday, October 18, 2007 10:17 AM
Hi Everyone,
complex,
wheel
in
ideas?
off
department?
Allen McClung
And if
either of them sees your post you’ll be the one in [hot] water.
Patrick
11:07 AM
Subject: [freedom21] Re: Wench
maint.
Change the “e”
wench or a
sailboat, she is
Patrick
On Behalf
Of Allen McClung
Hi Everyone,
complex,
wheel
in
ideas?
off
department?
Allen McClung
Here is some Archive Info"
"Allen,
When I replaced the ones on “Blue Merle” back in 1996/1997 I was able
to order them directly from Freedom Yachts. However, Freedom Yachts
is no longer in the sailboat business (they have gone over to
the “dark side”) and the parts are no longer available from them.
"Both the Freedoms and the Js (J/22, J/24, etc.)
were built at TPI Composites (formerly Tillotson-Pearson, Inc.), now
Pearson Composites in RI. Common parts were often used.
The current J/22 and J/24 licensed builder in the USA is U.S.
Watercraft (http://www.waterlinesystems.com/uswatercraft.php) also
referenced at the J/Boats factory page
(http://www.jboats.com/jfactory_links.htm).
They show a J/22 and J/24 parts list with the Hatch Slide Extrusion
(part number 10004) – same part for both the J/22 and J/24.
Links:
http://www.waterlinesystems.com/pdfs/j22-parts.pdf
http://www.waterlinesystems.com/pdfs/j24-parts.pdf
-John
Former owner “Blue Merle” (#259 - 1984)"
Date: Wed May 5, 2004 7:23 am
Subject: Re: Barient Winch Servicing
To service F-21 Barient winches - Push down firmly on the plastic
button in the bottom of the hole for the winch handle. It will
release a spring and should lock in place. If the spring does not
lock open, hold it down as you lift the winch drum up.
Mike"
Now you can go mess with your boat.
Nick
— In freedom21@yahoogroups.com, “Allen McClung” <amcclung@…>
Hi Everyone,
complex,
wheel
in
ideas?
off
department?
Allen McClung
