Hi All: Is there a factual case of a wet Freedom hull actually
coming to grief? Or, is it a case of “what if’s”? My f33 #55 has had
some wet spots above the waterline for at least ten years. A result
of leaking stern pulpit bedding. I finally opened up a couple
blisters and must have got out at least a pint of clear water. That
is a lot! However, again I ask how serious is this? There appears to
be nothing below the water line which is amazing. John Jones
— In freedomyachts2003@yahoogroups.com, “John Jones” <a1john@c…>
had
to
Actually wet balsa is nowhere near as bad as rotted balsa. There as to
be a source of oxygen for rot to occur. From a structural standpoint
there is not a significant reduction in strength wilth wet balsa, only
with rotted balsa.
A F-39 went up on the reef at Ano Nuevo many years ago. The boat
sustained major damage from boucing around but miraculously there was
no significant water intrusion inside the boat. The boat was purchased
from the insurance company for scrap value and then the long
restoration process began. Although the outer shell of the hull had
been damaged and the balsa soaked the boat was successfully recored
and is out sailing today.
I’d have no hesitation taking a TPI built Freedom anywhere as long as
it hadn’t been screwed up by ignorant owners.
Water in hulls is not limited to only cored hulls and decks. My concern is with hulls that have entraped water and experience hard freezing temperatures. Andre.John Jones <a1john@…> wrote: Hi All: Is there a factual case of a wet Freedom hull actuallycoming to grief? Or, is it a case of “what if’s”? My f33 #55 has hadsome wet spots above the waterline for at least ten years. A resultof leaking stern pulpit bedding. I finally opened up a coupleblisters and must have got out at least a pint of clear water. Thatis a lot! However, again I ask how serious is this? There appears tobe nothing below the water line which is amazing. John Jones
Posted by williedoylemom (williedoylemom@…>)
We are, hopefully, soon-to-be Freedom owners. Unfortunately major
snow storms have made us put off tomorrow’s survey until Feb. 1.
Darn. However, all this talk about balsa core and wet hulls, etc.
prompted us to give Paul Dennis a call. He’s the fellow who worked
at Freedom Yachts for years and now has his own boatyard, Warren
River Marina. He is the also the person to whom Freedom now
forwards all inquiries. He told us that, in later model Freedoms,
the areas around through hulls do not have balsa in them; that they
are totally glass for a several inch radius. Thus, there is little
chance of water intrusion from those areas, at least. All this
discussion does make us realize that we will need to be careful
about frequent rebedding of stanchions, etc.
— In freedomyachts2003@yahoogroups.com, andre laviolette
Andre.
had
result
That
appears to
SPONSORED LINKS
Sailing schools Sailing instruction Sailing lesson
Sailing course Sailing adventure Sailing
YAHOO! GROUPS LINKS
Visit your group "freedomyachts2003" on the web.
Service.
Speaking for The Mull boats, vintage '86 and newer, the areas of
concern are cabin top penetrations including ports and canvas
attachment points. The deck is solid glass in a 4" band around its
perimeter, so the stanchions, scuppers, deckfills, and cleats are
not an issue. The transoms are solid glass and the hull, 6" either
side of the centerline and fore and aft of the keel is solid
glass as well as a 2" band around the hull below the hull/deck joint.
By all means, exercise due diligence, but don’t be unduly alarmed.
— In freedomyachts2003@yahoogroups.com, “williedoylemom”
worked
they
little
Andre.
actually
has
had
result
That
appears to
SPONSORED LINKS
lesson
YAHOO! GROUPS LINKS
Service.
On my Freedom 33/35 UK built catketch I found the same. The width of
the solid glass seams may be a bit different, but the approach is
the same. One addition: the cabin sides, where the ports are, are
solid glass.
Mind you, solid glass can also suffer from water ingress in the
laminate, especially in vertical surfaces, like the cabin sides
under the ports. The holes for the ports were sawn out, but the open
laminate was not covered in any way.
— In freedomyachts2003@yahoogroups.com, “macks011” <macks04@o…>
joint.
major
etc.
worked
Freedoms,
they
little
My
hard
Andre.
actually
has
had
result
water.
That
appears to
SPONSORED LINKS
lesson
YAHOO! GROUPS LINKS
of
Service.
