On most of my boats I have had a windlass (well strictly
speaking a capstan). Has anyone done this with the Hoyt Freedom 32? I realize
it is a little on the smaller side but I have found them very useful, especially
in a blow or difficult holding. Makes and models appreciated. Obviously a low
profile would be best. Thanks
I have done that. I put in a 12X12 teak door as an
access panel
Sward
ron barr <rwhb@…> wrote:
Has anyone solved the problem of easy access to shut off the
aft head seacocks when leaving the boat on a Freedom Hoyt 32??
Currently I have to get into the cockpit locker – no small
feat for the less nimble! I am contemplating cutting an access panel behind the
head – anyone have ideas? Thanks
I have a Sprint/Lewmar 1000 anchor windlass on my 32 however, I would not get the same type again. I’ve had trouble with it many times. My friend has a Maxwell and if I had to switch out I would go with that one. Reason being, that that model has the motor out of the anchor locker and away from the moisture, and you can gain access to the chain manually without taking the thing apart.ron barr <rwhb@…> wrote: On most of my boats I have had
a windlass (well strictly speaking a capstan). Has anyone done this with the Hoyt Freedom 32? I realize it is a little on the smaller side but I have found them very useful, especially in a blow or difficult holding. Makes and models appreciated. Obviously a low profile would be best. Thanks Ron Freedom 32 Newport RI From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of SwardSent: Friday, September 07, 2007 1:07 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: Re: [FreedomOwnersGroup] Access to head Seacocks on freedom 32 I have done that. I put in a 12X12 teak door as an access panel Swardron barr <rwhb@…> wrote: Has anyone solved the problem of easy access to shut off the aft head seacocks when leaving the boat on a Freedom Hoyt
32?? Currently I have to get into the cockpit locker – no small feat for the less nimble! I am contemplating cutting an access panel behind the head – anyone have ideas? Thanks Ron Freedom 32 Newport RI “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD
the thing apart.
On most of my
boats I have had a windlass (well strictly speaking a capstan). Has anyone done
access panel
Sward
I’ll find out tomorrow night if I can.ron barr <rwhb@…> wrote: Thanks. I agree about Lewmar (and Simpson Lawrence) and have had good luck myself with Maxwells. Do you know which model he has? Ron From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of SwardSent: Monday, September 10, 2007 1:57 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: Re: [FreedomOwnersGroup] Windlass/Capstan for Freedom 32 I have a Sprint/Lewmar 1000 anchor windlass on my 32 however, I would not get the same type again. I’ve had trouble with it many times. My friend has a Maxwell and if I had to switch out I would go with that one. Reason being, that that model has the motor out of the anchor locker and away from the moisture, and you can gain access
to the chain manually without taking the thing apart.ron barr <rwhb@…> wrote: On most of my boats I have had a windlass (well strictly speaking a capstan). Has anyone done this with the Hoyt Freedom 32? I realize it is a little on the smaller side but I have found them very useful, especially in a blow or difficult holding. Makes and models appreciated. Obviously a low profile would be best. Thanks Ron Freedom 32 Newport RI From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of SwardSent: Friday, September 07, 2007 1:07 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: Re: [FreedomOwnersGroup] Access to head Seacocks on freedom 32 I have done that. I put in a 12X12 teak door as an access panel Swardron barr <rwhb@…> wrote: Has anyone solved the
problem of easy access to shut off the aft head seacocks when leaving the boat on a Freedom Hoyt 32?? Currently I have to get into the cockpit locker – no small feat for the less nimble! I am contemplating cutting an access panel behind the head – anyone have ideas? Thanks Ron Freedom 32 Newport RI “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD
The windlass is a Maxwell 1200, VW- which is better than VWC in that you can use two anchors on one wondlass and the anchor chain is accessibleSward <swardfullsail@…> wrote: I’ll find out tomorrow night if I can.ron barr <rwhb@…> wrote: Thanks. I agree about Lewmar (and Simpson Lawrence) and have had good luck myself with
32 however, I would not get the same type again. I’ve had trouble with it many times. My friend has a Maxwell and if I had to switch out I would go with that one. Reason being, that that model has the motor out of the anchor locker and away from the moisture, and you can gain access to the chain manually without taking the thing apart.ron barr <rwhb@…> wrote: On most of my boats I have had a windlass (well strictly speaking a capstan). Has anyone done this with the Hoyt Freedom 32? I realize it is a little on the smaller side but I have found them very useful, especially in a blow or difficult holding. Makes and models appreciated. Obviously a low profile would be best. Thanks Ron Freedom 32 Newport RI From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of SwardSent: Friday, September 07, 2007 1:07 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: Re: [FreedomOwnersGroup] Access to head Seacocks on freedom 32 I have done that. I put in a 12X12 teak door as an access
panel Swardron barr <rwhb@…> wrote: Has anyone solved the problem of easy access to shut off the aft head seacocks when leaving the boat on a Freedom Hoyt 32?? Currently I have to get into the cockpit locker – no small feat for the less nimble! I am contemplating cutting an access panel behind the head – anyone have ideas? Thanks Ron Freedom 32 Newport
RI “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD
Thanks Sward….
The 1200 looks like a nice size for the F32 although I wonder if
the 8 ½” height from deck is significant? Likewise the same dimension approx
below decks?
On most of my
access panel
Sward
I don’t know-I didn’t look into it that far for my boat as I am going to be able to repair my Lewmar. I saw it installed in his boat-a Morgan 382. He had the motor fiberglassed in and covered with teak in his V-berth. He also had the yard reinforce the deck under it. I just liked how it worked and he liked it. He told me he had done extensive research and found Rigging Only, in Fairhaven, MA to be by far the cheapest by about $500.00. ron barr <rwhb@…> wrote: Thanks Sward…. The 1200 looks like a nice size for the F32 although I wonder if the 8 ½” height from deck is significant? Likewise the same dimension approx below decks? Ron Newport RI From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of SwardSent: Tuesday, September 11, 2007 9:44 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: RE: [FreedomOwnersGroup] Windlass/Capstan for Freedom 32 The windlass is a Maxwell 1200, VW- which is better than VWC in that you can use two anchors on one wondlass and the anchor chain is accessibleSward <swardfullsail@yahoo.com> wrote: I’ll find out tomorrow night if I can.ron barr <rwhb@…> wrote: Thanks. I agree about Lewmar (and Simpson Lawrence) and have had good luck myself with Maxwells. Do you know which model he has? Ron From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of SwardSent: Monday, September 10, 2007 1:57 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: Re: [FreedomOwnersGroup] Windlass/Capstan for Freedom 32 I have a Sprint/Lewmar 1000 anchor windlass on my 32 however,
I would not get the same type again. I’ve had trouble with it many times. My friend has a Maxwell and if I had to switch out I would go with that one. Reason being, that that model has the motor out of the anchor locker and away from the moisture, and you can gain access to the chain manually without taking the thing apart.ron barr <rwhb@…> wrote: On most of my boats I have had a windlass (well strictly speaking a capstan). Has anyone done this with the Hoyt Freedom 32? I realize it is a little on the smaller side but I have found them very useful, especially in a blow or difficult holding. Makes and models appreciated. Obviously a low profile would be best. Thanks Ron Freedom 32 Newport RI From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of SwardSent: Friday, September 07, 2007 1:07 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: Re: [FreedomOwnersGroup] Access to head Seacocks on freedom 32 I have done that. I put in a 12X12 teak door as an access panel Swardron barr <rwhb@…> wrote: Has anyone solved the problem of easy access to shut off the aft head seacocks when leaving the boat on a Freedom Hoyt 32?? Currently I have to get into the cockpit locker – no small feat for the less nimble! I am contemplating cutting an access panel behind the head – anyone have ideas? Thanks Ron Freedom 32
Newport RI “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD
