windlass for f35 sloop
Posted by tatianamatysuk (tatianamatysuk@…>)
I have a pedrick design f35 and have concluded that i need some help
with the anchor;
I am considering a maxwell rc-10 windlass;
anycomments or suggestions would be welcome;
Leon
Posted by Fred Molden (fmolden@…>)
Hi Leon,
I have a Pedrick F35 with a Lewmar
anchor windlass. Fairly simple installation on the deck over the front of
the anchor locker. The motor is mounted horizontally under the
deck. I have 35 ft of chain and 200 ft of 5/8 in rode. Electric cable
comes into the anchor locker where the navigation light electric comes in and
solid state switch is also mounted inside the locker. Caution, the motor
is a soft iron housing and can rust if not washed off with fresh water, I also
coat the entire assembly with Bose Shield spray once or twice a year. I
found a place on the net located in Florida and got a very good price, I’ll
let you know if I can find it again.
Fred
FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of tatianamatysuk
Sent: Monday, October 13, 2008
11:30 AM
To:
Subject: [FreedomOwnersGroup]
need some help
with the anchor;
Leon
Thanks Fred,
is your winch horizontal or vertical?
Leon
— In FreedomOwnersGroup@yahoogroups.com, “Fred Molden”
<fmolden@…> wrote:
Hi Leon,
I have a Pedrick F35 with a Lewmar anchor windlass. Fairly simple
installation on the deck over the front of the anchor locker. The
motor is
mounted horizontally under the deck. I have 35 ft of chain and 200
ft of
5/8 in rode. Electric cable comes into the anchor locker where the
navigation light electric comes in and solid state switch is also
mounted
inside the locker. Caution, the motor is a soft iron housing and
can rust
if not washed off with fresh water, I also coat the entire assembly
with
Bose Shield spray once or twice a year. I found a place on the net
located
in Florida and got a very good price, I’ll let you know if I can
find it
again.
Fred
tatianamatysuk
Sent: Monday, October 13, 2008 11:30 AM
Subject: [FreedomOwnersGroup] windlass for f35 sloop
help
with the anchor;
Leon
Posted by HOWARD FARRER (farrer@…>)
I have the same boat - hull 64 - and have a Lewmar verticle windlass which works fine with chain. ONly problem I have is the chain piling up in the anchor locker and jamming the windlass and kicking out the circuit breaker. Once I discovered what was happening I realized I need to clear the chain pile every 25’ or so.Howard Ping #64 — On Mon, 10/13/08, tatianamatysuk <tatianamatysuk@…> wrote:From: tatianamatysuk <tatianamatysuk@…>Subject: [FreedomOwnersGroup] windlass for f35 sloopTo: FreedomOwnersGroup@yahoogroups.comDate: Monday, October 13, 2008, 11:30 AM
with the anchor;
Leon
I have the Ocean Concept vertical
windlass. The one thing I wish I had added is the optional capstain.
Not that I have needed it but it seems like a great idea if the anchor is
fouled or you need that pulling power on some other line (second anchor).
Did you decide on a wind vane? I
have always liked the Cape Horn unit due to its simplicity over the swim
platform. http://www.capehorn.com/index.html
. Let me know what you pick. I can’t justify it as 99% of my
sailing is in the Chesapeake and a couple of trips to Nantucket or Florida but
the electronic autopilot is sufficient for that kind of coastal cruising.
12:11 PM
To:
Subject: [FreedomOwnersGroup] Re:
Thanks Fred,
Leon
“Fred Molden”
<fmolden@…> wrote:
Hi Leon,
motor is
ft of
mounted
can rust
with
located
find it
again.
Fred
On Behalf Of
tatianamatysuk
help
with the anchor;
Leon
Posted by marno_ss (marno@…>)
Gday Leon,
There has been a discussion on the merit of various windlasses here
http://www.cruisersforum.com/forums/f118/simpson-lawrence-windless-20014-2.html
, the Lewmar didn’t get a very good report.
I really like the Hydrovane, but I thought they were a bit out of my
budget. I got a Fleming.
Regards
Marno
— In FreedomOwnersGroup@yahoogroups.com, “tatianamatysuk”
with the anchor;
Leon
Posted by Jim Demerest (jdemer@…>)
Leon,
I just installed a RC 10 on my 36/38 in August. I had Maxwell modify the RC10/10 and replace the chain wheel with the smaller one from the RC10/8. This gave me the heftier motor and 5/16" chain with 5/8" rope (25’ chain and 250’ rope). Maxwell offers a prespliced rope chain combo with a soft 8 ply rope that lets the rope flake into the chain locker without kinking.
Also, have the new wireless remote with a chain counter. I use the remote when letting out rode and the foot switch when hauling it in.
Sure makes life easier.
Jim Demerest
F36/38 Lady of Remes
Posted by ptecca63 (paul.tecca@…>)
Hi Fred,
I have the same windlass on my F35 and had problems with the motor
housing rusting. You mentioned that you used “Bose Shield spray” as
part of your rust prevention. I’m interested in learning more about
this product. I googled it and was unable to find anything that
matched. Where did you find it?
Regards,
Paul Tecca
Midnight Star, 1993 F35 #8
BOESHIELD spray is in the Defender catalog on page 193. Probably West
Marine too, and most full-inventory marine suppliers.
Herm
At 04:20 PM 10/14/2008, you wrote:
Hi Fred,
Regards,
Paul Tecca
Hi Paul,
Sorry for the bad data. I saw
it in Practical Sailor some time ago, its full name is Boeshield T-9 http://www.boeshield.com/ . When I
replaced the motor I needed new brass terminal nuts but could not find the
metric size so I used nickel plated steel. This would only work for a
month or two before becoming completely rusted but with the Boeshield it works
for the season and more.
Regards, Fred
Behalf Of ptecca63
Sent: Tuesday, October 14, 2008
4:21 PM
To:
Hi Fred,
Regards,
Paul Tecca
